- From: Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] installing new version of coq
- Date: Tue, 14 Jan 2020 02:41:03 +0000
- Accept-language: en-CA, en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=none; dmarc=none; dkim=none; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=tAKWfTX7C7dW9EeV7XvNC7FEjbHp9xWx1JB2VYiAyFU=; b=VIL8eTi3ykKFSy2GZ0tHxbrGkFq+S9OZVGPD/2fKVhvus0dbX53jzwvLfOWBygXKt8OEORG/3RNQig1TxG39c/vVyIP3KZ28/1l+vDIZMGgXTGDXsZPIGgbhtQ2xPdio8MsnRyyCGPHI0l9/OsJuxx/0D8ZV15mgoB9dZUXcWd6vEO9uGQl5v5SLUHMJYNzd21Fvh//lTVhpVDKIZTwqr6JLJmt/wLDfJKsDh/q83JQ4nb1oGo3kdbTUF0XLZCQMOL5n/rquAoZfYbaIozNCx20o/zO+sH4quol1H4/knlGQjMQGVmnlrSCuoPRgochw62QKcKv99b9XC1CvTlyFxg==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=OKQytHprYhR8aZwHWBCy95m0uYfS5L7LT1XYQEZvMLtGKejQqGp4rQ3LflOaUrB6tTSVpYw9tsAcoxhXrZPTeEKYXneyOL2Zq8fyQTaz8ilxedci0F5eWYxfDkmLN5krhdOeJTCyHK+ew6e5KBqMZjrWKBpC3O9mjr9IVfP3qXPhweCif26NpUjQ78gQjmOp2Z0vhNgmiBNZ1RYVIcvRL5DzYL7hL8hahYEoe8M14m5WTJ39fmo0lnYajJAvhhcND2rbh61yXZvOqaET+up4KiftRXNeqnkKQ+djoA0Le+9HNtmyxkViynL/eWA+UYOnGsmCV8pVSCPART6z2kbqyQ==
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=fdhzs2010 AT hotmail.com; spf=Pass smtp.mailfrom=fdhzs2010 AT hotmail.com; spf=Pass smtp.helo=postmaster AT NAM10-BN7-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
ok I actually sent it to coqclub... fat fingers...
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Jason -Zhong Sheng- Hu <fdhzs2010 AT hotmail.com>
Sent: January 13, 2020 9:38 PM
To: coq-club AT inria.fr <coq-club AT inria.fr>
I don't send to the whole coqclub because I am not certain about it. however, I kind of remember someone mentioned that later coq versions will no longer support opam 1. all repos for opam 1 will be put into a frozen state, and they will eventually be decommissioned.
you might want to wait for a more official person for a confirmation.
From: coq-club-request AT inria.fr <coq-club-request AT inria.fr> on behalf of Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
Sent: January 13, 2020 9:28 PM
Subject: [Coq-Club] installing new version of coq
Hi,
I'm trying to do this, following instructions at the website
https://coq.inria.fr/opam-using.html
jeremy@cecs-042179:~$ opam pin add coq 8.10.2
[ERROR] Package coq has no version 8.10.2
then I try a separate root (instructions near the bottom of the page)
export OPAMROOT=~/opam-coq.8.10.2 # no dot
opam init -n --compiler=ocaml-base-compiler.4.02.3
this gave
Cannot find
/home/users/jeremy/opam-coq.8.10.2/compilers/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3.comp:
ocaml-base-compiler.4.02.3 is not a valid compiler name.
OK, maybe this is because I'm running opam version 1.2.2
so I use the command that I have noted as having used a year ago
opam init -n --comp 4.02.3 # for opam 1
this puts a lot of stuff in the directory ~/opam-coq.8.10.2 but then hangs,
jeremy@cecs-042179:~/coq$ opam init -n --comp 4.02.3
Checking for available remotes: rsync and local, git, mercurial, darcs.
Perfect!
=-=- Fetching repository information
[default] synchronized from https://opam.ocaml.org
[NOTE] The repository 'default' will be *permanently* redirected to
https://opam.ocaml.org/1.2.2 (opam-version < "2.0~")
Processing: [default: http]
Obviously it hasn't done all it needs to do, because
Are there instructions available for using opam version 1?
(I tried installing opam, using instructions at
https://opam.ocaml.org/doc/Install.html using the instruction
sh <(curl -sL https://raw.githubusercontent.com/ocaml/opam/master/shell
/install.sh)
but (even when specifying to install in my own directory) required root
access)
Thanks,
Jeremy
- [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jason -Zhong Sheng- Hu, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Donald Leung, 01/14/2020
