coq-club - Re: [Coq-Club] evar anomaly
  • From: Tom Hirschowitz <tom.hirschowitz AT univ-smb.fr>
  • To: Jonathan Leivent <jonikelee AT gmail.com>, coq-club AT inria.fr
  • Cc:
  • Subject: Re: [Coq-Club] evar anomaly
  • Date: Fri, 10 Feb 2017 21:38:47 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tom.hirschowitz AT univ-smb.fr; spf=None smtp.mailfrom=tom.hirschowitz AT univ-smb.fr; spf=None smtp.helo=postmaster AT smtpout01.partage.renater.fr
Ah, right, thanks to both of you. (And sorry for not looking directly
into the bug tracker, I confess I trusted google...)
Tom
> On 02/10/2017 12:35 PM, Jason Gross wrote:
>> Yes, this is a bug (an "anomaly" is always a bug worth reporting, though
>> occasionally the bug is just "there should be a real error message here"),
>> but it doesn't seem to occur in Coq 8.6; your "unshelve refine" fails.
> This is probably https://coq.inria.fr/bugs/show_bug.cgi?id=5122
> Note that cases there that produced the bug in pre-release 8.6 versions
> now fail in released 8.6 before producing the bug as well.
> -- Jonathan
>> On Fri, Feb 10, 2017 at 11:05 AM Tom Hirschowitz <
>> wrote:
>>> Hi all,
>>> The little proof below fails on exact (...) with
>>> Anomaly: cannot define an evar twice. Please report.
>>> But it does go through using apply instead of exact.
>>> Is this a bug?
>>> Thanks,
>>> Tom
>>> PS: the code grew out of an attempt at finding an efficient way to program
>>> the equivalent
>>> Definition trivial' A (a : A) (F : el (Typ A) a) : El a = F :=
>>> match F with El _ => eq_refl end.
>>> from the tactic language (in a more complex setting, of course).
>>> I'd be grateful for any hints about this too :)
>>> Set Implicit Arguments.
>>> Unset Strict Implicit.
>>> Unset Printing Implicit Defensive.
>>> Inductive typ : Type -> Type := Typ : forall T, typ T.
>>> Inductive el : forall A, typ A -> A -> Type :=
>>> El : forall A (a : A), el (Typ A) a.
>>> Definition trivial A (a : A) (F : el (Typ A) a) : El a = F.
>>> unshelve refine (@el_rect _ _ A (Typ A) a F).
>>> clear A a F.
>>> intros A X a F.
>>> unshelve refine ((@typ_rect (fun A' X' => (forall a' : A', el X' a' ->
>>> Type)) _ A X) a F).
>>> clear A X a F.
>>> intros A a F.
>>> exact (El a = F).
>>> simpl.
>>> reflexivity.
>>> Defined.
