- From: Conor McBride <conor AT strictlypositive.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Fwd: "Lean is like Coq but better"
- Date: Thu, 9 Jan 2020 00:41:09 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=conor AT strictlypositive.org; spf=None smtp.mailfrom=conor AT strictlypositive.org; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:6gAC2hV1M+H0MQrvgU5DW5oO+fvV8LGtZVwlr6E/grcLSJyIuqrYbBSHt8tkgFKBZ4jH8fUM07OQ7/m7HzZdsN3b7DgrS99lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUhrwOhBoKevrB4Xck9q41/yo+53Ufg5EmCexbal9IRmrowjdrNcajItmJ6o+1BfErWZDdvhLy29vOV+dhQv36N2q/J5k/SRQuvYh+NBFXK7nYak2TqFWASo/PWwt68LlqRfMTQ2U5nsBSWoWiQZHAxLE7B7hQJj8tDbxu/dn1ymbOc32Sq00WSin4qx2RhLklDsLOjgk+2zRl8d+jr9UoAi5qhJ/34Hab46aOudwcKPTY90VR2lPUMFKWixdG4O8apcDD+odMetaqYT2ulsArQG5BQmpHO7i1DhIhnnx3a0gzu8vFh3J0RE6H9IPrXvbssj+OaAOXuCyyqnIyi/DYuhN2Tfh8ojIcwwuoe2IXbNwacrRzlIvFwLZjlWRt4zqISmZ1uMXs2iU9udtU/+khWAgqwF0uDevx8Esh5HTiYIPxVHE9Dt5zJwyJd2iR052Z8OvHphItyyCKYd6X8EvT3tqtSok0LEKpJq2cDYQxJklyBPTc/+KfouS7h/nV+udOyl0iX14dL6lmhq/8katx+vhXceuyllKtDBKktzUu3ANyRPT7s+HR+N4/kemxDaPyxrf6uJZIUAyiKXUNZghwqUumZoJr0TMADX2lF/rg6CIbkkk++6o5Pr7Yrj+uJOQKo15hhv8P6gwgMCzHOA1PhYUU2WZ9umwzLjj8lf4QLVOgP02iK7ZsJXCKMsHoa65BQhV0pw45hakEzemytUYkmUbLFJBeBOHl4/pO0rPIPDkDPe/nUqjnC1sx/DcMb3tGo/NIWTbkLf9YbZ97FZRxxY0zdBG/p5bFrUBIO/oVULqr9zZDho5MxSuzOr9CdV90JkeWWOVDaODPqPSqwzA2uV6KO6VIYQRpTzVKv4/5veog2Vqt0UaePyC2p0QcjidFd58IkmUKS7nhdEGC08RohA/R/DumUWFSj9PZmi/GaUm6WdoW8qdEY7fS9X10/S61yChE8gOPzwUOhW3CX7tMr68dbIUcivIeJ16jiYFXqSlWpcmzhCytRH3jb19IbiMo3xKhdfYzNFwotbru1Q3/D1wAd6a1jvXHXpohGIDWzsnxKdkoFB81FrF1rJ30aQBSI5joshRWwJ/Dqbyiux3D9eoAFDEecqVDlW7RNmrByo8VMw82ZkCbhQlFg==
Ah, politics.
--not sent from my iPhone
> On 8 Jan 2020, at 23:09, Kevin Buzzard
> <kevin.m.buzzard AT gmail.com>
> wrote:
> Since I highlighted Differential Geometry in my previous note, let us look
> at an example that seems particularly tricky to formalize in our current
> proof-assistant world: the elliptization conjecture (commonly known as the
> Poincaré conjecture), which was solved by Perelman in 2003, over a span of
> three papers
> (https://arxiv.org/search/?query=grisha+perelman&searchtype=author&abstracts=show&order=-announced_date_first&size=50).
> Incidentally, Perelman was awarded a Fields Medal for his work.
> Perelman did not accept the Fields Medal (but he was offered it).
> Whilst I have no doubt that LEM and AC will be thoroughly embedded in the
> Perelman proof, I believe that this has nothing to do with the fact that
> the proof of the Poincaré conjecture "seems particularly tricky to
> formalise" (to those not in the area, let me say that this is a *gigantic*
> understatement). I believe that none of the systems currently even contain
> a *statement* of the Poincaré conjecture, although Lean is nearly there. I
> would love to be proved wrong about this (the belief that no system
> contains a statement! I know full well that no system contains a proof).
> The reason that none of the systems contain a statement is, I believe, due
> to the fact that mathematicians are not anywhere near as engaged with these
> systems as they could be, and hence things like the definition of a smooth
> manifold have only recently started to appear in these systems (Lean got a
> definition late last year). The reason that the systems don't contain a
> proof of Poincaré is that the proof when written out in full is thousands
> of pages long, no mathematician sees the need to write down a "roadmap"
> which would be suitable for computer scientists to formalise, and no
> mathematician sees the need to formalise the proof themselves, because our
> community has accepted it and hence we see no need to verify it in any
> formal way. It's just like FLT (which I know for sure uses LEM and AC, at
> least in all currently known proofs) -- I have said in the past that if you
> give me $100,000,000 I could hire a team to put in the many hundreds of
> person-years necessary to formalise the Wiles/Taylor proof (I was a PhD
> student of Taylor when it all blew up in the 90s and I read the Wiles and
> Taylor-Wiles proofs carefully) -- but this will never happen because no
> grant agency would spend that kind of money on a project which most number
> theorists believe to be utterly pointless (and believe you me, I have asked
> many number theorists what their opinion on a formalised proof would be).
