- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Primitive Projections and eta
- Date: Wed, 07 Dec 2016 10:07:13 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wj0-f182.google.com
- Ironport-phdr: 9a23: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
Hi,
You're right, that's a bit weird. We must have removed or are missing a warning telling you that Inductive should rather not be used for a non-recursive record definition and that Record is the preferred way to define them. As soon as you write Inductive, eta is disabled (eta on recursive types is a quite different beast, see N. Ghani's thesis for example for a short exposition). This finiteness information you give (Variant/Record(bifinite) or Inductive(finite) or CoInductive(cofinite)) is checked and used by the kernel now, in particular to decide if eta can be decided. All this information should be in the documentation indeed.
Best regards,
-- Matthieu
On Wed, Dec 7, 2016 at 9:06 AM Ralf Jung <jung AT mpi-sws.org> wrote:
Hi,
> Le 07/12/2016 à 08:32, Ralf Jung a écrit :
>> Hi,
>>> As I understand it, any record declared with the [Record] vernacular
>>> whose projections can be defined, which has at least one projection,
>>> automatically gets eta. That is, the following records do not enjoy eta:
>>> Set Primitive Projections.
>>> Record unit := tt {}.
>>> Record inhabited (A : Type) : Prop := inhabits { inhabited_val : A }.
>>> Record unnamed_inhabitant (A : Type) := { _ : A }.
>>> Inductive prod A B := pair { fst : A ; snd : B }.
>>> and all records which do not suffer from any of these "problems" will
>>> automatically get eta conversion when primitive projections are turned
>>> on. Someone else (Matthieu?) can correct me if I've missed anything.
>> I see; in our case, we used 'Inductive' instead of 'Record' so we did
>> not get eta. Thanks! That's kind of a surprising difference between
>> these vernaculars, at the very least, it should be documented.
> Well, I think it is:
> "The option Set Primitive Projections turns on the use of primitive
> projections when defining subsequent records."
The 'Inductive' *is* a record with primitive projections. It just
doesn't get eta. I do not see a way to interpret that into the
documentation.
Kind regards,
Ralf
>> Kind regards,
>> Ralf
>>> On Tue, Dec 6, 2016 at 3:57 PM Ralf Jung <jung AT mpi-sws.org
>>> <mailto:jung AT mpi-sws.org>> wrote:
>>> Hi all,
>>> We started to play around with primitive projections a little in our
>>> development, and if they work (which unfortunately still is a rather big
>>> if), we could achieve some fairly significant performance improvements:
>>> Coq 8.6 got >7% faster (that's total compilation time!) by switching the
>>> record we use for sealing some of our core definitions to primitive
>>> projections. That's pretty impressive!
>>> One thing we couldn't figure out though is when we get eta conversion
>>> for primitive projections. The aforementioned record used for sealing
>>> does not have eta (according to About), while other records do. Are the
>>> rules for when a primitive record gets eta written down anywhere? All I
>>> could find in the documentation is the two paragraphs in
>>> <https://coq.inria.fr/distrib/8.6beta1/refman/Reference-Manual004.html>,
>>> which don't even mention that primitive projections have anything to do
>>> with eta conversion.
>>> Kind regards,
>>> Ralf
- [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Jason Gross, 12/06/2016
- Re: [Coq-Club] Primitive Projections and eta, Ralf Jung, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Jacques-Henri Jourdan, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Matthieu Sozeau, 12/07/2016
- Re: [Coq-Club] Primitive Projections and eta, Maxime Dénès, 12/07/2016
