coq-club - Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Mysterious Universes introduced by List.tl and List.repeat
  • Date: Mon, 11 Sep 2017 11:35:46 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=janno AT mpi-sws.org; spf=Pass smtp.mailfrom=janno AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23:b9TvnBXNi1dihKc/7hwun1QexwTV8LGtZVwlr6E/grcLSJyIuqrYZRGPt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aSV3DMl9+If2wEYrPhey20fqz8tvdeVZmnj24NJF7KlCRqQTPu9NeooJjMasrgk/Lq31OfMxT3WItPk2I2RHm6ZHjr9ZY7y1Mtqd5pIZ7WqLgcvFgQA==
Here's some further illustration of the problem Jacques-Henri mentioned. I included different variations because I had initially thought that maybe it could be worked around by making the FMap class or instance polymorphic. But it turns out that that doesn't help at all.
Now, the example I use doesn't make any sense on it's own but I am not convinced that one couldn't come up with more sensible ways of triggering universe inconsistencies in this setup.
Best,
Janno
From Coq Require Import List.
Module BuiltinLists.
Class Fmap (G : Type -> Type) := fmap : forall A B (f : A -> B) , G A
-> G B.
Instance list_Fmap : Fmap list := map.
Fail Definition fails := map _ (cons list_Fmap nil). (* sad face *)
End BuiltinLists.
Module BuiltinListsPolyClass.
Polymorphic Class Fmap (G : Type -> Type) := fmap : forall A B (f : A
-> B) , G A -> G B.
End BuiltinListsPolyClass.
Module BuiltinListsPolyInstance.
-> B) , G A -> G B.
Polymorphic Instance list_Fmap : Fmap list := map.
End BuiltinListsPolyInstance.
Module PolyLists.
Polymorphic Inductive list {A : Type} := | nil : list | cons : A ->
list -> list.
Arguments list A : clear implicits.
Polymorphic Definition map {A B : Type} (f : A -> B) := fix go l :=
match l with | nil => nil | cons a l => cons (f a) (go l) end.
Arguments map [A B].
-> B) , G A -> G B.
Definition works := map id (cons list_Fmap nil). (* works but now we can't use `list` from the prelude *)
End PolyLists.
On 09/06/2017 05:12 PM, Jacques-Henri Jourdan wrote:
Le 06/09/2017 à 13:58, Jacques-Henri Jourdan a écrit :
Reason 1)
Partially applying a template polymorphic type does not trigger
instantiation with fresh universe variables, and we do not understand
why. This issue has already been raised on this mailing list on Sat,
22 Oct 2016 by Gregory Malecha in a post entitled "list :: nil?", but
I do not quite understand the answer. At that time, Matthieu answered :
> Indeed, in the template case partial applications do not give
you a fresh instance (because there's no way to know what the fresh
levels are in that case, when retyping) , but an eta-expanded version
will work I think, e.g fun X => list X, as then we can look at the
type of X to determine the type of list X.
What does "because there's no way to know what the fresh levels are in
that case, when retyping"?
Can't you just use fresh level and unify them with whatever they need
to be unified with, depending on the context?
Why is this a problem for template polymorphism and not for full
polymorphism?
Also, more fundamentally, why doesn't that break subject reduction,
given that eta-reduction is part of Coq's conversion rules?
Maybe I should explain why this is a problem for us: It is not possible,
in our case, to eta-expand the list type where it appears, because it
appears as a parameter of a typeclass that needs to unify with
non-eta-expanded instances of list.
That is, we have a typeclass `FMap : (Type -> Type) -> Type`, and we
want to define an instance of type `FMap list`. An instance of type
`FMap (fun X => list X) would not work, because it would not be selected
when searching for instances of type `FMap list`.
