- To: Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] how to require file in subdirectory
- Date: Thu, 6 Feb 2020 15:22:20 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=theo.zimmi AT gmail.com; spf=Pass smtp.mailfrom=theo.zimmi AT gmail.com; spf=None smtp.helo=postmaster AT mail-ua1-f42.google.com
- Ironport-phdr: 9a23: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
Yes, CoqIDE does support _CoqProject as well. I don't know why I
didn't include it in my list.
The _CoqProject format is documented here:
https://coq.inria.fr/refman/practical-tools/utilities.html#building-a-coq-project-with-coq-makefile
Théo
Le jeu. 6 févr. 2020 à 15:09, Jeremy Dawson
a écrit :
> Hi Theo,
> Thanks. How about coqide (it's been mentioned to me previously, but
> apparently it has the same options as coqtop, and it's documentation
> within the reference manual doesn't seem to mention the _CoqProject file).
> And so far, I'm pretty much on my own regarding this _CoqProject file -
> I can't find any documentation about how to set it up, when it is used,
> and what it does. Is there any such documentation?
> Thanks for the tip about echo $?
> Jeremy Dawson
> On 6/2/20 7:48 pm, Théo Zimmermann wrote:
> > Hi Jeremy,
> > The _CoqProject file is supported by editors with Coq support (Emacs
> > with PG, VsCode with VsCoq, etc.) and by coq_makefile. You are never
> > supposed to run coqc nor coqtop directly by yourself. In particular,
> > today coqtop is considered as just a debugging tool. If you do insist on
> > using it standalone, you are pretty much on your own (and you'll have to
> > figure out the flags you need to give it).
> > Regarding how to make sure that a process such as make finished without
> > error, you can print the exit code: echo $?
> > Cheers,
> > Théo
> > Le jeu. 6 févr. 2020 à 01:59, Jeremy Dawson
> > <mailto:Jeremy.Dawson AT anu.edu.au>>
> > a écrit :
> > Well, make with the existing Makefile seems to make everything OK, I
> > suppose there is no way to tell for sure, but there is no apparent
> > error.
> > With a new _CoqProject file there are all sorts of errors, presumably
> > because the existing _CoqProject file has useful stuff in it.
> > But in any event, running coq (to be exact, coqtop) does not access
> > either _CoqProject or Makefile, so I can't see how your solution
> > should
> > work. (Anyway, it doesn't). Maybe I'm missing something here. Can
> > you
> > explain how your solution should work.
> > Or can anyone refer me to where the documentation on this issue is,
> > if any?
> > Thanks
> > Jeremy
> > On 5/2/20 7:59 pm, Donald Leung wrote:
> > > Dear Jeremy,
> > > Try adding a `_CoqProject` file in the root directory of your Coq
> > development with the following contents:
> > > -Q ./tttt/TTT/ tttt.TTT
> > > ./tttt/TTT/ssss.v
> > > ./tttt/TTT/file2.v
> > > ./tttt/TTT/file3.v
> > > ./tttt/TTT/filen.v
> > > where file2.v, file3.v, …, filen.v are the other vernacular files
> > in your Coq development that you would also like to compile. Then run:
> > > ```bash
> > > $ coq_makefile -f _CoqProject -o Makefile
> > > in your command line and select `Compile > Make` in your CoqIDE
> > (or similar). Provided the build is successful, you should then be
> > able to step through the line:
> > > ```coq
> > > From tttt.TTT Require Import ssss.
> > > in your CoqIDE (or similar) without any issues.
> > > Yours sincerely,
> > > Donald
> > >> Jeremy Dawson
> > <mailto:Jeremy.Dawson AT anu.edu.au>>於2020年2月5日
> > 15:00寫道:
> > >> Hi,
> > >> I'm trying to run a command which I was guessing should be
> > >> but I get the error
> > >> Cannot find a physical path bound to logical path matching suffix
> > >> <> and prefix tttt.TTT.
> > >> What does this mean?
> > >> How do I use a file tttt/TTT/ssss.vo?
> > >> The documentation contains
> > >> Variant From dirpath Require qualid
> > >> (in
> > https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#coq:cmdv.from-require)
> > >> What should a dirpath look like, and where is it to be found in
> > the
> > >> documentation? (Some of these syntax constructs seem to be
> > defined in
> > https://coq.inria.fr/distrib/current/refman/language/gallina-specification-language.html
> > >> but dirpath isn't - and none of them seem to be in the index)
> > >> Thanks
> > >> Jeremy
- [Coq-Club] how to require file in subdirectory, Jeremy Dawson, 02/05/2020
- Re: [Coq-Club] how to require file in subdirectory, Donald Leung, 02/05/2020
- Re: [Coq-Club] how to require file in subdirectory, Jeremy Dawson, 02/05/2020
- Re: [Coq-Club] how to require file in subdirectory, Gaëtan Gilbert, 02/05/2020
- Re: [Coq-Club] how to require file in subdirectory, Jeremy Dawson, 02/06/2020
- Re: [Coq-Club] how to require file in subdirectory, Théo Zimmermann, 02/06/2020
- Re: [Coq-Club] how to require file in subdirectory, Ralf Jung, 02/06/2020
- Re: [Coq-Club] how to require file in subdirectory, Pierre Courtieu, 02/06/2020
- Re: [Coq-Club] how to require file in subdirectory, Jeremy Dawson, 02/07/2020
