- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT normalesup.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat
- Date: Wed, 6 Sep 2017 17:12:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jacques-henri.jourdan AT normalesup.org; spf=Neutral smtp.mailfrom=jacques-henri.jourdan AT normalesup.org; spf=None smtp.helo=postmaster AT ulminfo.fr
- Ironport-phdr: 9a23:eQ3cUB0eiC9P+zwssmDT+DRfVm0co7zxezQtwd8ZsegWKfad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL3DMr2eN7T8OF1C6HEI1Y72tQs+Bx/iwguu14tjYZxhCrDu7e7J7ahus/ivLscxDo4JpM7s80V7pr31Seqx0wn5yKVuV10L+78yp4ZN4tiRdveggscxHTL/2dqIQS7tCCT0iPnso/IvsrxaVHljH3WcVTmhDykkAOAPC9hyvG86p6iY=
Le 06/09/2017 à 13:58, Jacques-Henri Jourdan a écrit :
> Reason 1)
> Partially applying a template polymorphic type does not trigger
> instantiation with fresh universe variables, and we do not understand
> why. This issue has already been raised on this mailing list on Sat,
> 22 Oct 2016 by Gregory Malecha in a post entitled "list :: nil?", but
> I do not quite understand the answer. At that time, Matthieu answered :
> > Indeed, in the template case partial applications do not give
> you a fresh instance (because there's no way to know what the fresh
> levels are in that case, when retyping) , but an eta-expanded version
> will work I think, e.g fun X => list X, as then we can look at the
> type of X to determine the type of list X.
> What does "because there's no way to know what the fresh levels are in
> that case, when retyping"?
> Can't you just use fresh level and unify them with whatever they need
> to be unified with, depending on the context?
> Why is this a problem for template polymorphism and not for full
> polymorphism?
> Also, more fundamentally, why doesn't that break subject reduction,
> given that eta-reduction is part of Coq's conversion rules?
Maybe I should explain why this is a problem for us: It is not possible,
in our case, to eta-expand the list type where it appears, because it
appears as a parameter of a typeclass that needs to unify with
non-eta-expanded instances of list.
That is, we have a typeclass `FMap : (Type -> Type) -> Type`, and we
want to define an instance of type `FMap list`. An instance of type
`FMap (fun X => list X) would not work, because it would not be selected
when searching for instances of type `FMap list`.
JH
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jan-Oliver Kaiser, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Guillaume Melquiond, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jan-Oliver Kaiser, 09/11/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/12/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/13/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Ralf Jung, 09/14/2017
