- To: coq-club AT inria.fr, Matthieu Sozeau <mattam AT mattam.org>
- Subject: Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat
- Date: Thu, 14 Sep 2017 16:36:37 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:qYUw0hxBJVFInkTXCy+O+j09IxM/srCxBDY+r6Qd0uIQIJqq85mqBkHD//Il1AaPBtqLra8cw8Pt8IneGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2NBXupSi56idXERHiPyJ0IP70E8jclYD/8umu553SbhgAvz2vbLpvZEGzpBnNv8w+hIJ+Nq80jBzTrS0bVf5RwDZSLFad1zTh4Mj4qJx+9St4vuogstVfSuP9ZatuHu8QNygvL21gvJ6jjhLEVwbavnY=
Hi Matthieu,
ah, that's interesting! I think I actually ran into this ~2 years ago
when working on Iris. So, this is not something that just comes up when
doing MetaCoq.
What I wanted to do for Iris was parameterize the logic by a list of
functors (describing the ghost state that will be available). I ran
into universe inconsistencies that we ended up fixing by having our own
copy of the list type. The setup has since changed somewhat, but at
least the comment survived:
<https://gitlab.mpi-sws.org/FP/iris-coq/blob/f96a894b14fe7095bb5ac5b937abd31e40316858/theories/base_logic/lib/iprop.v#L37>
This development also has the problematic FMap instance.
So, this is actually a problem that one can run into doing "normal" Coq
work, not just doing Coq metaprogramming.
Thanks for digging into this, at least now we understand. :)
Kind regards,
Ralf
On 12.09.2017 20:30, Matthieu Sozeau wrote:
> Hi,
> template polymorphic inductives can't be instantiated by universes,
> one could only "refresh" their type but that would only be useful for
> the conclusion, and even then I don't know what we could do in the
> kernel, the fresh universes have no place to be recorded in the
> representation. The domain types would still have to be convertible,
> e.g. list's universe i would have to be equal to the domain of Fmap's G
> operator in the Fmap list application. Otherwise said, template
> polymorphism does not go as far as making the domain of the G type
> constructor a "parameter" of Fmap.
> Also, singleton classes like Fmap do not have template polymorphism,
> you'd need Class Fmap G := { fmap : ... } to declare an inductive
> instead of a definition, but that doesn't change the problem.
> Module BuiltinLists.
> Universe i.
> Class Fmap (G : Type@{i} -> Type) := fmap : forall {A B : Type@{i}}
> (f : A -> B) , G A
> -> G B.
> Set Printing Universes.
> Instance list_Fmap : Fmap list := map.
> (* Forces lists' Datatypes.44 = i *)
> Fail Definition fails := map _ (cons list_Fmap nil).
> (* (list_Fmap : Fmap list : Type@{i+1,..) > i = Datatypes.44 *)
> End BuiltinLists.
>> What does "because there's no way to know what the fresh levels are in
>> that case, when retyping"?
> Can't you just use fresh level and unify them with whatever they need to
> be unified with, depending on the context?
> Why is this a problem for template polymorphism and not for full
> polymorphism?
> Also, more fundamentally, why doesn't that break subject reduction,
> given that eta-reduction is part of Coq's conversion rules?
> As mentioned by Guillaume, eta is only about conversion.
> The difference between template and full is exactly that list (and Fmap,
> and map) get universe instances attached to them in the internal
> representation, while template polymorphic inductives need their
> parameters types to typecheck (i.e. we need to see list A to infer its
> type using template polymorphism, which will depend on A's inferred
> type, partial applications don't have enough information to do that). So
> that leaves only eta-expansion to get out of your conundrum. Your
> example is even worsened by the partial application of map in list_Fmap,
> the following works:
> Module BuiltinListsEtaMap.
> Class Fmap (G : Type -> Type) := fmap : forall {A B} (f : A
> -> B) , G A -> G B.
> fun A B => @map A B.
> Definition succeeds := map id (cons list_Fmap nil).
> (* This is because map's universes are not fixed by the list_Fmap
> implementation in this case. However fmap id fails for the reason above *)
> Fail Definition fails := fmap id (cons list_Fmap nil).
> End BuiltinListsEtaMap.
> You could work around it a little bit using a polymorphic class and
> instance,
> but won't be able to "tie the knot" by applying fmap on lists containing
> Fmap list objects which might be what you want.
> Universe i.
