- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] installing new version of coq
- Date: Tue, 14 Jan 2020 12:29:24 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=gO1tWseJZn/gI9ANBxWr67Kizz0JDjbI7JX5fBzx1t4=; b=g+TTSq75bCU5hYCCuCq/sCbrFE3oigd2dcquX4BC7qCbmkRcURsO+OutgXGX8q1lXCxXGgYsRZRd68VUqCbegsVtXwPYhET4GQTxhjAf3WH9q1Vq4S3KZp3f3GPH7XRj2y4UjQ2wY6vlZTMi/zFtyL0xUrI2VuZd6MSALS6GZeTCS5ToUX1nAtiXQBFJyPoJQp5KxZeq2YqP3X95ox5LAVYCuMoeVHKpbquDBWcI5JAqpWvpzLQZ0MgLhs9ZsGH+h1JEVqnOAcrmdzRF+1hy2QGHwzHR7vCdQ6PMmXABrto1edVMsQ/YQAoCCE76C1/lJhVo0KcDNiyA0Mbkf9M61g==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=ORiDjv6q6r7rMXuSN7Khk1G33coKCh1vxIPAx/llkBWw2O4xPUpi6AQQoH5p9PwdnjeMuCHJTqMovv1uZKOMDWyZzv0YgBC7x6Np0RKlVIs04O0spc9+uvax4QIP2jH82oebT8bJtCNSA2QmUva3f7pgUGtdDsQ8c8X8Cy8SwWhOINqWpPYAk+txUVl43yJ6MOokMpJkoWnhdGnI41Ye4tpYHKhOVOf8ZZToRaQowKHLSQ37XyLpoyXpE0Axav47823qcA3Djz98OPY6qW8P1vtZ6vMLkUsKe2iA1US3AHnCxZ8OHq6RdepMpRw4vfMPTQCpmLDsnl059D5m1QQO+w==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-SY3-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23:M7qKGBf1jCr3xUcvu0Rwl4WqlGMj4u6mDksu8pMizoh2WeGdxc26ZhSN2/xhgRfzUJnB7Loc0qyK6vymATRLu87J8ChbNsAVDFld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbdgMutyu+95YDYbRlWizqhe7NyKwi9oRnMusUMjoZuN6k8xgHVrndUdOha239kLk+Xkxrg+8u85pFu/zletv4768JMTaD2dLkkQLJFCzgrL3o779DxuxnZSguP6HocUmEInRdNHgPI8hL0UIrvvyXjruZy1zWUMsPwTbAvRDSt9LxrRwPyiCcGLDE27mfagdFtga1BoRKhoxt/w5PIYIyQKfFzcL/Rcc8cSGFcWclfSjFBApikb4QRE+UBIehWr474p1QUrBu+AxSnCOfgxzJMg3P727Ax3eY8HgHcxAEuH8wAvmnIrNv7N6kSX+K6zKjUwjvMYPxbwiv955PSfxw9vf2AQbB9fMzMwkcvDQPFiVCQpJThMTyLzOQCrW2b7up9XuyhkWEmpRpxoj+pxswxjYTHgpwaykra+iV8wIc5P9O2R1R1YN6/F5tQsTqXOJFwQsM/WW1npjs1yqActZGhYSgH0ZIqzAPRZfyAdoiH+BPjVOCJLDd/mH1qYre/hxKo/Uin0O38WdG40FdMripfk9nDrGoB1xLJ6sSfRft9/1uh2TaS1w/I8O1EIEc0mbLUK54g3r4wlocTvl/eHi/thkr2lrOZdkIi+ui09evnZKnmqoWAOI9zjwHzNLkllM+nAekgPQUCQ3KX9fmg2LDh50H1XbtHg/8snqXErZzXJtwXq6G9DgNPz4ou7xayAy273NkWnnQLNlBIdRSahIbzIV7OOur3DfKnjlSsjjhrw/fGM6X9D5rDM3bPjKrtca9g5UFexgc/1Ndf6IlKBb0bJ/LzR1Pxu8ffDh8kNQy73vzrCM1n1oMZRWKAHLOWML/TsV+P4OIjOe6MZJIJuDb5LPgl4P3ugWUlll8aeKmlxZoXaHamEfR6O0iUbmbgjs0cHWsWvAcyVvHmhVOAXDJJenq+QqEx6ik+CI28DIfDQo6tgKaG3Ce+BpBYYn5JCkqSHnftd4SIQfkCZzicI896lTwEU6OsRJUn1RGzrgP11adoLvfO9iICqJLvzMJ16PHLlREu6Tx0CNyQ3H2KT2Fth28HWzs23L1krkFm0VeC0a14g+RCGtBJ5vNJVB06NZ/GwOBgBdDyQFGJQtDcAl2hW5CtBSw7ZtM32d4HJUhnUZ32hRfamiGuHrU9lrqRBZVy/LiKjFbrIMMo6Xvc2awwx3UvXdBIMyXypKNl+g3CQaLAjF6ekY6jc7la0SLQsm6emznd9HpEWRJ9BP2WFUsUYVHb+Iiovx6Qf/qVEb0idzB554uCJ69NNoK7pGh9HK6mA+WFJmW7liG3GAqCwa6KYMzyYWIB0S7BCU8C1QcO4XKBMgt4DSCk8TuHUG5eUGn3akapytFQ7WuhRxZunQiMcgts26fz8wNH3aXNGcNW5aoNvWIakxsxGV+829zMDN/Z/VhoergabN8gpl5ahzvU
Hi Donald,
Probably around an hour. Might have been a bit less.
