coq-club - Re: [Coq-Club] how to require file in subdirectory
  • To: coq-club AT inria.fr, Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
  • Subject: Re: [Coq-Club] how to require file in subdirectory
  • Date: Thu, 6 Feb 2020 15:23:00 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
  • Autocrypt: addr=post AT ralfj.de; prefer-encrypt=mutual; keydata= mQINBFNAJO0BEAC8Rr0Q4AC4X2l0a09GQSCIib9Htj5N+21vHZ3EYAG0gQ1QAOX3QHrtu26D n1nvpQ8hhsp86YHK7pD4IXPesdJjbEmF0glidhPMJJ6pq8vQvMywg7sDX1XOhDKP/ejSOXmS 6G5cgMGrYad2ys5eB9Q18Bj310zwZTeDTPwxM5GqIg7/cX66LCITZOi88ZNOJgysuCLioCU2 j4bBgJbrmClwi5IipfclsWZwACmgEGHc/STcEyrTAolLdtW3L3Ghaz4gZRGqV606plWewdFI qkVgJpDOWou9yIDoeSpKc2sHY2PL3xozGfftBj+gJkwsBovHzxZUbU4oTETVGpPmyExiIL79 ickHwqdDBZV9PzyHioK7AhMQys0K1yHn0x/pTMWrOFLQxJ5tPNWstTXcAYIbJMJaAKTmtN0d 4sj4/U8Q9S2D+ItFEyZOUyL480xHzX4STTF1ibiDm9tDvpZEsFHwbb7yA7nfXg4F82FIVI1R 16n3IqdKROFsToE0MM2FTyApFIpVx2KGdbtRsCOty07TWrenRDMMCj2YJcBkCOy2u1loULEm /n8cyiyhxEE4EkzIsChngB3+wgfQQCLAUEjbwUyWztvvo8EzvmZDVDKGBPHhQtx8EOL/Qpa0 zVCU5eJ+JeSc2rMRhFP1+tL9GWu7Gxmfb8gv0yBhtJIXTcT5awARAQABtBlSYWxmIEp1bmcg PHBvc3RAcmFsZmouZGU+iQJTBBMBCgA9AhsDBAsJCAcFFQoJCAsFFgIDAQACHgECF4AWIQS9 P1r22V13xIqFr2gMsY5SGyTz/wUCXS4PxwUJC88eWgAKCRAMsY5SGyTz//0dD/9IBOAun+dM vBZUU7U0JsTyv5WN7Xp9JS7ztxSUrfnFChHy1H6OP0xvOL7fCAoa6pyi8P72PzsZ6E/piAka JsK3dk0gMFHn0+u7VrhbxXTh1kVEBRwCmNv73G3h33JfH7/fet+RKAsWC+APmKtmkQl7yJhr 2USxiJ693sMg7jT7ksuCjz18xnPBpWTZDa5zotQw094fvVyOShDSXwbYIKrhrxJAN8t8pDiP D6oP+zWOqYe5rOy62W+qv6FntY810oxKTAFNsXgST8+AY9jvN/1wb38C0ggHNgZOZRTjYYGw X/4/t920nYUDfIKFRlHtjryEAC9YmF0sBRLppZmaaM9aWdu9QiBFykdrUJcGkyUZrsOv5gOm jmRhWni3FLKecvXyR/4VeDHOAcV+m6Dm9P96iSO/lRe7r1U0t944NgmksAiChryi8ChkuEm7 OGAuwnTpPD6ulwUBfVvLj3kvyZraTNT66XYpLEVjUDOQVsh73q5xAJZhhj13tMqYHldmmaem /Ve2kqt11uJCLjMs6CPOTzZta7wYGvXcyf7Za/4Br0fFqBW6wXMH6k29n8jUvcqrWy5q88eA xkzHEyUuuHxuOoC4EvHs3pTsKBMywMuxrN7TDZ3vjTVpLrIrL7CGeXQbCznNVrbQdq4c2G0S DAptG/LDH+nwWkVNz/BGBpPBeLkCDQRTQCTtARAA15KifZIQmK2uE3SH3kkLRRXEvpkrH2rx plaJ7hQuddObXJuFxHCCLTcl5SH6creVacN5C6uqmk+orMyl6ywgmAzrXoLC+05McIAqaljb cK/2crI8ryyzXb1rhAxkLAgp5WP9mogi7BmPL/6gRY90UWYLVIaEx6/VDKa6z5zHV36iHEsu