- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Primitive Projections and eta
- Date: Wed, 7 Dec 2016 09:06:08 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT hera.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:h8FnVhd1NSQ2LtU/SuA8YeIWlGMj4u6mDksu8pMizoh2WeGdxc28YB7h7PlgxGXEQZ/co6odzbGH6Oa9ACddu97B6ClEK8McEUddyI0/pE8JPo2sMQXDNvnkbig3ToxpdWRO2DWFC3VTA9v0fFbIo3e/vnY4ExT7MhdpdKyuQtaBx5f/6+fn8JrKJg5MmTCVYLVoLRzwox+CmNMRhN5YI6I/gjnUpHQAL+ZLw2xAIEqS2g3j/YG35pE1oHcYgO4o68MVCfayRK8/V7ENVDk=
Hi,
> Le 07/12/2016 à 08:32, Ralf Jung a écrit :
>> Hi,
>>> As I understand it, any record declared with the [Record] vernacular
>>> whose projections can be defined, which has at least one projection,
>>> automatically gets eta. That is, the following records do not enjoy eta:
>>> Set Primitive Projections.
>>> Record unit := tt {}.
>>> Record inhabited (A : Type) : Prop := inhabits { inhabited_val : A }.
>>> Record unnamed_inhabitant (A : Type) := { _ : A }.
>>> Inductive prod A B := pair { fst : A ; snd : B }.
>>> and all records which do not suffer from any of these "problems" will
>>> automatically get eta conversion when primitive projections are turned
>>> on. Someone else (Matthieu?) can correct me if I've missed anything.
>> I see; in our case, we used 'Inductive' instead of 'Record' so we did
>> not get eta. Thanks! That's kind of a surprising difference between
>> these vernaculars, at the very least, it should be documented.
> Well, I think it is:
> "The option Set Primitive Projections turns on the use of primitive
> projections when defining subsequent records."
The 'Inductive' *is* a record with primitive projections. It just
doesn't get eta. I do not see a way to interpret that into the
documentation.
Kind regards,
Ralf
>> Kind regards,
>> Ralf
>>> On Tue, Dec 6, 2016 at 3:57 PM Ralf Jung
>>> <jung AT mpi-sws.org
>>> <mailto:jung AT mpi-sws.org>>
>>> wrote:
>>> Hi all,
>>> We started to play around with primitive projections a little in our
>>> development, and if they work (which unfortunately still is a rather
>>> big
>>> if), we could achieve some fairly significant performance
>>> improvements:
>>> Coq 8.6 got >7% faster (that's total compilation time!) by switching
>>> the
>>> record we use for sealing some of our core definitions to primitive
>>> projections. That's pretty impressive!
>>> One thing we couldn't figure out though is when we get eta conversion
>>> for primitive projections. The aforementioned record used for sealing
>>> does not have eta (according to About), while other records do. Are
>>> the
>>> rules for when a primitive record gets eta written down anywhere?
>>> All I
>>> could find in the documentation is the two paragraphs in
>>> <https://coq.inria.fr/distrib/8.6beta1/refman/Reference-Manual004.html>,
>>> which don't even mention that primitive projections have anything to
>>> do
>>> with eta conversion.
>>> Kind regards,
>>> Ralf
- [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Jason Gross, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Jacques-Henri Jourdan, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Matthieu Sozeau, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Maxime Dénès, 12/07/2016
