coq-club - Re: [Coq-Club] Variable scope creep?
  • From: Joachim Breitner <mail AT joachim-breitner.de>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Variable scope creep?
  • Date: Fri, 10 Nov 2017 18:40:57 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mail AT joachim-breitner.de; spf=Neutral smtp.mailfrom=mail AT joachim-breitner.de; spf=None smtp.helo=postmaster AT hermes.serverama.de
  • Ironport-phdr: 9a23:bIe1kx12I0cyb+FtsmDT+DRfVm0co7zxezQtwd8ZseseLPad9pjvdHbS+e9qxAeQG96Eu7QZ06L/iOPJZy8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL3DMr2eN7T8OF1C6HEI1Y72tQs+Bx/iwguu14tjYZxhCrDu7e7J7ahus/ivLscxDo4xrIaYwz1PjuHZJZ+Jb3ys8IFuSmz7+4c67/J9mti5KtvM98cNaF6n3KfdrBYdEBSgrZjhmrPbgsgPOGE7WviMR
Hi,
good point. In the real code, however, I have to use {|…|} because it
is a Definition, not an Instance, so I believe I cannot use {…}.
I learned that using Build_ and instantiating the argument works
better:
Class Class f := {
field1 : forall {a}, f a -> unit ;
field2 : forall {a}, f (a -> a) -> unit }.
Definition option_field1 : forall {a}, option a -> unit :=
fun {a} => fun _ => tt.
Definition option_field2 : forall {a}, option (a -> a) -> unit:=
Definition instance1 : Class option :=
Build_Class _ (@option_field1) (@option_field2).
Definition instance2 : Class option :=
Build_Class option (fun {a} => option_field1 )
(@option_field2).
Definition instance3 : Class option :=
Build_Class _ (fun {a} => option_field1 ) (@option_field2).
instance1 and instance2 work, instance3 does not.
Joachim
Joachim Breitner
http://www.joachim-breitner.de/
Attachment: signature.asc
Description: This is a digitally signed message part
