- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] installing new version of coq
- Date: Tue, 14 Jan 2020 02:28:56 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=1UzK6iriO5z4kYLed88ifTdbx+Yrr3JxwzTNmjhGytg=; b=LtO1BQSe2RcXyHioW/6IMvuMt79jFLkfTT9rInK7QShxkOoRtRZ1zK110Dz5djisAkvN8HD1JzCNkdmwDqWjV4Drr5Ky3OT+S04TuDrmlZ4kudxNeueHMcqjTkDlc8cQf91NfO5mNeMo82Ek+nLmMXJOTKDNUYkb6CE8RwrxhOfl0XTqiY3nSa9MqgbtCjVeabVT+bBQgzmC96pynqvPfu37BbRxxiUouUb0/s21238w83dUUjtQuWQJZW+rJBDKAEAeQy1sAA1wnRTVIyEgP0F6iY5c0YuUsfNrKCLNABC3tfnwj2FmL/wG/rh8y6dzO12Bptx+ujBQJN8pf5sCdw==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=PeRen8KeoPBjYCqAJrsE8TbV4z6Bad325xEsZA3kIhGx+owHSsxlTzcziZSJFcH4NEsHZnss5kX1DMuQzjLfVhAUwGrT/vGxRsJnDiMwmfdBd8vub67xuA42Bq5ceRayVJ7vTEVjAFDtsWeo/R/HW1S8I2q+DKMLRlPIKvtpofPYNFZeVvyHjd9uCDyi5r0yT8SJxqodNCcQZB1zVubT0XskHffiT0ktskcAvDh9qBm6RXSkMOUN66j04zt7g/ecxWTKBa4HoZxbET74ugZMujbiZ6jT2OxwEezkiYHFEfWlO9XgcX+HXDHzCIGFrzseazLxd1vSJ7QQAEDxCKB3tg==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi,
I'm trying to do this, following instructions at the website
https://coq.inria.fr/opam-using.html
jeremy@cecs-042179:~$ opam pin add coq 8.10.2
[ERROR] Package coq has no version 8.10.2
then I try a separate root (instructions near the bottom of the page)
export OPAMROOT=~/opam-coq.8.10.2 # no dot
opam init -n --compiler=ocaml-base-compiler.4.02.3
this gave
Cannot find
/home/users/jeremy/opam-coq.8.10.2/compilers/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3.comp:
ocaml-base-compiler.4.02.3 is not a valid compiler name.
OK, maybe this is because I'm running opam version 1.2.2
so I use the command that I have noted as having used a year ago
opam init -n --comp 4.02.3 # for opam 1
this puts a lot of stuff in the directory ~/opam-coq.8.10.2 but then hangs,
jeremy@cecs-042179:~/coq$ opam init -n --comp 4.02.3
Checking for available remotes: rsync and local, git, mercurial, darcs.
Perfect!
=-=- Fetching repository information
[default] synchronized from https://opam.ocaml.org
[NOTE] The repository 'default' will be *permanently* redirected to
https://opam.ocaml.org/1.2.2 (opam-version < "2.0~")
Processing: [default: http]
Obviously it hasn't done all it needs to do, because
Are there instructions available for using opam version 1?
(I tried installing opam, using instructions at
https://opam.ocaml.org/doc/Install.html using the instruction
sh <(curl -sL https://raw.githubusercontent.com/ocaml/opam/master/shell
/install.sh)
but (even when specifying to install in my own directory) required root
access)
Thanks,
Jeremy
- [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jason -Zhong Sheng- Hu, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Donald Leung, 01/14/2020
