- From: Joachim Breitner <mail AT joachim-breitner.de>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Variable scope creep?
- Date: Wed, 08 Nov 2017 23:37:04 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
- Ironport-phdr: 9a23:eancrBZSdcO92prEKGbV5UH/LSx+4OfEezUN459isYplN5qZpsS8bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76wCAfACr/NBZ4Y6HcUs6X1pzvlrP6x5qGaAJRwTG5fLlaLROsrAyXuNNFr5FlL/MTzRLConpNM85MyGJ0I1+J10L578a01Jxk+i9Quvdk/dRNULn8cr5+QbEOX2duCHw8+MC+7UqLdgCI/HZJFzxOyhc=
Dear list,
here is a curious puzzle. Consider this file:
Class Class f := {
field1 : forall {a}, f a -> unit ;
field2 : forall {a}, f (a -> a) -> unit }.
Definition option_field1 : forall {a}, option a -> unit :=
fun {a} => fun _ => tt.
Definition option_field2 : forall {a}, option (a -> a) -> unit:=
Instance instance1 : Class option :=
{| field1 := fun {a} => option_field1 ;
field2 := _ |}.
exact @option_field2.
Defined.
Print instance1.
Instance instance2 : Class option :=
{| field1 := @option_field1;
field2 := @option_field2 |}.
Instance instance3 : Class option :=
The first two instance declarations go through, the third one fails with this
error messagE:
Error:
The term "@option_field2" has type "forall a : Type, option (a -> a) ->
unit"
while it is expected to have type
"forall a : Type, option ?a@{a:=a -> a} -> unit" (cannot instantiate
"?a" because "a" is not in its scope: available arguments are "a -> a").
This looks very fishy to me. Why should a change in how I implement
field1 change the typing of my assignment of field2?
It looks almost as if the [fun {a} =>] of the field1 somehow leaks into
the type-checking of field2...
Or maybe the problem is somewhere else… any insight is appreciated!
This is The Coq Proof Assistant, version 8.6 (July 2017), compiled on
Jul 20 2017 12:59:58 with OCaml 4.02.3
Thanks,
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
signature.asc
Description: This is a digitally signed message part
- [Coq-Club] Variable scope creep?, Joachim Breitner, 11/09/2017
- Re: [Coq-Club] Variable scope creep?, Yao Li, 11/10/2017
- Re: [Coq-Club] Variable scope creep?, Joachim Breitner, 11/11/2017
- Re: [Coq-Club] Variable scope creep?, Gaëtan Gilbert, 11/11/2017
