coq-club - Re: [Coq-Club] Fwd: "Lean is like Coq but better"
  • From: Conor McBride <conor AT strictlypositive.org>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Fwd: "Lean is like Coq but better"
  • Date: Thu, 9 Jan 2020 01:23:57 +0000
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=conor AT strictlypositive.org; spf=None smtp.mailfrom=conor AT strictlypositive.org; spf=None smtp.helo=postmaster AT mout.kundenserver.de
  • Ironport-phdr: 9a23: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
Ah, potilics.
-- Sent from my oPhine
> On 9 Jan 2020, at 00:50, Timothy Carstens
> <intoverflow AT gmail.com>
> wrote:
> https://twitter.com/congressfellows/status/1111721764336422913?s=21
> Guilty as charged 😉
> Sent from my iPhone
>> On Jan 8, 2020, at 4:41 PM, Conor McBride
>> wrote:
>> Ah, politics.
>> --not sent from my iPhone
>>> On 8 Jan 2020, at 23:09, Kevin Buzzard
>>> <kevin.m.buzzard AT gmail.com>
>>> wrote:
>>> Since I highlighted Differential Geometry in my previous note, let us
>>> look at an example that seems particularly tricky to formalize in our
>>> current proof-assistant world: the elliptization conjecture (commonly
>>> known as the Poincaré conjecture), which was solved by Perelman in 2003,
>>> over a span of three papers
>>> (https://arxiv.org/search/?query=grisha+perelman&searchtype=author&abstracts=show&order=-announced_date_first&size=50).
>>> Incidentally, Perelman was awarded a Fields Medal for his work.
>>> Perelman did not accept the Fields Medal (but he was offered it).
>>> Whilst I have no doubt that LEM and AC will be thoroughly embedded in the
>>> Perelman proof, I believe that this has nothing to do with the fact that
>>> the proof of the Poincaré conjecture "seems particularly tricky to
>>> formalise" (to those not in the area, let me say that this is a
>>> *gigantic* understatement). I believe that none of the systems currently
>>> even contain a *statement* of the Poincaré conjecture, although Lean is
>>> nearly there. I would love to be proved wrong about this (the belief that
>>> no system contains a statement! I know full well that no system contains
>>> a proof). The reason that none of the systems contain a statement is, I
>>> believe, due to the fact that mathematicians are not anywhere near as
>>> engaged with these systems as they could be, and hence things like the
>>> definition of a smooth manifold have only recently started to appear in
>>> these systems (Lean got a definition late last year). The reason that the
>>> systems don't contain a proof of Poincaré is that the proof when written
>>> out in full is thousands of pages long, no mathematician sees the need to
>>> write down a "roadmap" which would be suitable for computer scientists to
>>> formalise, and no mathematician sees the need to formalise the proof
>>> themselves, because our community has accepted it and hence we see no
>>> need to verify it in any formal way. It's just like FLT (which I know for
>>> sure uses LEM and AC, at least in all currently known proofs) -- I have
>>> said in the past that if you give me $100,000,000 I could hire a team to
>>> put in the many hundreds of person-years necessary to formalise the
>>> Wiles/Taylor proof (I was a PhD student of Taylor when it all blew up in
>>> the 90s and I read the Wiles and Taylor-Wiles proofs carefully) -- but
>>> this will never happen because no grant agency would spend that kind of
>>> money on a project which most number theorists believe to be utterly
>>> pointless (and believe you me, I have asked many number theorists what
>>> their opinion on a formalised proof would be). I'm sure that an expert in
>>> Ricci Flow could envisage formalising a proof of Poincaré with a similar
>>> sum of money. This will clearly never happen and we need another
>>> approach. The reason it happened with the odd order theorem was that
>>> mathematicians wrote a good roadmap (two essentially self-contained
>>> books, by Bender--Glauberman and Peterfalvi) which
>>> mathematically-inclined computer scientists could follow, and it probably
>>> helped that the odd order theorem was a statement whose proof (not just
>>> the statement, but the proof too) mostly involved finite objects and
>>> hence LEM/AC were not an issue (some parts of it use representation
>>> theory and hence the complex numbers, although the use was not "serious"
>>> enough to require non-constructive arguments). Whilst the statement of
>>> FLT is elementary, its proof involves many objects from analysis (modular
>>> forms, automorphic representations, harmonic analysis, the trace formula)
>>> and AC is embedded in the set-up of these theories (as well as in the
>>> "patching" argument in the algebra side of things, which relies on
>>> Kőnig's Lemma).
>>> What I believe LEM and AC have to do with this is that I believe that the
>>> fact that computer scientists still believe that these facts are still
>>> worth talking about puts off the 99% of mathematicians who assume one or
>>> both of these facts every day because we mathematicians are told from day
>>> one at university that they are both true and that modern "Fields Medal"
>>> mathematics is built upon them. The fact that LEM and AC are still some
>>> sort of an "issue" in formalisation -- still something worth talking
>>> about -- makes the subject feel to the Fields Medal crowd like it is
>>> living 100 years in the past; for mathematicians, Hilbert beat Brouwer
>>> and that was the end of it. Sure there are some examples of
>>> constructivism in modern mathematics. Sure one can talk about doing
>>> mathematics in some large class of toposes or whatever, where
>>> constructivism becomes an issue. But what I really want to hammer home is
>>> that to the "mainstream maths" crowd this whole constructivism thing is
>>> weird niche mathematics, uncomfortable as this story sounds to many
>>> within the formal proof community. Mathematics undergraduates start using
>>> Lean and within an hour will hit some issue about equality not being
>>> decidable or trying to get an element from a non-empty type and finding
>>> that the `cases` tactic won't eliminate to type -- they ask what is wrong
>>> and I tell them to switch on decidability of all propositions and
>>> noncomputability of all functions and they'll be fine. Once they do this
>>> they can go back to treating mathematics the same way that every single
>>> one of their lecturers do. That is what mathematics has become, for
>>> better or worse, and the systems that do not embrace this point of view
>>> will have a hard time attracting "regular" mathematicians. On the other
>>> hand they might perhaps have an easier time attracting constructivists or
>>> computer programmers. One has to make choices here. As a "regular"
>>> mathematician myself this is why I promote Lean, but if it is true that
>>> Coq can also present itself as an environment where "regular"
>>> mathematicians can do *all* undergraduate level mathematics without being
>>> troubled by foundational issues then I see no reason why Coq cannot
>>> attempt to build up a community of "regular" maths users as well. Here's
>>> hoping. If any Coq users have mathematician friends who are looking for
>>> projects, then *stating* the Poincaré conjecture in Coq (and in
>>> particular formalising the definition of a real manifold) would be a
>>> great way of showing mathematicians that Coq is capable of talking about
>>> modern Fields Medal level mathematics. On the other hand, any talk of
>>> proving it in any of the theorem provers is a complete fantasy and will
>>> remain so until long after "regular" mathematicians have started to
>>> embrace this sort of technology (which still unfortunately shows no sign
>>> of happening; most mathematicians still have no understanding of the
>>> achievements of Gonthier, for example; they know that the four colour
>>> theorem was "proved using a computer" but most seem have no idea of the
>>> difference between Gonthier's work and that of Appel and Haken, both of
>>> which "used computers"...). I am doing my best to stomp on this ignorance
>>> but it is an uphill challenge because the systems still seem to offer
>>> very little to the working mathematician (who typically is far less
>>> worried about rigour (in the CS/"absolute" sense) than one might imagine;
>>> they are far more concerned with having their work accepted by the
>>> community, something which is slightly different).
>>> Kevin
>>> Coq’s math-comp is an axiom-free formalization.
>>> R.
