Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern
- Date: Wed, 7 Sep 2016 12:39:06 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f182.google.com
- Ironport-phdr: 9a23:lHROPh1iVuBCInJRsmDT+DRfVm0co7zxezQtwd8ZsesRLvad9pjvdHbS+e9qxAeQG96KsrQa0qGH7uigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFDzsc8fnYtrLO4VxxrXr31UM7BUwmVpJl+XkhvU6cK5/Zol+CNV7aFyv/VcWLn3KvxrBYdTCy4rZjg4
On 09/07/2016 12:28 PM, Gaetan Gilbert wrote:
>For instance, one can prove forall (x:True), x = I, but not:
>Inductive Foo : unit -> Prop := foo : Foo tt.
>Goal forall (f : Foo tt), f = foo.
You can actually.
Definition foo_transport : forall (x : unit) (y : unit), Foo x -> Foo y.
Proof.
intros [] [];trivial.
Defined.
Proof.
assert (H : forall x y (a : Foo x) (b : Foo y), foo_transport _ _ a = b).
intros x y [] [].
reflexivity.
intros.
etransitivity.
- symmetry. apply H.
- apply H.
Unshelve.
+ exact tt.
+ exact f.
Defined.
Gaëtan Gilbert
OK - should have seen that coming. That's a lot like proving UIP for unit.
What I should have said is that you can't prove:
Variable A : Set.
Variable a : A.
Inductive Foo : A -> Prop := foo : Foo a.
Goal forall (f : Foo a), f = foo.
even though there really is only the one foo : Foo a.
-- Jonathan
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, (continued)
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Guillaume Melquiond, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Jonathan Leivent, 09/07/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Gaetan Gilbert, 09/07/2016
- RE: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Soegtrop, Michael, 09/08/2016
- Re: [Coq-Club] Getting "computing" proof terms with dependent types / reduction of matches with single pattern, Jonathan Leivent, 09/08/2016
