- From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] proving a lemma in a proof
- Date: Wed, 23 Jan 2019 11:13:56 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay8-d.mail.gandi.net
- Ironport-phdr: 9a23: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
Could you report this on github with enough info to reproduce? Thanks
Gaëtan Gilbert
On 22/01/2019 06:08, Jeremy Dawson wrote:
Hi,
I get the following errors:
gen_moveL < apply midI3.
Toplevel input, characters 6-11:
> apply midI3.
Error: The reference midI3 was not found in the current environment.
gen_moveL < Check midI3.
> Check midI3.
gen_moveL < Lemma midI3: forall T (a b c d : list T) (x y : T),
a = c -> b = d -> a ++ x :: b = c ++ x :: d.
gen_moveL < Toplevel input, characters 6-11:
Error: midI3 already exists.
I'm in the middle of a long proof, in which I have previously proved a
useful lemma, called midI3.
Presumably the lemma I've proved is considered (though not actually) to
depend somehow on the particular state of the proof at which I first
proved it. Would that be right?
but it seems the system won't let me use it at the current point in my
proof, and won't let me prove it again.
So my question is, having decided during a proof that a particular lemma
would be useful, how to I prove and use it?
thanks
Jeremy
- Re: [Coq-Club] proving a lemma in a proof, (continued)
- Re: [Coq-Club] proving a lemma in a proof, Jim Fehrle, 01/22/2019
- RE: [Coq-Club] proving a lemma in a proof, Soegtrop, Michael, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Gaëtan Gilbert, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, James McKinna, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Christian Doczkal, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Jeremy Dawson, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Laurent Thery, 01/22/2019
- Re: [Coq-Club] proving a lemma in a proof, Jan Bessai, 01/22/2019
- Re: [Coq-Club] proving a lemma in a proof, Pierre Courtieu, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Adam Chlipala, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Théo Zimmermann, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Maxime Dénès, 01/23/2019
- Re: [Coq-Club] proving a lemma in a proof, Ralf Jung, 01/24/2019
- Re: [Coq-Club] proving a lemma in a proof, Théo Zimmermann, 01/24/2019
- Re: [Coq-Club] proving a lemma in a proof, Adam Chlipala, 01/24/2019
- Re: [Coq-Club] proving a lemma in a proof, Beta Ziliani, 01/24/2019