Using OCaml 4.02.3 because it's what I get by doing
apt-get install ocaml
Cheers,
Jeremy
On 14/1/20 5:09 pm, Donald Leung wrote:
> Hi Jeremy,
> Just out of interest, how long did you wait for the `opam init` command?
> Also note that Coq 8.10.2 can only be compiled with OCaml >= 4.05.0 so you
> would not be able to install Coq 8.10.2 even if your OCaml 4.02.3
> installation were successful. Any reason why you would need to use OCaml
> 4.02.3 in particular?
> Cheers,
> Donald
>> Jeremy Dawson
>> <Jeremy.Dawson AT anu.edu.au>於2020年1月14日
>> 11:53寫道:
>> Hi, thanks,
>> I found how the opam site gives the option to simply download the
>> executable, so I did that, so now using opam 2.0.5
>> and doing opam init -n --compiler=ocaml-base-compiler.4.02.3
>> I still get that it hangs at the point
>> Processing: [default: http]
>> Thanks
>> Jeremy
>> On 14/1/20 1:38 pm, Jason -Zhong Sheng- Hu wrote:
>>> I don't send to the whole coqclub because I am not certain about it.
>>> however, I kind of remember someone mentioned that later coq versions
>>> will no longer support opam 1. all repos for opam 1 will be put into a
>>> frozen state, and they will eventually be decommissioned. you might want
>>> to wait for a more official person for a confirmation.
>>> *Thanks,*
>>> *Jason Hu*
>>> *https://hustmphrrr.github.io/*
>>> *From:*
>>> coq-club-request AT inria.fr
>>> <coq-club-request AT inria.fr>
>>> on behalf
>>> of Jeremy Dawson
>>> *Sent:* January 13, 2020 9:28 PM
>>> *To:*
>>> *Subject:* [Coq-Club] installing new version of coq
>>> Hi,
>>> I'm trying to do this, following instructions at the website
>>> https://coq.inria.fr/opam-using.html
>>> jeremy@cecs-042179:~$ opam pin add coq 8.10.2
>>> [ERROR] Package coq has no version 8.10.2
>>> then I try a separate root (instructions near the bottom of the page)
>>> export OPAMROOT=~/opam-coq.8.10.2 # no dot
>>> this gave
>>> Cannot find
>>> /home/users/jeremy/opam-coq.8.10.2/compilers/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3/ocaml-base-compiler.4.02.3.comp:
>>> ocaml-base-compiler.4.02.3 is not a valid compiler name.
>>> OK, maybe this is because I'm running opam version 1.2.2
>>> so I use the command that I have noted as having used a year ago
>>> opam init -n --comp 4.02.3 # for opam 1
>>> this puts a lot of stuff in the directory ~/opam-coq.8.10.2 but then
>>> hangs,
>>> jeremy@cecs-042179:~/coq$ opam init -n --comp 4.02.3
>>> Checking for available remotes: rsync and local, git, mercurial, darcs.
>>> Perfect!
>>> =-=- Fetching repository information
>>> [default] synchronized from https://opam.ocaml.org
>>> [NOTE] The repository 'default' will be *permanently* redirected to
>>> https://opam.ocaml.org/1.2.2 (opam-version < "2.0~")
>>> Obviously it hasn't done all it needs to do, because
>>> Are there instructions available for using opam version 1?
>>> (I tried installing opam, using instructions at
>>> https://opam.ocaml.org/doc/Install.html using the instruction
>>> sh <(curl -sL https://raw.githubusercontent.com/ocaml/opam/master/shell
>>> /install.sh)
>>> but (even when specifying to install in my own directory) required root
>>> access)
>>> Thanks,
>>> Jeremy
- [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jason -Zhong Sheng- Hu, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Jeremy Dawson, 01/14/2020
- Re: [Coq-Club] installing new version of coq, Donald Leung, 01/14/2020
