coq-club - Re: [Coq-Club] existT
  • From: Dominique Larchey-Wendling <dominique.larchey-wendling AT loria.fr>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] existT
  • Date: Tue, 1 Oct 2019 11:18:15 +0200 (CEST)
Hi Jeremy,
Pierre Casteran points you to the right place.
I just complete the information by telling you
that the constructor existT is *not* injective
in its third argument.
This means that from
existT P x tx = existT P y ty
you can deduce x = y (with projT1)
but you *cannot* deduce tx = ty (in general).
What you can prove is the following:
existT P x tx = existT P y ty -> exists E : x = y, ty = eq_rect x P tx y E.
If the type X on which P : X -> Type has some extra
properties, like "proof irrelevance on the type of
equalities over X", or stronger, "decidable equality over X",
then you can prove
existT P x t1 = existT P x t2 -> t1 = t2
because there is only one proof that x = x
and this is eq_refl.
See the script below and also welcome to the
wonderful world of dependent types ;-)
Best
Dominique
Section existT_inj.
Variable (X : Type) (P : X -> Type).
Fact existT_inv x tx y ty :
E.
Proof.
inversion 1; exists eq_refl; reflexivity.
Qed.
Hypothesis eq_X_pirr : forall (x y : X) (E1 E2 : x = y), E1 = E2.
Fact existT_inj2 x t1 t2 :
existT P x t1 = existT P x t2 -> t1 = t2.
Proof.
intros H.
apply existT_inv in H.
destruct H as (E & ->).
rewrite (eq_X_pirr _ _ _ eq_refl).
simpl; trivial.
Qed.
End existT_inj.
Check existT_inv.
Check existT_inj2.
----- Mail original -----
> De: "Jeremy Dawson"
> <Jeremy.Dawson AT anu.edu.au>
> À: "coq-club"
> Envoyé: Mardi 1 Octobre 2019 09:57:05
> Objet: [Coq-Club] existT
> Hi,
> I have an inductive definition:
> Inductive
> in_dersrec (X : Type) (rules : rlsT X) (prems : X -> Type)
> (concl : X) (d : derrec rules prems concl)
> : forall concls : list X, dersrec rules prems concls -> Type :=
> in_dersrec1 : forall (concls : list X) (ds : dersrec rules prems
> concls),
> in_dersrec d (dlCons d ds)
> | in_dersrec2 : forall (concl' : X) (d' : derrec rules prems concl')
> (concls : list X) (ds : dersrec rules prems concls),
> in_dersrec d ds -> in_dersrec d (dlCons d' ds)
> When I have a goal with
> X0 : in_dersrec d ds
> among the assumptions,
> inversion X0. gives new assumptions
> ds0 : dersrec rules prems concls
> H0, H2 : p :: concls = ps
> H3 : existT (fun x : list X => dersrec rules prems x)
> (p :: concls) (dlCons d ds0) =
> existT (fun x : list X => dersrec rules prems x) ps ds
> What I would expect to get is also
> dlCons d ds0 = ds
> Whay do I get this strange assumption?
> Furthermore, it seems that existT is a constructor for the inductive
> definition of sigT. That being so, why doesn't injection H3
> give that the respective arguments of the two occurrences of existT are
> equal?
> thanks for any help
> Jeremy
