coq-club - Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk)
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] coqchk safe from plugins? (Was: Axioms reported by coqchk)
  • Date: Fri, 19 Aug 2016 19:40:04 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
  • Ironport-phdr: 9a23:XNHY5heqeZ1Luhqz/36hpuRVlGMj4u6mDksu8pMizoh2WeGdxc69ZR7h7PlgxGXEQZ/co6odzbGH6ua6BydZucnJ8ChbNscdD1ld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbshsi6n9q/54fUK10RwmHsOPUocl7v9VqZ9pFPx9AzcuBpklqBi0ALUtwe/XlvK1OXkkS0zeaL17knzR5tvek8/dVLS6TwcvdwZ7VZCDM7LzJ9v5Wz5lGQBTeIs3AbSyAdlgdCKwnD9hDzGJnr4QXgse8o4i6QN8DsUfgXQzmo5apxU1e8jS4GMz8//2XWkdBrpLhcqhisvQB82YPeaoyPL7x4evWOLpshWWNdU5MJBGR6CYSmYt5XAg==
A way to remedy the issue you describe is to extend coqchk with functionality to print the statement of a lemma and all of the definitions that are used in the statement of that lemma. That way, you can audit that the proof in the .vo file is in fact a proof of the lemma you are interested in.
On 08/19/2016 07:08 PM, Ralf Jung wrote:
Hi,
[Warning: digression ahead.]
On 19.08.2016 18:37, Jonathan Leivent wrote:
For coqchk the issue is that it checks module "inclusion", not actual
definition usage. Hence it will report that axioms are "present' when
Print Assumptions (even without plugin misbehavior) does not. But, it
doesn't load plugins, hence is safe from "plugin misbehavior".
Is this actually true? Sure coqchk does not load plugins, but that still
leaves the question open of what coqchk is actually checking. As far as
I understand, it checks the .vo files, so if a plugin manages to make
"good" .vo files from "bad" .v files, coqchk would not catch that. For
example, the plugin could alter the statement that has been proven such
that the .vo file contains a valid proof of *some* statement (but not
the one the user wants), and the .v files contains an *invalid* proof
(messed with by the plugin) of the statement the user wants.
It's not like I have any thoughts on how to remedy this, but I feel like
saying "malicious plugins can't harm you if you use coqchk" isn't
actually true. Admittedly, it is very unlikely for an accidental bug in
a plugin to trigger this.
Or maybe this falls into the same category as "Definition False :=
True", though "don't Import/Export any modules / fully qualify
everything" doesn't help if the plugin is messing with the parser and
pretty-printer.
Kind regards,
Ralf
