- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat
- Date: Wed, 6 Sep 2017 10:51:20 +0200
On 06/09/2017 10:42, Jacques-Henri Jourdan wrote:
> My naive understanding is that it would create a fresh (set of) universe
> variable, and copy all the edges of the existing universe variable of
> the list inductive type. But there should not be any direct constraint
> between the fresh universe to the one of the original list definition.
I don't think it has ever worked that way. (That said, I never
understood why it was called "template", so maybe it was meant to work
that way). For instance, if you type
Check (fun T : Type => list T).
you get a constraint between the Type type here and the one from the
definition of list:
Top.1 |= Top.1 <= Coq.Init.Datatypes.44
Best regards,
Guillaume
- [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jan-Oliver Kaiser, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Guillaume Melquiond, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jan-Oliver Kaiser, 09/11/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/12/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/13/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Ralf Jung, 09/14/2017
