Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- To: José Manuel Rodriguez Caballero <josephcmac AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- Date: Wed, 02 May 2018 18:46:49 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=e AT x80.org; spf=Pass smtp.mailfrom=e AT x80.org; spf=Pass smtp.helo=postmaster AT x80.org
- Ironport-phdr: 9a23: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
- Organization: X80 Heavy Industries
Dear José,
writes:
> Thank you very much by the information that Voevodsky retracted its
> conjecture that PA is inconsistent (it would be wonderful to find a video
> or a manuscript of him in order to know the context).
If my memory serves me correctly you should be able to find a mail
discussion in FOM around the date of the talk.
> Nevertheless, as far as I know, he didn't retracted his second claim:
> "CIC is not cleaned defined, because it is an initial model of a
> theory which itself requires natural numbers to be specified".
I am not an expert on the meta-theory of CIC and indeed I heard that it
may have some rough edges, but AFAIK there should not be a serious
problem there.
> Concerning you claim that "consistency of PA is a well-established fact",
> according to your two arguments I only can deduce that "consistency of PA
> is a well-established belief". First, "the termination of the finitary
> Hydra game" is not true for certain initial segment of PA (this is
> precisely the theorem that I'm trying to mechanize in Coq right now). You
> can prove "the termination of the finitary Hydra game" in ZFC as well as in
> CiC, but that is more, not less. Second, the argument "if you had to bet
> all your current and future state to either..." can be used to "prove" any
> conjecture, for example the 3x+1 conjecture.
Well, I say it is a well established fact as I can build a _physical_
machine that will actually normalize any proof let's say, in System-T,
provided you give me a finite, but _unbounded_ number of pieces, thus
breaking the "assumption cycle" by constructing an actual device.
I guess the device could be a steam-punk like machine [with gears and
steam pipes and whatnot] but usually computers are more practical; but
indeed, this only holds if I can assume an unbounded amount of memory,
well, in the case of PA I believe given the input term I can predict the
maximum amount of memory I would use.
As I wrote on the other mail, rejecting the unbounded nature of our
theoretical computing devices it is a valid and fair point, but usually
off-topic in the context of traditional cut-elimination proofs.
> CiC is wonderful for many branches of mathematics, but there are some
> foundational problems when it is applied as an autonomous foundation of
> mathematics.
I'll have to disagree here, as indeed in my very humble view you cannot
do much better than having a realizability model in terms of
philosophical justification; basically you are reducing truth to a
computation that can be carried out by a physical machine, and thus
outside the realm of mathematics themselves.
I am not sure what kind of problem you do find with that, other than of
course the unavoidable physical limits of reality.
E.
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), (continued)
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), ikdc, 05/01/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Matej Košík, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Pierre-Yves Strub, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Emilio Jesús Gallego Arias, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), R. Pollack, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Arthur Azevedo de Amorim, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Siddharth Bhat, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Andrej Bauer, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Adam Chlipala, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Jose Manuel Rodriguez Caballero, 05/02/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Pierre Courtieu, 05/02/2018
