- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] evar anomaly
- Date: Fri, 10 Feb 2017 15:23:58 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qt0-f179.google.com
- Ironport-phdr: 9a23:VrGvcxzwaQF1EovXCy+O+j09IxM/srCxBDY+r6Qd0u0TIJqq85mqBkHD//Il1AaPBtSHraIbwLON7uigATVGusnR9ihaMdRlbFwst4Y/p0QYGsmLCEn2frbBThcRO4B8bmJj5GyxKkNPGczzNBX4q3y26iMOSF2kbVImbre9JomHhMOukuu25pf7YgNShTP7b6khAg+xqFDzsc8fnYtrLO4VxxrXr31UM7BUwmVpJl+XkhvU6cK5/Zol+CNV7aFyv/VcWLn3KvxrBYdTCy4rZjg4
On 02/10/2017 12:35 PM, Jason Gross
wrote:
Yes, this is a bug (an "anomaly" is always a bug worth reporting, though occasionally the bug is just "there should be a real error message here"), but it doesn't seem to occur in Coq 8.6; your "unshelve refine" fails. This is probably https://coq.inria.fr/bugs/show_bug.cgi?id=5122 Note that cases there that produced the bug in pre-release 8.6 versions now fail in released 8.6 before producing the bug as well. -- Jonathan On Fri, Feb 10, 2017 at 11:05 AM Tom Hirschowitz < tom.hirschowitz AT univ-smb.fr> wrote: Hi all, The little proof below fails on exact (...) with Anomaly: cannot define an evar twice. Please report. But it does go through using apply instead of exact. Is this a bug? Thanks, Tom PS: the code grew out of an attempt at finding an efficient way to program the equivalent Definition trivial' A (a : A) (F : el (Typ A) a) : El a = F := match F with El _ => eq_refl end. from the tactic language (in a more complex setting, of course). I'd be grateful for any hints about this too :) --------------------------------------------------- Set Implicit Arguments. Unset Strict Implicit. Unset Printing Implicit Defensive. Inductive typ : Type -> Type := Typ : forall T, typ T. Inductive el : forall A, typ A -> A -> Type := El : forall A (a : A), el (Typ A) a. Definition trivial A (a : A) (F : el (Typ A) a) : El a = F. unshelve refine (@el_rect _ _ A (Typ A) a F). clear A a F. intros A X a F. unshelve refine ((@typ_rect (fun A' X' => (forall a' : A', el X' a' -> Type)) _ A X) a F). clear A X a F. intros A a F. exact (El a = F). simpl. reflexivity. Defined. |
- [Coq-Club] evar anomaly, Tom Hirschowitz, 02/10/2017
- Re: [Coq-Club] evar anomaly, Jason Gross, 02/10/2017
- Re: [Coq-Club] evar anomaly, Jonathan Leivent, 02/10/2017
- Re: [Coq-Club] evar anomaly, Tom Hirschowitz, 02/10/2017
