coq-club - Re: [Coq-Club] existT
  • From: Matthieu Sozeau <matthieu.sozeau AT inria.fr>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] existT
  • Date: Wed, 16 Oct 2019 15:58:53 +0200
> Le 16 oct. 2019 à 15:47, Sylvain Boulmé
> <Sylvain.Boulme AT univ-grenoble-alpes.fr>
> a écrit :
> Hello Jeremy,
> Le 16/10/2019 à 15:35, Jeremy Dawson a écrit :
> > Given the earlier replies to my question, this doesn't seem to make sense
> When you "Require Import Coq.Program.Equality",
> you implicitly import the "eq_rect_eq" axiom, of:
> https://coq.inria.fr/library/Coq.Logic.Eqdep.html
> whereas earlier replies explain how to avoid this axiom in some cases.
> To my knowledge, there is no particular issue with this axiom, except that
> it may not be consistent with other axioms, such as univalence.
There is always the issue that axioms are stuck terms. Equations [1] provides
dependent elimination
tactics that avoid relying on it. For example, if you can provide an instance
of the type class
`UIP A := forall (x y : A) (p q : x = y), p = q` (or `EqDec A` from which
`UIP A` can be derived)
then the tactics will simplify equalities of sigma-types with `A` as a domain
without relying
on an axiom but rather on the proof. It will also tell you if you try to
implicitly use the
K/UIP/eq_rect_eq axiom while performing a dependent elimination (switch `Set
Equations With UIP`
to allow its use based on provided type class instances).
The Equations Reloaded paper provides an in-depth explanation of the issue
and how Equations
treats it.
[1] http://mattam82.github.io/Coq-Equations/
Best,
— Matthieu
