- To: coq-club AT inria.fr, Arnaud Spiwack <arnaud.spiwack AT gmail.com>
- Subject: Re: [Coq-Club] Primitive Projections and eta
- Date: Wed, 07 Dec 2016 13:34:18 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f43.google.com
- Ironport-phdr: 9a23:VCA8ZBfDS5SvoeeimgzwUdeJlGMj4u6mDksu8pMizoh2WeGdxcS4Yh7h7PlgxGXEQZ/co6odzbGH6Oa9Aydau96oizMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpTEdFQ/iOgVrO+/7BpDdj9it1+C15pbffxhEiCCzbL52Ihi6twXcutcZjYd8NKo61wfErGZPd+lK321jOEidnwz75se+/Z5j9zpftvc8/MNeUqv0Yro1Q6VAADspL2466svrtQLeTQSU/XsTTn8WkhtTDAfb6hzxQ4r8vTH7tup53ymaINH2QLUpUjms86tnVBnlgzocOjUn7G/YlNB/jKNDoBKguRN/xZLUYJqIP/Z6Z6/RYM8WSXZEUstXSidPAJ6zb5EXAuUOM+ZXrYnzqVUNoxWjGwejGPjixSVUinLsx6A2z/gtHAPA0Qc9H9wOqnPUrNDtOakVS++10LXIzTXCb/xIxDf29ZXGchcgoP6SR71wbNfaxE4qFwzfklWQtZbqPzaO2+QIqWeb8/ZgWviqi2I9rAFxuDevy94qh4LUiIwVzVXE+j94wIYzPdC4SUh7YcSlEJRKrS2aOZF2T8U/SG9roCY30r8LtJGhcCQX1pgqxwTTZv+Zf4SS7R/uWuCcKipiin1/YrKwnROy/FCgyuLiUsm0105Hri9fndnNsnABzhLS6s2bRvdk8Ees1jiC2xrc6uFDJkA0mq7bJIA7zrEskZoTtFzPHi7wmErokK+bbkcp9+ey5+j6fLnrpoWQOoxqhg3kPakjlNSzAeEiPQgPW2ib9/681Lrm/UDhRbVFlOE2krXZsJDbO8sbu7S1AxRS0oci9RmwFSqm3c8XnXkCNl1FeRaHg5L1NFHJJfD0Fe2/jEi0kDd32/DGOaXsDYnKLnjaibvuYbJ961NHxwco1tBe55dUCqkbL/7pW0/xssbYDh4jPACuzebnEoY16oRLUmWWR6SdLan6sFmS5+tpLfPILKYPvj/gJ7Ae///xhHQ60QsUZ6+gwJdRc2i5Af1tIG2WZHPthpEKFmJc7SQkS+m/rVSeTT5Samv6ZKUu6zgmQNajBJvfT4WFhbWdwC6+WJpMaTYVWRi3DX70etDcCL83YyWIL5oky2RcWA==
I'm not so sure, that's a design choice I maybe didn't realize I was making.
Maybe Arnaud has an opinion on this, since he's the one who played
with this distinction initially.
-- MatthieuOn Wed, Dec 7, 2016 at 12:43 PM Maxime Dénès <mail AT maximedenes.fr> wrote:
Hi Matthieu,
Why does the "bifiniteness" info depend on the vernacular command rather
being inferred from the declaration?
Maxime.
On 12/07/16 11:07, Matthieu Sozeau wrote:
> Hi,
> You're right, that's a bit weird. We must have removed or are missing
> a warning telling you that Inductive should rather not be used for a
> non-recursive record definition and that Record is the preferred way to
> define them. As soon as you write Inductive, eta is disabled (eta on
> recursive types is a quite different beast, see N. Ghani's thesis for
> example for a short exposition). This finiteness information you give
> (Variant/Record(bifinite) or Inductive(finite) or CoInductive(cofinite))
> is checked and used by the kernel now, in particular to decide if eta
> can be decided. All this information should be in the documentation indeed.
> Best regards,
> -- Matthieu
> On Wed, Dec 7, 2016 at 9:06 AM Ralf Jung <jung AT mpi-sws.org
> <mailto:jung AT mpi-sws.org>> wrote:
> Hi,
> > Le 07/12/2016 à 08:32, Ralf Jung a écrit :
> >> Hi,
> >>> As I understand it, any record declared with the [Record] vernacular
> >>> whose projections can be defined, which has at least one projection,
> >>> automatically gets eta. That is, the following records do not
> enjoy eta:
> >>> Set Primitive Projections.
> >>> Record unit := tt {}.
> >>> Record inhabited (A : Type) : Prop := inhabits { inhabited_val
> : A }.
> >>> Record unnamed_inhabitant (A : Type) := { _ : A }.
> >>> Inductive prod A B := pair { fst : A ; snd : B }.
> >>> and all records which do not suffer from any of these "problems"
> will
> >>> automatically get eta conversion when primitive projections are
> turned
> >>> on. Someone else (Matthieu?) can correct me if I've missed
> anything.
> >> I see; in our case, we used 'Inductive' instead of 'Record' so we did
> >> not get eta. Thanks! That's kind of a surprising difference between
> >> these vernaculars, at the very least, it should be documented.
> > Well, I think it is:
> > "The option Set Primitive Projections turns on the use of primitive
> > projections when defining subsequent records."
> The 'Inductive' *is* a record with primitive projections. It just
> doesn't get eta. I do not see a way to interpret that into the
> documentation.
> Kind regards,
> Ralf
> >> Kind regards,
> >> Ralf
> >>> On Tue, Dec 6, 2016 at 3:57 PM Ralf Jung <jung AT mpi-sws.org
> >>> <mailto:jung AT mpi-sws.org <mailto:jung AT mpi-sws.org>>> wrote:
> >>> Hi all,
> >>> We started to play around with primitive projections a
> little in our
> >>> development, and if they work (which unfortunately still is
> a rather big
> >>> if), we could achieve some fairly significant performance
> improvements:
> >>> Coq 8.6 got >7% faster (that's total compilation time!) by
> switching the
> >>> record we use for sealing some of our core definitions to
> primitive
> >>> projections. That's pretty impressive!
> >>> One thing we couldn't figure out though is when we get eta
> conversion
> >>> for primitive projections. The aforementioned record used
> for sealing
> >>> does not have eta (according to About), while other records
> do. Are the
> >>> rules for when a primitive record gets eta written down
> anywhere? All I
> >>> could find in the documentation is the two paragraphs in
> <https://coq.inria.fr/distrib/8.6beta1/refman/Reference-Manual004.html>,
> >>> which don't even mention that primitive projections have
> anything to do
> >>> with eta conversion.
> >>> Kind regards,
> >>> Ralf
- [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Jason Gross, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Jacques-Henri Jourdan, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Matthieu Sozeau, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Maxime Dénès, 12/07/2016
