Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- Date: Wed, 7 Sep 2016 12:21:34 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f179.google.com
- Ironport-phdr: 9a23:aTysvxXtNTItRV3WT8j0O8KmleHV8LGtZVwlr6E/grcLSJyIuqrYZRODt8tkgFKBZ4jH8fUM07OQ6PG5HzJZqsfc+DBaKdoXCE9D0Z1X1yUbQ+e7SmTDZMbwaCI7GMkQHHRExFqcdXZvJcDlelfJqWez5zNBUj/2NA5yO/inUtWK15f/hKiO/MjYZBwNjz6ga5tzKg+3pEPfrJo4m4xnf4Q2zBLVonJOM8BbxH1lI07byxT74Maz8Zpu/gxfvvsg84hLVqCsLPdwdqBREDlzazN938bsrxSWFQY=
On 09/07/2016 10:13 AM, Soegtrop, Michael wrote:
Dear Guillaume,
Coq just checks that this is true for all the branches of the "match"; if so, itSorry, I don't get it. That is what I assumed Coq does until I saw your example, but how does Coq
assumes that it is also true for the "match" itself.
check that (in my example below ) the branch term "1" has type "bool"?
Definition foo2 (H : nat = bool) : bool :=
match H in (_ = t) return t with
| eq_refl => 1
end.
Here's a non-type-theorists view of what is happening: matches on equalities can only reduce when the equality is exactly eq_refl because otherwise the equality might be hypothetical - as in your nat = bool case. Even assuming UIP, when there can only be one proof of the equality, there can also be no proof of it. Hence, what the match above says is : in the imaginary world where we can prove nat = bool, 1 is a bool because it is a nat.
IMHO, the more interesting "feature" about Coq's logic is that it doesn't have universal UIP - hence it can't even assume an actual proof of x = x is always eq_refl, even though eq_refl is the only way to construct x = x. And, other constructive-logic-based dependently-typed languages out there, such as Agda and Idris, do have UIP built in (via K, which is equivalent). Coq seems to act in confusing ways when dealing with x = x. Sometimes, when that x = x is alone, it can reduce it to eq_refl. Other times, when there are multiple instances of x = x in a goal, it can only reduce one to eq_refl. Also, other one-constructor fieldless Props are irrelevant - as long as they don't have a type index.
For instance, one can prove forall (x:True), x = I, but not:
Inductive Foo : unit -> Prop := foo : Foo tt.
Goal forall (f : Foo tt), f = foo.
-- Jonathan
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, (continued)
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/06/2016
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Guillaume Melquiond, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Jonathan Leivent, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Gaetan Gilbert, 09/07/2016
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/08/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Jonathan Leivent, 09/08/2016