a83qN+RBO4Yio0CwsEqPUrNhCahHgmRMf19BsNMFZsCAZK5oA1l+hLn+OsBduC/OFdgyusD7 KTcF7XpMj0XZgsgDT/W4uYHTJa97UIIvmYjGQulycGRAqEuM6hQys6IFgvqIWsxghu3NDKgX jDJBDMamZS4/tzOPDKVoj1EuaxFbAW1LJLp7Pg7LQq/keFxUR7KwiG87m2ZngsSRYWIqySpQ fzCH+1OKjowFmYMwrBOap1gQeM0W9mpitbQ7RRWvA1mDAAF0ZfcTfuqcdwSy9SCzCZj8wSq/ w61eB/I356AtEcRJOmCmVAGxOrPPTFJdJiDVapVNAxa26DU0hLxd4Yqd+sldIwrhaCdEquwU /VDyARNHXf5rf6YXccpZ73C1TaANFTZwz7wQZ4Oy8CfPFhwe9X7wTQnTfFTwvqKxtt5YCo+T kVH3QVTVVMO8Xp72XvMks8sg7xQpl8KnWARSaAizuptcDfdO4WWli8VgY78RTqFe8nn9S5No 3jcAEQEAAYkCPAQYAQoAJgIbDBYhBL0/WvbZXXfEioWvaAyxjlIbJPP/BQJdLg/OBQkLzx5h AAoJEAyxjlIbJPP/NHMQALfxGCusePGAN0AkNCsLf65qlOcE3ohDVGj0ItaltpuSfTQW9Ea+ CZWLifvdq8K6Myxw87GwvwEU34JUxJQBewN58rIAyhiDB+SDbyoGFUks1lITUheqpGW7TDYA Q8FoQeDRSknRurUoUGrLjOZ8lUTdrtlpI4fDXk+qq2I63hbdbTcdq5KakkBjSy/HKvC6ZtCZ ifx4gB1zcb6ctZQ/IcDoY8/nUqOqfiZ7bLUuf8qRvPzP9CNW33jePKifXcjMDhm2+dG3/KEe xK9qfZchunRsVUz/yDUJ7VFvPg6UADADLOxEViAzsJ6IJbJup36HLx+TIsjHEa2pXTH6B6SX 6pqNi4AlDILCnXgzXBZwmMyGDrQXgqIAyCilmiPRllcjI0n1LuaA5Ca8Ri8MPDtu/UV2f1NJ FTrGizx8/U5o7n/SWqfOwqw9RaZtgG/NGL0uW73hcZXLG3haP8MBmFJx/CGrfz1Ax871rFMr 2mvqTBvQnjeMo57pHUAQQaHlLVr7FdzAOA18keUy8ycUUqvheHb8QmY314rDjpU2BI64Yxau LVCVgrGsZLYVkwYXqaVgWLFox+5KGUQitraA9BPJGKSiDZ7g2tDRpDPRTS+CWzjELHGnv82m /REYVvFrtj9lpKUi/OCnnb1IMx59YaT+aJIPvDVtKUoq8QrU+o+cZ1p3
  • Ironport-phdr: 9a23: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
  • Openpgp: preference=signencrypt
Hi Jeremy,
if it helps to see an example, you can check out how we are using _CoqProject
in
Iris:
https://gitlab.mpi-sws.org/iris/iris/blob/master/_CoqProject
In particular, note the "-Q theories iris". This means that the folder
"theories" (relative to the _CoqProject file) becomes the Coq logical path
"iris".
With this, you can just open any .v file in theories/* in CoqIDE, and all the
paths just work. No need to pass any flags anywhere else. (Well, this is
what
happens with ProofGeneral, but I think CoqIDE is the same.) And as already
mentioned in this thread, the coq_makefile invocation is
coq_makefile -f _CoqProject -o Makefile
After that, running "make" will build all files listed in _CoqProject.
