coq-club - Re: [Coq-Club] how to require file in subdirectory
  • From: Gaëtan Gilbert <gaetan.gilbert AT skyskimmer.net>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] how to require file in subdirectory
  • Date: Wed, 5 Feb 2020 10:38:59 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=gaetan.gilbert AT skyskimmer.net; spf=Pass smtp.mailfrom=gaetan.gilbert AT skyskimmer.net; spf=None smtp.helo=postmaster AT relay5-d.mail.gandi.net
  • Ironport-phdr: 9a23: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
No, ``` (optionally suffixed by a language) is markdown syntax to indicate a code block (verbatim in latex terms)
Gaëtan Gilbert
On 05/02/2020 10:11, Jeremy Dawson wrote:
Hi Donald,
I now take it that ``` is supposed to appear literally in the
_CoqProject file, is that correct?
but typing
```bash
$ coq_makefile -f _CoqProject -o Makefile
literally into the command line seems to do nothing except do weird
things to my terminal window.
Could you explain further?
Thanks
Jeremy
PS - it seems really weird that to Load or Require Import a file from a
subdirectory requires remaking everything - is that really correct?
On 5/2/20 7:59 pm, Donald Leung wrote:
Dear Jeremy,
Try adding a `_CoqProject` file in the root directory of your Coq development
with the following contents:
-Q ./tttt/TTT/ tttt.TTT
./tttt/TTT/ssss.v
./tttt/TTT/file2.v
./tttt/TTT/file3.v
./tttt/TTT/filen.v
where file2.v, file3.v, …, filen.v are the other vernacular files in your Coq
development that you would also like to compile. Then run:
```bash
in your command line and select `Compile > Make` in your CoqIDE (or similar).
Provided the build is successful, you should then be able to step through the
line:
```coq
From tttt.TTT Require Import ssss.
in your CoqIDE (or similar) without any issues.
Yours sincerely,
Donald
Jeremy Dawson
<Jeremy.Dawson AT anu.edu.au>於2020年2月5日
15:00寫道:
Hi,
I'm trying to run a command which I was guessing should be
but I get the error
Cannot find a physical path bound to logical path matching suffix
<> and prefix tttt.TTT.
What does this mean?
How do I use a file tttt/TTT/ssss.vo?
The documentation contains
Variant From dirpath Require qualid
(in
https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#coq:cmdv.from-require)
What should a dirpath look like, and where is it to be found in the
documentation? (Some of these syntax constructs seem to be defined in
https://coq.inria.fr/distrib/current/refman/language/gallina-specification-language.html
but dirpath isn't - and none of them seem to be in the index)
Thanks
Jeremy