> I'm sure that an expert in Ricci Flow could envisage formalising a proof of
> Poincaré with a similar sum of money. This will clearly never happen and we
> need another approach. The reason it happened with the odd order theorem
> was that mathematicians wrote a good roadmap (two essentially
> self-contained books, by Bender--Glauberman and Peterfalvi) which
> mathematically-inclined computer scientists could follow, and it probably
> helped that the odd order theorem was a statement whose proof (not just the
> statement, but the proof too) mostly involved finite objects and hence
> LEM/AC were not an issue (some parts of it use representation theory and
> hence the complex numbers, although the use was not "serious" enough to
> require non-constructive arguments). Whilst the statement of FLT is
> elementary, its proof involves many objects from analysis (modular forms,
> automorphic representations, harmonic analysis, the trace formula) and AC
> is embedded in the set-up of these theories (as well as in the "patching"
> argument in the algebra side of things, which relies on Kőnig's Lemma).
> What I believe LEM and AC have to do with this is that I believe that the
> fact that computer scientists still believe that these facts are still
> worth talking about puts off the 99% of mathematicians who assume one or
> both of these facts every day because we mathematicians are told from day
> one at university that they are both true and that modern "Fields Medal"
> mathematics is built upon them. The fact that LEM and AC are still some
> sort of an "issue" in formalisation -- still something worth talking about
> -- makes the subject feel to the Fields Medal crowd like it is living 100
> years in the past; for mathematicians, Hilbert beat Brouwer and that was
> the end of it. Sure there are some examples of constructivism in modern
> mathematics. Sure one can talk about doing mathematics in some large class
> of toposes or whatever, where constructivism becomes an issue. But what I
> really want to hammer home is that to the "mainstream maths" crowd this
> whole constructivism thing is weird niche mathematics, uncomfortable as
> this story sounds to many within the formal proof community. Mathematics
> undergraduates start using Lean and within an hour will hit some issue
> about equality not being decidable or trying to get an element from a
> non-empty type and finding that the `cases` tactic won't eliminate to type
> -- they ask what is wrong and I tell them to switch on decidability of all
> propositions and noncomputability of all functions and they'll be fine.
> Once they do this they can go back to treating mathematics the same way
> that every single one of their lecturers do. That is what mathematics has
> become, for better or worse, and the systems that do not embrace this point
> of view will have a hard time attracting "regular" mathematicians. On the
> other hand they might perhaps have an easier time attracting
> constructivists or computer programmers. One has to make choices here. As a
> "regular" mathematician myself this is why I promote Lean, but if it is
> true that Coq can also present itself as an environment where "regular"
> mathematicians can do *all* undergraduate level mathematics without being
> troubled by foundational issues then I see no reason why Coq cannot attempt
> to build up a community of "regular" maths users as well. Here's hoping. If
> any Coq users have mathematician friends who are looking for projects, then
> *stating* the Poincaré conjecture in Coq (and in particular formalising the
> definition of a real manifold) would be a great way of showing
> mathematicians that Coq is capable of talking about modern Fields Medal
> level mathematics. On the other hand, any talk of proving it in any of the
> theorem provers is a complete fantasy and will remain so until long after
> "regular" mathematicians have started to embrace this sort of technology
> (which still unfortunately shows no sign of happening; most mathematicians
> still have no understanding of the achievements of Gonthier, for example;
> they know that the four colour theorem was "proved using a computer" but
> most seem have no idea of the difference between Gonthier's work and that
> of Appel and Haken, both of which "used computers"...). I am doing my best
> to stomp on this ignorance but it is an uphill challenge because the
> systems still seem to offer very little to the working mathematician (who
> typically is far less worried about rigour (in the CS/"absolute" sense)
> than one might imagine; they are far more concerned with having their work
> accepted by the community, something which is slightly different).
> Kevin
> Coq’s math-comp is an axiom-free formalization.
> R.
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", (continued)
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", jonikelee AT gmail.com, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Mario Carneiro, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Jason Gross, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Sylvain Boulmé, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kevin Buzzard, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Florent Hivert, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Timothy Carstens, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Conor McBride, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Kinan Dak Albab, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", jonikelee AT gmail.com, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Théo Zimmermann, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Ramkumar Ramachandra, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Talia Ringer, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", BEGAY Pierre-leo, 01/08/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Frédéric Blanqui, 01/09/2020
- Re: [Coq-Club] Fwd: "Lean is like Coq but better", Vincent Semeria, 01/09/2020
