coq-club - Re: [Coq-Club] Primitive Projections and eta
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Primitive Projections and eta
  • Date: Wed, 7 Dec 2016 08:32:25 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23:tPsBHRNnFrtgHLqJNXYl6mtUPXoX/o7sNwtQ0KIMzox0K/vzrarrMEGX3/hxlliBBdydsKMfzbeP+PywESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9LKeJ0J/yj7z6u8CLIlYAuD3oarRraR6ysA/5t88MgIIkJLxi5AHOpy5ycuBYjUF1I13byxTh4MiY+YZitj9PoLQm7cEWAvayRLgxUbENVGduCGsy/sC+6EHO
Hi,
> As I understand it, any record declared with the [Record] vernacular
> whose projections can be defined, which has at least one projection,
> automatically gets eta. That is, the following records do not enjoy eta:
> Set Primitive Projections.
> Record unit := tt {}.
> Record inhabited (A : Type) : Prop := inhabits { inhabited_val : A }.
> Record unnamed_inhabitant (A : Type) := { _ : A }.
> Inductive prod A B := pair { fst : A ; snd : B }.
> and all records which do not suffer from any of these "problems" will
> automatically get eta conversion when primitive projections are turned
> on. Someone else (Matthieu?) can correct me if I've missed anything.
I see; in our case, we used 'Inductive' instead of 'Record' so we did
not get eta. Thanks! That's kind of a surprising difference between
these vernaculars, at the very least, it should be documented.
Kind regards,
Ralf
> On Tue, Dec 6, 2016 at 3:57 PM Ralf Jung
> <jung AT mpi-sws.org
> <mailto:jung AT mpi-sws.org>>
> wrote:
> Hi all,
> We started to play around with primitive projections a little in our
> development, and if they work (which unfortunately still is a rather big
> if), we could achieve some fairly significant performance improvements:
> Coq 8.6 got >7% faster (that's total compilation time!) by switching the
> record we use for sealing some of our core definitions to primitive
> projections. That's pretty impressive!
> One thing we couldn't figure out though is when we get eta conversion
> for primitive projections. The aforementioned record used for sealing
> does not have eta (according to About), while other records do. Are the
> rules for when a primitive record gets eta written down anywhere? All I
> could find in the documentation is the two paragraphs in
> <https://coq.inria.fr/distrib/8.6beta1/refman/Reference-Manual004.html>,
> which don't even mention that primitive projections have anything to do
> with eta conversion.
> Kind regards,
> Ralf
