Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument)
- Date: Sat, 5 May 2018 13:30:34 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tadeusz.litak AT gmail.com; spf=Pass smtp.mailfrom=tadeusz.litak AT gmail.com; spf=None smtp.helo=postmaster AT mail-wr0-f169.google.com
- Ironport-phdr: 9a23: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
An aside: as relevance arithmetic keeps
being dragged into the pit, merged in a puzzling way with model
theory, let us clarify what it shows, and what actual lessons one
can draw from studying it. We also seem to have a few other basic
misunderstandings regarding model theory itself. I'll address them
briefly below, but these are perhaps more obvious to at least some
readers of this list than problematic use made of relevance
arithmetic in this discussion.
Just to be clear: I think that arithmetic and set theory based on substructural logics (not only relevance logics) is a very interesting subject, and there is not nearly enough attention devoted to it (still, there are many more references than those quoted so far; a few more are mentioned below). In particular, I believe it has a lot to offer to theorem proving and formalized mathematics. But sadly, it also has some potential to attract half-baked and overexcited interpretations, particularly from people with insufficient training. Of course, far be it from me to insinuate we have a case in point here, but I wouldn't like anybody (still) reading this discussion (especially students!) to get wrong ideas, so better safe than sorry. First and foremost, there are several notions of consistency in relevance logic; as usual with nonclassical logics, one can make distinctions invisible in the classical setting. The consistency notion which corresponds most naturally to the classical one is "negation-consistency". And R# (one should rather write "RA", or even better "MA"...) is *subject to exactly the same restrictions as PA* here! It has been stated very clearly by its creator (in the unlikely case it's not obvious anyway): the impossibility of provinghttp://www.filozof.uni.lodz.pl/bulletin/pdf/05_4_3.pdf (btw, just to relieve people worried about the name on this paper, Robert K. Meyer has nothing to with James Meyer. The latter is, as correctly mentioned several days ago, a crank. The former was, for all his idiosyncrasies and eccentricities, an eminent logician) In other words, R# cannot exclude the existence of a sentence A s.t. R# |- A and, at the same time, R# |- ~A (although if there is such a sentence, then PA is screwed as well). It gets funnier than that: these finitary models of R# where 0 = 1 fails all validate both (0 = 0) and ~(0 = 0) (the latter is not a theorem of R# because it is rejected in various infinite models, including the standard one...). And while they refute (0 = 1), the first of them validates (0 = 2), the next one refutes it, but validates (0 = 3) and so on. One can find more here: http://www.jstor.org/stable/227414 Curious as it all is, I doubt that Hilbert would find this satisfying. ******* This is one sense in which R# is "finitarily consistent". Another, perhaps even more exotic one, is described by Bob Meyer as follows: one can prove, "Equations which violate the addition or multiplication tables for + and \times" are very weak formulas indeed. Of course, if Peano Arithmetic or Heyting Arithmetic is inconsistent, then in particular such equations are derivable in them, simply because everything is derivable from A & ~A. But, as we have said above, R# may be inconsistent (in the standard sense of being "negation-inconsistent") and still not everything would be derivable. Relevance logic does not obey ex falso quodlibet. Again, recall that non-derivability of such absurd equations still goes hand-in-hand that many of them actually hold in this or that finitary model of R#. And the situation is even worse for negations of derivable equations, such as ~(0= 0) which hold in all the finitary ones. Besides, as admitted by Bob Meyer, many cut-free formulations of classical arithmetic have similar consistency properties. ******* As I said, the family of substructural arithmetic and set theories is not restricted to its relevance species. And the discovery that famous paradoxes and contradictions tend to lose their fangs over substructural propositional base has been made repeatedly. A famous example is Grisin's 1982 consistent naive set theory build without contraction rule (this is, in a sense, the opposite polarity of substructural spectrum to the one investigated by relevance logicians). (Incidentally, I've read papers in "leading philosophical journals" such as "Mind" published several decades later, which completely ignored this and other substructural developments and presented the realization that Russell's paradox can be "avoided" when contraction is banished as a new and revolutionary discovery...) The uses of substructural logic in set theory are not limited to playing cat-and-mouse with paradoxes. See, say, Terui's proof that a function on {0,1}-words is provably total in Light Affine Set Theory iff it is computable in polynomial time: http://www.kurims.kyoto-u.ac.jp/~terui/lastfin.pdf ****** I hope nobody is making the claim that classical model theory as a field leans towards *more* constructive, predicative or relevant approaches than CIC, or that typical publications in the field are agnostic wrt foundations. If anything, the exact opposite seems true. Numerous papers in the field essentially rely not only on ZFC, but on large cardinal axioms; indeed, one obviously needs to assume existence of some inaccessible cardinals to even talk about models of ZFC and similar theories. Just go tell Shelah, Newelski or Keisler they are supposed to get predicative or avoid classical logic, treat PA with suspicion and perhaps simply base their work on relevant arithmetic. Indeed, even something as basic as the ultrafilter construction is essentially, fundamentally and irreparably non-constructive. For this reason, finally, it'd be absolutely surreal to question the axioms of PA, yet talk freely about its nonstandard models. Showing that such models exist requires a bigger and *much* more problematic fragment of ZFC than constructing the standard model of PA in ZF! Ditto for any other metatheory one can think of. Ciao, t. On 04/05/18 05:29, José Manuel Rodriguez Caballero wrote:
Emilio
said
So now the question is, can you construct a losing strategy for the Hydra game? There is such a losing strategy, but you need to take a certain initial segment of non-standard model of first-order Peano arithmetic, this is how Kirby and Paris proved the unprovability of Goodstein theorem in PA (page 291 of Accessible Independence Results for Peano Arithmetic). Russell said I'm about as confident that there is no infinitely long descending chain of ordinal notations in Cantor normal form as I am that there is no infinitely long descending chain of natural numbers. If you take Nelson's Internal Set Theory in place of ZFC,
then you can prove in a trivial way that there exists an
"infinitely long" descending chain of ordinal notations in
Cantor normal form, where "infinitely
long" here means "larger than any standard natural
number", i.e. larger than any n : nat. Of course that
sequence will be Dedekind-finite, but from a practical
point of view, it will be infinite.
To
believe that the statement 0 = 1 is false is not the same
a to believe in the consistency of PA. Indeed, the
relevant arithmetic R# is consistent and you can prove
there that the statement 0 = 1 cannot be deduced.
If there is an inconsistency of PA, it will be because
of its first-order classical logic and it will be
related to the induction principle.
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), (continued)
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Ken Kubota, 05/03/2018
- Message not available
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Ken Kubota, 05/03/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/04/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Emilio Jesús Gallego Arias, 05/04/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Emilio Jesús Gallego Arias, 05/05/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), roconnor, 05/05/2018
- Re: [Coq-Club] [Metamath] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/05/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), Tadeusz Litak, 05/05/2018
- Re: [Coq-Club] A criticism to CIC from the point of view of foundations of mathematics (Voevodsky's argument), José Manuel Rodriguez Caballero, 05/05/2018
