- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Variable scope creep?
- Date: Fri, 10 Nov 2017 16:06:55 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=liyao AT seas.upenn.edu; spf=Pass smtp.mailfrom=liyao AT seas.upenn.edu; spf=None smtp.helo=postmaster AT fox.seas.upenn.edu
- Ironport-phdr: 9a23:TveXABeFWJEIYOx4s66aLFmHlGMj4u6mDksu8pMizoh2WeGdxc2/ZB7h7PlgxGXEQZ/co6odzbGJ4+a9ASQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpW1aJhKqPg1sY+/xB4T6jsKt1un09YeATR9PgW+MaLQ6CBT++QHQp8ARqZBvI7131wPEpH0OduhLkzA7bWmPlgrxs5/jtKVo9D5d7qos
It’s probably because of the difference between {|…|} and {…}.
The following code would work:
Instance instance3 : Class option :=
{ field1 := fun {a} => option_field1 ;
field2 := @option_field2 }.
I remember hearing from Benjamin that type inference works differently in
{|…|} and {…}, but I’m not knowledgable enough to explain what exactly is
going on here.
Best,
Yao
> On 8 Nov 2017, at 11:37 PM, Joachim Breitner
> <mail AT joachim-breitner.de>
> wrote:
> Dear list,
> here is a curious puzzle. Consider this file:
> Class Class f := {
> field1 : forall {a}, f a -> unit ;
> field2 : forall {a}, f (a -> a) -> unit }.
> Definition option_field1 : forall {a}, option a -> unit :=
> fun {a} => fun _ => tt.
> Definition option_field2 : forall {a}, option (a -> a) -> unit:=
> Instance instance1 : Class option :=
> {| field1 := fun {a} => option_field1 ;
> field2 := _ |}.
> exact @option_field2.
> Defined.
> Print instance1.
> Instance instance2 : Class option :=
> {| field1 := @option_field1;
> field2 := @option_field2 |}.
> The first two instance declarations go through, the third one fails with
> this error messagE:
> Error:
> The term "@option_field2" has type "forall a : Type, option (a -> a) ->
> unit"
> while it is expected to have type
> "forall a : Type, option ?a@{a:=a -> a} -> unit" (cannot instantiate
> "?a" because "a" is not in its scope: available arguments are "a -> a").
> This looks very fishy to me. Why should a change in how I implement
> field1 change the typing of my assignment of field2?
> It looks almost as if the [fun {a} =>] of the field1 somehow leaks into
> the type-checking of field2...
> Or maybe the problem is somewhere else… any insight is appreciated!
> This is The Coq Proof Assistant, version 8.6 (July 2017), compiled on
> Jul 20 2017 12:59:58 with OCaml 4.02.3
> Thanks,
> Joachim
> Joachim Breitner
> http://www.joachim-breitner.de/
- [Coq-Club] Variable scope creep?, Joachim Breitner, 11/09/2017
- Re: [Coq-Club] Variable scope creep?, Yao Li, 11/10/2017
- Re: [Coq-Club] Variable scope creep?, Joachim Breitner, 11/11/2017
- Re: [Coq-Club] Variable scope creep?, Gaëtan Gilbert, 11/11/2017
