Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- To: José Manuel Rodriguez Caballero <josephcmac AT gmail.com>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- Date: Sat, 05 May 2018 00:56:30 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=e AT x80.org; spf=Pass smtp.mailfrom=e AT x80.org; spf=Pass smtp.helo=postmaster AT x80.org
- Ironport-phdr: 9a23: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
- Organization: X80 Heavy Industries
writes:
> Read page 291 in the paper
> There is an initial segment M of first-order Peano Arithmetic (denoted just
> P in this paper) such that no interval [1, y] is omega_c-large.
> Furthermore, it says how to define such a model, formalizing in Peano
> arithmetic a certain theorem about rapidly increasing functions due to
> Ketonen and Solovay (it can be done in O'Connor simulation of first-order
> Peano arithmetic). You suppose that every Goodstein sequence terminates and
> you deduce from this fact that there is an interval [1, y] which is omega_c
> - large. Because we are in classical logic, it follows that there exists a
> Goodstein sequence which does not terminate.
Sorry if I am bit obstruse as I barely got out of a day-long meeting and
have to do some urgent stuff so I write in a hurry, but doesn't this
just show that "P + ¬Con(P)" has a model?
What problem do you have with Theorem 2.(i) in the paper you cite?
You claimed "there is such a losing strategy" and indeed there exists
one due to oddities of non-standard models (which is sometimes a high
price to pay, as others have said, for keeping compactness)
But this doesn't mean you can prove that there exists a losing strategy,
in fact, quite the contrary it is possible to prove in ZFC that all
strategies are winning strategies.
Let me remark that I explicitly asked to interpreted the Hydra game as a
computational, or psychical device.
Let's take it this way, should you be able to prove that the following
program terminates: [example due to Michael J. O'Donnell]
while(a > 0) a--;
Well, if is interpreted in a non-standard model you may find trouble,
won't you?
> Moerdijk, Ieke. "A model for intuitionistic non-standard arithmetic."
> (1995). http://repository.ubn.ru.nl/bitstream/handle/2066/
> 129065/129065.pdf?sequence=1
> I'm trying to formalize in UniMath (using Coq) the unprovability of
> Goodstein's theorem in higher-order Heyting arithmetic, following a topos
> theoretic approach. My motivation to read Russell's paper was to try to do
> it in his first-order system, but I think that the first-order logic is not
> essential in Moerdijk's approach. Of course, it will be not the original
> Kirby & Paris theorem, but a free version in Coq.
That's very interesting, but may not be pain-free. You are totally right
that CIC is a very syntactic system and thus it may not map well to some
key notions on categorical logic. And also you are right about the
different trade-offs involved in the formalization of model theory and
logic. Coq in a sense gives you a "model" for free. So you can trivially
prove the consistency of PA in Coq just by building nat and a few
trivial proofs.
> By the way, Emilio, do you think that the incompleteness of arithmetic can
> be mechanized in Coq without simulating first-order logic? I think that you
> can repeat the Gödel-Rosser argument by coding CiC by Gödel numbers. I do
> not see why first-order logic is essential here.
That's a very good point, but somehow you need to reflect the syntax of
Coq terms; I am not sure what the best choice would be here, I guess
that Russell can say more as I vaguely recall reading on some paper of
his "I would pick a different syntax representation would I start again".
In terms of embedding to Coq, FOL or System-T may be fine; however
binders turn out to be a pain and Paulson recently used Hereditarily
Finite Sets plus Nominal Isabelle which seems like very cool stuff.
> If higher-order arithmetic is incomplete, then in particular first-order
> arithmetic is incomplete too. I wonder if there could be some
> simplifications...
I have no idea, but looks like a very interesting question; maybe
someone more expert knows more?.
For consistency, it is very easy to take advantage of the
meta-theoretical property, as Coq is a quite strong system, but for
incompleteness...
E.
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), (continued)
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Andrej Bauer, 05/03/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Jose Manuel Rodriguez Caballero, 05/03/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), roconnor, 05/03/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Ken Kubota, 05/03/2018
- Message not available
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Ken Kubota, 05/03/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/04/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Emilio Jesús Gallego Arias, 05/04/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Emilio Jesús Gallego Arias, 05/05/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), roconnor, 05/05/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/05/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Tadeusz Litak, 05/05/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/05/2018
