coq-club - Re: [Coq-Club] existT
  • From: Sylvain Boulmé <Sylvain.Boulme AT univ-grenoble-alpes.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] existT
  • Date: Wed, 16 Oct 2019 15:47:50 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=Pass smtp.mailfrom=Sylvain.Boulme AT univ-grenoble-alpes.fr; spf=None smtp.helo=postmaster AT zm-mta-out-1.u-ga.fr
Hello Jeremy,
Le 16/10/2019 à 15:35, Jeremy Dawson a écrit :
> Given the earlier replies to my question, this doesn't seem to make sense
When you "Require Import Coq.Program.Equality",
you implicitly import the "eq_rect_eq" axiom, of:
https://coq.inria.fr/library/Coq.Logic.Eqdep.html
whereas earlier replies explain how to avoid this axiom in some cases.
To my knowledge, there is no particular issue with this axiom, except that it may not be consistent with other axioms, such as univalence.
Sylvain.
Thanks for these replies, several of them say in different ways that
(only) under certain conditions, existT is injective in its 3rd argument.
But it seems that now I've been proving it without making any such
assumption:
[jeremy@localhost sysadmin]$ coqtop -color no
Welcome to Coq 8.8.2 (January 2019)
Coq < Require Import Coq.Program.Equality. (* for dependent
induction/destruction *)
Coq < Lemma existT_inj: forall A P (x : A) px px',
existT P x px = existT P x px' -> (px = px').
Coq < 1 subgoal
forall (A : Type) (P : A -> Type) (x : A) (px px' : P x),
existT P x px = existT P x px' -> px = px'
existT_inj < Proof. intros. dependent destruction H. tauto. Defined.
1 subgoal
A : Type
P : A -> Type
x : A
px, px' : P x
H : existT P x px = existT P x px'
px = px'
1 subgoal
A : Type
P : A -> Type
x : A
px' : P x
px' = px'
No more subgoals.
existT_inj is defined
Cheers,
Jeremy
On 2/10/19 11:12 pm, Tom de Jong wrote:
> Actually, under some conditions existT is injective. It is the case if
> the underlying type has decidable equality. See proof below. IIRC
> a proof of this nowadays is also in the standard library, but I do not
> seem to be able to find it that quickly.
https://coq.inria.fr/library/Coq.Logic.Eqdep_dec.html
Best,
Tom
On 02/10/2019 1:47 pm, Chris Dams wrote:
Hello all,
Good luck,
Chris
Definition sigT_get_proof:
    forall T: Type,
    forall eq_dec_T: forall t t': T, {t = t'} + {~ t = t'},
    forall P: T -> Type,
    forall t: T,
    P t ->
    sigT P ->
    P t.
intros T eq_dec_T P t H1 H2.
destruct H2 as [t' H2].
destruct (eq_dec_T t t') as [H3|H3].
rewrite H3.
exact H2.
exact H1.
Defined.
Theorem sigT_get_proof_existT_same:
    forall T: Type,
    forall t: T,
    forall H1 H2: P t,
    sigT_get_proof eq_dec_T t H1 (existT P t H2) = H2.
Proof.
unfold sigT_get_proof.
destruct (eq_dec_T t t) as [H3|H3].
unfold eq_rect_r.
symmetry.
exact (eq_rect_eq_dec eq_dec_T (fun t: T => P t) H2 (sym_eq H3)).
tauto.
Qed.
Theorem existT_injective:
    forall T,
    (forall t1 t2: T, { t1 = t2 } + { t1 <> t2 }) ->
    forall t: T,
    forall pt1 pt2: P t,
    existT P t pt1 = existT P t pt2 ->
    pt1 = pt2.
Proof.
intros T T_dec P t pt1 pt2 H1.
pose (H2 := f_equal (sigT_get_proof T_dec t pt1) H1).
repeat rewrite sigT_get_proof_existT_same in H2.
assumption.
Qed.
