coq-club - Re: [Coq-Club] evar anomaly
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] evar anomaly
  • Date: Fri, 10 Feb 2017 13:42:03 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f173.google.com
  • Ironport-phdr: 9a23:YsH7pheBf//io/uTEMUE43ovlGMj4u6mDksu8pMizoh2WeGdxc2ybR7h7PlgxGXEQZ/co6odzbGH7+awBidZuM3J8ChbNscTB1ld0YRetjdjKfDGIHWzFOTtYS0+EZYKf35e1Fb/D3JoHt3jbUbZuHy44G1aMBz+MQ1oOra9QdaK3IyB/rvtoNiLP00I2WL8MvtOK0C9qhyUvc0Li6NjLLwww13HuChmYeNTkEFvI1uPnx/6ruO9/YBu9TgY7/Am8c9DXKH3cow3SLVZCHItNGVjt56jjgXKUQbavihUaW4RiBcdXlDI
On 02/10/2017 12:35 PM, Jason Gross wrote:
Yes, this is a bug (an "anomaly" is always a bug worth reporting, though
occasionally the bug is just "there should be a real error message here"),
but it doesn't seem to occur in Coq 8.6; your "unshelve refine" fails.
This is probably https://coq.inria.fr/bugs/show_bug.cgi?id=5122
Note that cases there that produced the bug in pre-release 8.6 versions now fail in released 8.6 before producing the bug as well.
-- Jonathan
On Fri, Feb 10, 2017 at 11:05 AM Tom Hirschowitz <
tom.hirschowitz AT univ-smb.fr>
wrote:
Hi all,
The little proof below fails on exact (...) with
Anomaly: cannot define an evar twice. Please report.
But it does go through using apply instead of exact.
Is this a bug?
Thanks,
Tom
PS: the code grew out of an attempt at finding an efficient way to program
the equivalent
Definition trivial' A (a : A) (F : el (Typ A) a) : El a = F :=
match F with El _ => eq_refl end.
from the tactic language (in a more complex setting, of course).
I'd be grateful for any hints about this too :)
Set Implicit Arguments.
Unset Strict Implicit.
Unset Printing Implicit Defensive.
Inductive typ : Type -> Type := Typ : forall T, typ T.
Inductive el : forall A, typ A -> A -> Type :=
El : forall A (a : A), el (Typ A) a.
Definition trivial A (a : A) (F : el (Typ A) a) : El a = F.
unshelve refine (@el_rect _ _ A (Typ A) a F).
clear A a F.
intros A X a F.
unshelve refine ((@typ_rect (fun A' X' => (forall a' : A', el X' a' ->
Type)) _ A X) a F).
clear A X a F.
intros A a F.
exact (El a = F).
simpl.
reflexivity.
Defined.
