- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Variable scope creep?
- Date: Sat, 11 Nov 2017 01:10:41 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay3-d.mail.gandi.net
- Ironport-phdr: 9a23:E6ATIBXf9ppQ2wZAYsKLnh9X92nV8LGtZVwlr6E/grcLSJyIuqrYZRyHt8tkgFKBZ4jH8fUM07OQ6P+wHzFYqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aLDvwOTJSA6y1R9eT3IyL0LW5/ISWaAFVjhK8Z6lzJVO4t1b/rM4T1KRrqbo4zCzmo39Cdv5KjTdnLF+PlhC66ca09pN57wxLuOM69M9FVKjgOaI1UeoLX3wdL2kp6Ziz5lH4RgyV6y5BC2g=
The issue is that you made the unification problem more difficult until Coq could not solve it anymore. TLDR try Program Definition.
After replacing holes with evars, the definition of instance3 looks like
Build_Class ?f (fun a => @option_field1 ?x@{a:=a}) @option_field2.
(plus an evar for the type of the fun a binding)
typechecking it involves a first unification problem checking that the type of (fun a => @option_field1 ?x@{a:=a}) is the expected type:
(forall a, ?f a -> unit) == (forall a, option ?x@{a:=a} -> unit).
which simplifies to
a |- ?f a == option ?x{a:=a}
This is solved by taking ?f := fun a => option ?x@{a:=a}.
Then there is a second unification problem for the type of @option_field2:
(forall a, ?f (a -> a) -> unit) == (forall a, option (a -> a) -> unit).
substituting our definition for ?f:
(forall a, option ?x@{a:=a -> a} -> unit) == (forall a, option (a -> a) -> unit).
Coq is incapable of solving this so it fails.
If Coq used bidirectional typechecking the constraint that the whole must have type Class option would be used earlier to set ?f := option. I believe Program does this and indeed
Require Import Program.
Program Definition instance3 : Class option :=
Build_Class _ (fun {a} => option_field1 ) (@option_field2).
succeeds.
This has come up before, see eg https://sympa.inria.fr/sympa/arc/coq-club/2017-06/msg00083.html mentioning a similar issue.
Gaëtan Gilbert
On 11/11/2017 00:40, Joachim Breitner wrote:
Hi,
good point. In the real code, however, I have to use {|…|} because it
is a Definition, not an Instance, so I believe I cannot use {…}.
I learned that using Build_ and instantiating the argument works
better:
Class Class f := {
field1 : forall {a}, f a -> unit ;
field2 : forall {a}, f (a -> a) -> unit }.
Definition option_field1 : forall {a}, option a -> unit :=
fun {a} => fun _ => tt.
Definition option_field2 : forall {a}, option (a -> a) -> unit:=
Definition instance1 : Class option :=
Build_Class _ (@option_field1) (@option_field2).
Definition instance2 : Class option :=
Build_Class option (fun {a} => option_field1 )
(@option_field2).
instance1 and instance2 work, instance3 does not.
Joachim
- [Coq-Club] Variable scope creep?, Joachim Breitner, 11/09/2017
- Re: [Coq-Club] Variable scope creep?, Yao Li, 11/10/2017
- Re: [Coq-Club] Variable scope creep?, Joachim Breitner, 11/11/2017
- Re: [Coq-Club] Variable scope creep?, Gaëtan Gilbert, 11/11/2017
