- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] LEM variants vs. proof relevance
- Date: Mon, 30 May 2016 11:28:36 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f54.google.com
- Ironport-phdr: 9a23:fRHHcRCDVibkIF5P8blUUyQJP3N1i/DPJgcQr6AfoPdwSP74rsbcNUDSrc9gkEXOFd2CrakU2qyL6OuwByQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTmkb3psM2NKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FppIZ8VvDxeL19RrhFBhwnNXo07Yvlr0rtVwyKs1kbVGwKkhNOSyzI7Q/3WIu55in9sOt+1S2XMOX5SLk1XXKp6KI9G0ygszsOKzNsqDKfscd3lq8O+B8=
On 05/28/2016 10:26 PM, Jason Gross
wrote:
Have you considered LEM on hProps? forall P, (forall x y : P, x = y) -> P \/ ~P Together with propositional truncation / quotient types, this may give you want you want. (I think these are similar to your irrelevant_sibling; you do: Module Export Trunc. Private Inductive PropTrunc A := tr : A -> PropTrunc A. Axiom PropTrunc_trunc : forall {A} (x y : PropTrunc A), x = y. Definition Trunc_ind {A} (P : PropTrunc A -> Type) {Pt : forall x y, P x = P y} : (forall a, P (tr a)) -> (forall aa, P aa) := (fun f aa => match aa with tr a => fun _ => f a end Pt). End Trunc. ) Does this do what you want? It turns out that the Prop version of this Private trick, plus the proof relevance I'm working with, is inconsistent: Module Export TruncP. -- Jonathan |
- Re: [Coq-Club] LEM variants vs. proof relevance, (continued)
- Re: [Coq-Club] LEM variants vs. proof relevance, Gérard Huet, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Arnaud Spiwack, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/30/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/30/2016
