coq-club - Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
  • From: José Manuel Rodriguez Caballero <josephcmac AT gmail.com>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
  • Date: Fri, 4 May 2018 22:54:17 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=josephcmac AT gmail.com; spf=Pass smtp.mailfrom=josephcmac AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f175.google.com
  • Ironport-phdr: 9a23:Qz4glhAfb4qh6Mw1YoeeUyQJP3N1i/DPJgcQr6AfoPdwSPvyr8bcNUDSrc9gkEXOFd2Cra4c0KyO6+jJYi8p2d65qncMcZhBBVcuqP49uEgeOvODElDxN/XwbiY3T4xoXV5h+GynYwAOQJ6tL1LdrWev4jEMBx7xKRR6JvjvGo7Vks+7y/2+94fcbglUijexe69+IAmrpgjNq8cahpdvJLwswRXTuHtIfOpWxWJsJV2Nmhv3+9m98p1+/SlOovwt78FPX7n0cKQ+VrxYES8pM3sp683xtBnMVhWA630BWWgLiBVIAgzF7BbnXpfttybxq+Rw1DWGMcDwULs5Xymp4aV2Rx/ykCoINTA5/mHZhMJzkaxVvg6uqgdlzILIeoyYLuZycr/fcN4cWGFPXtxRVytEAo6ka4UPCPEBOvxAoIf6vVQOqwa+CheoBOz31jFIgWL53bc70+QuDAHJwg0hEMoQvXvOt9r6LqMSUeSrw6nSyjXIcvRb2TX66IjTbB8hufGMUq51ccXL1UYiDAzFjlCKpozkOzOZzPgCs2+e7+d5U++klmApqwZ0oje1x8csjJHEhpgIylze8yV5xJ45JcWjSE5me9KrDoZftzycOoBrQc0iW3lltDgmxrACo5K2fygHxI46yxPedvCLaZWE7xDjWeuXPDx2nmhqeKiliBa36UWgyvPzVs2z0FtSqypKiNjMtnQU2x3T5MmLVuJx/km81TuN1w3f8O5EIUczlarUL54u3KQ8mYYUsUTGBiP2mUP2g7GKdkg85OSk9+Dqbq/lq5KcLYN4lwDzPrk0lsCiA+k1MhACX22B9uS90L3j81f5QLJPjvAukKnZt4vaKtoDpq65HwBV15ws5AqkAjep1dQXh3gHLFZfdB2biIjpPknCIOrkAvenn1SsjDBryujaMb3mG5XBN2TMkLP8fblm8ENc0woyzdVH551OEL0BIfTzWlXwtNPCFBM5PRa0kK7bD4B20ZpbUmaSCIeYNrnTuBmG/LEBOe6JMa0So7fKDvEj+vPqukU+lUUccrSkz6w8YXqxGvBrOULRNXjrmdoZEWwPtwEWQ+njiVnEWjlWMSXhF5kg7y02Xdr1RbzIQZqg1eTYjXWLW6ZOb2UDMWiiVHLhdoGKQfAJMXvALcpokzhCXr+kGdZ4iUOe8TTiwr8iFdL6vzUCvMu6htdw7uzX0xo18G4sVpnP4yS2V2hx21gwaXo20aR4+xIvz16C1e1pnKQdG4UMurVGVQA1MZOaxOt/WYj/
Emilio said
I am not sure what do you mean, the paper is very clear in that every
strategy is a winning strategy (Thm. 2.(i))
Read page 291 in the paper
Kirby, Laurie, and Jeff Paris. "Accessible independence results for Peano arithmetic." Bulletin of the London Mathematical Society 14.4 (1982): 285-293. http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.107.3303&rep=rep1&type=pdf
There is an initial segment M of first-order Peano Arithmetic (denoted just P in this paper) such that no interval [1, y] is omega_c-large. Furthermore, it says how to define such a model, formalizing in Peano arithmetic a certain theorem about rapidly increasing functions due to Ketonen and Solovay  (it can be done in O'Connor simulation of first-order Peano arithmetic). You suppose that every Goodstein sequence terminates and you deduce from this fact that there is an interval [1, y] which is omega_c - large. Because we are in classical logic, it follows that there exists a Goodstein sequence which does not terminate.
I'm just focus on CategoryTheory from UniMath in order to formalize in Coq my favorite model of arithmetic:
Moerdijk, Ieke. "A model for intuitionistic non-standard arithmetic." (1995). http://repository.ubn.ru.nl/bitstream/handle/2066/129065/129065.pdf?sequence=1
I'm trying to formalize in UniMath (using Coq) the unprovability of Goodstein's theorem in higher-order Heyting arithmetic, following a topos theoretic approach. My motivation to read Russell's paper was to try to do it in his first-order system, but I think that the first-order logic is not essential in Moerdijk's approach. Of course, it will be not the original Kirby & Paris theorem, but a free version in Coq.
By the way, Emilio, do you think that the incompleteness of arithmetic can be mechanized in Coq without simulating first-order logic? I think that you can repeat the Gödel-Rosser argument by coding CiC by Gödel numbers. I do not see why first-order logic is essential here.
If higher-order arithmetic is incomplete, then in particular first-order arithmetic is incomplete too. I wonder if there could be some simplifications...