> Polymorphic Class Fmap@{i} (G : Type@{i} -> Type@{i}) := fmap :
> forall {A B : Type@{i}} (f : A
> -> B) , G A -> G B.
> (** This ones fully polymorphic, i is only bounded by global floating
> universes which are meant to go as high as necessary *)
> Polymorphic Instance list_Fmap@{i} : Fmap@{i} (fun A : Type@{i} =>
> list A) :=
> (** This instance is for the fixed Datatypes.44 universe *)
> Instance list_Fmap' : Fmap list := list_Fmap.
> (** One can use Fmap' like this *)
> Check (fmap S (cons 0 nil)).
> Check (fmap (@tl nat) nil).
> (** But not like this, as list_Fmap' sort included the global list
> universe *)
> Fail Definition fail' := fmap (@id _) (cons list_Fmap' nil).
> Definition succeeds := fmap id (cons list_Fmap nil).
> Hope this helps,
> -- Matthieu
> On Mon, Sep 11, 2017 at 11:37 AM Jan-Oliver Kaiser
> <janno AT mpi-sws.org
> <mailto:janno AT mpi-sws.org>>
> wrote:
> Here's some further illustration of the problem Jacques-Henri mentioned.
> I included different variations because I had initially thought that
> maybe it could be worked around by making the FMap class or instance
> polymorphic. But it turns out that that doesn't help at all.
> Now, the example I use doesn't make any sense on it's own but I am not
> convinced that one couldn't come up with more sensible ways of
> triggering universe inconsistencies in this setup.
> Best,
> Janno
> From Coq Require Import List.
> Class Fmap (G : Type -> Type) := fmap : forall A B (f : A -> B) , G A
> -> G B.
> Fail Definition fails := map _ (cons list_Fmap nil). (* sad face *)
> End BuiltinLists.
> Module BuiltinListsPolyClass.
> Polymorphic Class Fmap (G : Type -> Type) := fmap : forall A B (f : A
> -> B) , G A -> G B.
> End BuiltinListsPolyClass.
> Module BuiltinListsPolyInstance.
> -> B) , G A -> G B.
> Polymorphic Instance list_Fmap : Fmap list := map.
> End BuiltinListsPolyInstance.
> Module PolyLists.
> Polymorphic Inductive list {A : Type} := | nil : list | cons : A ->
> list -> list.
> Arguments list A : clear implicits.
> Polymorphic Definition map {A B : Type} (f : A -> B) := fix go l :=
> match l with | nil => nil | cons a l => cons (f a) (go l) end.
> Arguments map [A B].
> -> B) , G A -> G B.
> Definition works := map id (cons list_Fmap nil). (* works but now we
> can't use `list` from the prelude *)
> End PolyLists.
> On 09/06/2017 05:12 PM, Jacques-Henri Jourdan wrote:
> > Le 06/09/2017 à 13:58, Jacques-Henri Jourdan a écrit :
> >> Reason 1)
> >> Partially applying a template polymorphic type does not trigger
> >> instantiation with fresh universe variables, and we do not understand
> >> why. This issue has already been raised on this mailing list on Sat,
> >> 22 Oct 2016 by Gregory Malecha in a post entitled "list :: nil?", but
> >> I do not quite understand the answer. At that time, Matthieu
> answered :
> >> > Indeed, in the template case partial applications do not
> give
> >> you a fresh instance (because there's no way to know what the fresh
> >> levels are in that case, when retyping) , but an eta-expanded version
> >> will work I think, e.g fun X => list X, as then we can look at the
> >> type of X to determine the type of list X.
> are in
> >> to be unified with, depending on the context?
> >> polymorphism?
> > Maybe I should explain why this is a problem for us: It is not
> possible,
> > in our case, to eta-expand the list type where it appears, because it
> > appears as a parameter of a typeclass that needs to unify with
> > non-eta-expanded instances of list.
> > That is, we have a typeclass `FMap : (Type -> Type) -> Type`, and we
> > want to define an instance of type `FMap list`. An instance of type
> > `FMap (fun X => list X) would not work, because it would not be
> selected
> > when searching for instances of type `FMap list`.
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, (continued)
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Guillaume Melquiond, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/06/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jan-Oliver Kaiser, 09/11/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Matthieu Sozeau, 09/12/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Jacques-Henri Jourdan, 09/13/2017
- Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat, Ralf Jung, 09/14/2017
