coq-club - [Coq-Club] existT
[Coq-Club] existT
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: [Coq-Club] existT
  • Date: Tue, 1 Oct 2019 07:57:05 +0000
  • Accept-language: en-US
  • Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
  • Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=YPvU8xKbHXLFmODuACJJfZ6YlWtaI6E9sALrWAcm+zw=; b=gQOfi8TPPxEvkyq5y7dy3j1Jexqgwn8cpwUD3KuKm3/WiYWj8u5Fua8HunpjavJg7dXg9aXHKKGyaokfY7TRuxvr5K+E3wAqVahzmPwIfrt8jc/OHOr/KavO3pTJqmH9yPh0AkEn4KlBAwSATatBESMlE9552L8gb/SJag/qrXWLRHfzlh8q681Wi3VNhIjP3R20kk9kxPvVjizTU5YTCxWcTKovYOjqHVgdpgqCkaQ4dxRdYzwKK4GVDa8qbFgdNx7gL/eOlU3cxp5VqZY4+zk9zqZnvA8JudsZryqVn/QHXASF8ovJjHMYwkyi9oJ4BAVbJ/Ef/Qv0dN/AmCMDuQ==
  • Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=PhiuX4vny4pSL9F48K2EZFsh/7Gzv91KS1SKsgyUAXXjtLQbMH1Ndo9gWqHXaadhxhhGNhjZaqssje3xEdvMYUwhr8od2ziuhyHLrb3PNofhQRC/8R9APySbp9s80pGa67XLAL+D+xKjJexX4TPMzg/IxQhR9YqOWb40UqP1MEx2gNLoGAhXgxSVtF0dEM2lFqwC1zyQqQCXB4pWrrP2dSFQGZfZpXc3hqAgd6F1MK+j+1YLYH96sZECKYPAULxOtJ63PtF24vFTJSmTBmvAEioUM29HsuB2KaRDTw06f1hdlfgAeSTLRPXfTsqT1DxdQ7SaRhjtefqj+6vUlTtDHg==
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-SY3-obe.outbound.protection.outlook.com
  • Ironport-phdr: 9a23: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
Hi,
I have an inductive definition:
Inductive
in_dersrec (X : Type) (rules : rlsT X) (prems : X -> Type)
(concl : X) (d : derrec rules prems concl)
: forall concls : list X, dersrec rules prems concls -> Type :=
in_dersrec1 : forall (concls : list X) (ds : dersrec rules prems
concls),
in_dersrec d (dlCons d ds)
| in_dersrec2 : forall (concl' : X) (d' : derrec rules prems concl')
(concls : list X) (ds : dersrec rules prems concls),
in_dersrec d ds -> in_dersrec d (dlCons d' ds)
When I have a goal with
X0 : in_dersrec d ds
among the assumptions,
inversion X0. gives new assumptions
ds0 : dersrec rules prems concls
H0, H2 : p :: concls = ps
H3 : existT (fun x : list X => dersrec rules prems x)
(p :: concls) (dlCons d ds0) =
existT (fun x : list X => dersrec rules prems x) ps ds
What I would expect to get is also
dlCons d ds0 = ds
Whay do I get this strange assumption?
Furthermore, it seems that existT is a constructor for the inductive
definition of sigT. That being so, why doesn't injection H3
give that the respective arguments of the two occurrences of existT are
equal?
thanks for any help
Jeremy
