- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] installing new version of coq
- Date: Tue, 14 Jan 2020 03:53:45 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=7MYXLH+RqPnr3z7nUhnsiyF33pEhIARR8J0nhvox1Uc=; b=QUWdnnOIfeAL5Qw9c/gBLS6VOhOWAHuvPBzk7A5aIYaSbrF2zZ3f5LFjXTWWMYbYLQOkPQK5bVT0EaJX9Wiokncn7k7U39RW1uA7YoFYrjLJ9CvG3epfXIAHbBz6q3kcmaOx7EE6v5shLyQkO6fkRBjdPfUEpCnOK1N6HetT/Y1enk2G3QZFOsdOh06fsq9HmGbideLGLDC+L/JzFWAJ/Sw6fGjJvyoedGM2dpncmpwj2N4s9t/jLzbKkORwgULx2uB6m3DvptvIeAccM3ZEEb+PlU5Brjn4W+FS/z1UTQGPotzKGBMB+BE7bKjnMHEHX7Tc0HVBSMzasyl0gFP2HQ==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=EfWxCV04RCZYxFxjz/uCZKtrYHXJ+n4fMwe8v2Dh8LP4UcakMayoHL6Gk2/4hs+zjKyUUdTM5NwiEQieuhjB7wVT5Jw+prpF3TvQCyM8MZ1FXmv5OaATkAemZf5z97S8YJw8JtoS/CRviGF0Mf7TYco9QCwGIy9X4PCcqsj9a1S0Txpp/RubUybMhbBL4MsKoqlQrwTzjQ0QGDTZ+zA4QTivSJ++OQ/Dcl8ZsR93RmMIQfAJBAfQGTNDzV87NU1vgbl0n21kN4DBZUzpeqBPz4nFtpAdsnz5xcIC1AucFzLzZkx+MnLLj6o8ejbLMq+5qI3O9Qf9BoUBGU8fxvpBEA==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi, thanks,
I found how the opam site gives the option to simply download the
executable, so I did that, so now using opam 2.0.5
and doing opam init -n --compiler=ocaml-base-compiler.4.02.3
I still get that it hangs at the point
Processing: [default: http]
Thanks
Jeremy
On 14/1/20 1:38 pm, Jason -Zhong Sheng- Hu wrote:
> I don't send to the whole coqclub because I am not certain about it.
> however, I kind of remember someone mentioned that later coq versions
> will no longer support opam 1. all repos for opam 1 will be put into a
> frozen state, and they will eventually be decommissioned. you might want
> to wait for a more official person for a confirmation.
> *Thanks,*
> *Jason Hu*
> *https://hustmphrrr.github.io/*
> *From:*
> coq-club-request AT inria.fr
> <coq-club-request AT inria.fr>
> on behalf
> of Jeremy Dawson
> <Jeremy.Dawson AT anu.edu.au>
> *Sent:* January 13, 2020 9:28 PM
> *To:*
> *Subject:* [Coq-Club] installing new version of coq
> Hi,
> I'm trying to do this, following instructions at the website
> https://coq.inria.fr/opam-using.html
> jeremy@cecs-042179:~$ opam pin add coq 8.10.2
> [ERROR] Package coq has no version 8.10.2
> then I try a separate root (instructions near the bottom of the page)
> export OPAMROOT=~/opam-coq.8.10.2 # no dot
> this gave
> Cannot find
> /home/users/jeremy/opam-coq.8.10.2/compilers/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3.comp:
> ocaml-base-compiler.4.02.3 is not a valid compiler name.
> OK, maybe this is because I'm running opam version 1.2.2
> so I use the command that I have noted as having used a year ago
> opam init -n --comp 4.02.3 # for opam 1
> this puts a lot of stuff in the directory ~/opam-coq.8.10.2 but then hangs,
> jeremy@cecs-042179:~/coq$ opam init -n --comp 4.02.3
> Checking for available remotes: rsync and local, git, mercurial, darcs.
> Perfect!
> =-=- Fetching repository information
> [default] synchronized from https://opam.ocaml.org
> [NOTE] The repository 'default' will be *permanently* redirected to
> https://opam.ocaml.org/1.2.2 (opam-version < "2.0~")
> Obviously it hasn't done all it needs to do, because
> Are there instructions available for using opam version 1?
> (I tried installing opam, using instructions at
> https://opam.ocaml.org/doc/Install.html using the instruction
> sh <(curl -sL https://raw.githubusercontent.com/ocaml/opam/master/shell
> /install.sh)
> but (even when specifying to install in my own directory) required root
> access)
> Thanks,
> Jeremy
- [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jason -Zhong Sheng- Hu, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Donald Leung, 01/14/2020