(Notice that if you have a typo in that file list, really weird stuff can
happen
-- that's a known bug: https://github.com/coq/coq/issues/9319.)
Kind regards,
Ralf
On 06.02.20 15:09, Jeremy Dawson wrote:
> Hi Theo,
> Thanks. How about coqide (it's been mentioned to me previously, but
> apparently it has the same options as coqtop, and it's documentation
> within the reference manual doesn't seem to mention the _CoqProject file).
> And so far, I'm pretty much on my own regarding this _CoqProject file -
> I can't find any documentation about how to set it up, when it is used,
> and what it does. Is there any such documentation?
> Thanks for the tip about echo $?
> Jeremy Dawson
> On 6/2/20 7:48 pm, Théo Zimmermann wrote:
>> Hi Jeremy,
>> The _CoqProject file is supported by editors with Coq support (Emacs
>> with PG, VsCode with VsCoq, etc.) and by coq_makefile. You are never
>> supposed to run coqc nor coqtop directly by yourself. In particular,
>> today coqtop is considered as just a debugging tool. If you do insist on
>> using it standalone, you are pretty much on your own (and you'll have to
>> figure out the flags you need to give it).
>> Regarding how to make sure that a process such as make finished without
>> error, you can print the exit code: echo $?
>> Cheers,
>> Théo
>> Le jeu. 6 févr. 2020 à 01:59, Jeremy Dawson
>> <mailto:Jeremy.Dawson AT anu.edu.au>>
>> a écrit :
>> Well, make with the existing Makefile seems to make everything OK, I
>> suppose there is no way to tell for sure, but there is no apparent
>> error.
>> With a new _CoqProject file there are all sorts of errors, presumably
>> because the existing _CoqProject file has useful stuff in it.
>> But in any event, running coq (to be exact, coqtop) does not access
>> either _CoqProject or Makefile, so I can't see how your solution should
>> work.  (Anyway, it doesn't).  Maybe I'm missing something here.  Can
>> you
>> explain how your solution should work.
>> Or can anyone refer me to where the documentation on this issue is,
>> if any?
>> Thanks
>> Jeremy
>> On 5/2/20 7:59 pm, Donald Leung wrote:
>> > Dear Jeremy,
>> > Try adding a `_CoqProject` file in the root directory of your Coq
>> development with the following contents:
>> > -Q ./tttt/TTT/ tttt.TTT
>> > ./tttt/TTT/ssss.v
>> > ./tttt/TTT/file2.v
>> > ./tttt/TTT/file3.v
>> > ./tttt/TTT/filen.v
>> > where file2.v, file3.v, …, filen.v are the other vernacular files
>> in your Coq development that you would also like to compile. Then run:
>> > ```bash
>> > $ coq_makefile -f _CoqProject -o Makefile
>> > in your command line and select `Compile > Make` in your CoqIDE
>> (or similar). Provided the build is successful, you should then be
>> able to step through the line:
>> > ```coq
>> >  From tttt.TTT Require Import ssss.
>> > in your CoqIDE (or similar) without any issues.
>> > Yours sincerely,
>> > Donald
>> >> Jeremy Dawson
>> <mailto:Jeremy.Dawson AT anu.edu.au>>於2020年2月5日
>> 15:00寫道:
>> >> Hi,
>> >> I'm trying to run a command which I was guessing should be
>> >> but I get the error
>> >> Cannot find a physical path bound to logical path matching suffix
>> >> <> and prefix tttt.TTT.
>> >> What does this mean?
>> >> How do I use a file tttt/TTT/ssss.vo?
>> >> The documentation contains
>> >>   Variant From dirpath Require qualid
>> >> (in
>> https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#coq:cmdv.from-require)
>> >> What should a dirpath look like, and where is it to be found in the
>> >> documentation?  (Some of these syntax constructs seem to be
>> defined in
>> https://coq.inria.fr/distrib/current/refman/language/gallina-specification-language.html
>> >> but dirpath isn't - and none of them seem to be in the index)
>> >> Thanks
>> >> Jeremy
Website: https://people.mpi-sws.org/~jung/
