coq-club - Re: [Coq-Club] how to require file in subdirectory
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Cc: Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
  • Subject: Re: [Coq-Club] how to require file in subdirectory
  • Date: Thu, 6 Feb 2020 15:26:23 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f50.google.com
  • Ironport-phdr: 9a23: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
FTR this is documented in the "PRACTICAL TOOLS/ Coq Command" chapter of the
documentation:
https://coq.inria.fr/distrib/current/refman/practical-tools/coq-commands.html
and in "PRACTICAL TOOLS/ Utilities":
https://coq.inria.fr/distrib/current/refman/practical-tools/utilities.html#utilities
P.
Le jeu. 6 févr. 2020 à 15:23, Ralf Jung
<jung AT mpi-sws.org>
a écrit :
> Hi Jeremy,
> if it helps to see an example, you can check out how we are using
> _CoqProject in
> Iris:
> https://gitlab.mpi-sws.org/iris/iris/blob/master/_CoqProject
> In particular, note the "-Q theories iris". This means that the folder
> "theories" (relative to the _CoqProject file) becomes the Coq logical path
> "iris".
> With this, you can just open any .v file in theories/* in CoqIDE, and all
> the
> paths just work. No need to pass any flags anywhere else. (Well, this is
> what
> happens with ProofGeneral, but I think CoqIDE is the same.) And as already
> mentioned in this thread, the coq_makefile invocation is
> coq_makefile -f _CoqProject -o Makefile
> After that, running "make" will build all files listed in _CoqProject.
> (Notice that if you have a typo in that file list, really weird stuff can
> happen
> -- that's a known bug: https://github.com/coq/coq/issues/9319.)
> Kind regards,
> Ralf
> On 06.02.20 15:09, Jeremy Dawson wrote:
> > Hi Theo,
> > Thanks. How about coqide (it's been mentioned to me previously, but
> > apparently it has the same options as coqtop, and it's documentation
> > within the reference manual doesn't seem to mention the _CoqProject file).
> > And so far, I'm pretty much on my own regarding this _CoqProject file -
> > I can't find any documentation about how to set it up, when it is used,
> > and what it does. Is there any such documentation?
> > Thanks for the tip about echo $?
> > Jeremy Dawson
> > On 6/2/20 7:48 pm, Théo Zimmermann wrote:
> >> Hi Jeremy,
> >> The _CoqProject file is supported by editors with Coq support (Emacs
> >> with PG, VsCode with VsCoq, etc.) and by coq_makefile. You are never
> >> supposed to run coqc nor coqtop directly by yourself. In particular,
> >> today coqtop is considered as just a debugging tool. If you do insist on
> >> using it standalone, you are pretty much on your own (and you'll have to
> >> figure out the flags you need to give it).
> >> Regarding how to make sure that a process such as make finished without
> >> error, you can print the exit code: echo $?
> >> Cheers,
> >> Théo
> >> Le jeu. 6 févr. 2020 à 01:59, Jeremy Dawson
> >> <mailto:Jeremy.Dawson AT anu.edu.au>>
> >> a écrit :
> >> Well, make with the existing Makefile seems to make everything OK, I
> >> suppose there is no way to tell for sure, but there is no apparent
> >> error.
> >> With a new _CoqProject file there are all sorts of errors, presumably
> >> because the existing _CoqProject file has useful stuff in it.
> >> But in any event, running coq (to be exact, coqtop) does not access
> >> either _CoqProject or Makefile, so I can't see how your solution
> >> should
> >> work. (Anyway, it doesn't). Maybe I'm missing something here. Can
> >> you
> >> explain how your solution should work.
> >> Or can anyone refer me to where the documentation on this issue is,
> >> if any?
> >> Thanks
> >> Jeremy
> >> On 5/2/20 7:59 pm, Donald Leung wrote:
> >> > Dear Jeremy,
> >> > Try adding a `_CoqProject` file in the root directory of your Coq
> >> development with the following contents:
> >> > -Q ./tttt/TTT/ tttt.TTT
> >> > ./tttt/TTT/ssss.v
> >> > ./tttt/TTT/file2.v
> >> > ./tttt/TTT/file3.v
> >> > ./tttt/TTT/filen.v
> >> > where file2.v, file3.v, …, filen.v are the other vernacular files
> >> in your Coq development that you would also like to compile. Then
> >> run:
> >> > ```bash
> >> > $ coq_makefile -f _CoqProject -o Makefile
> >> > in your command line and select `Compile > Make` in your CoqIDE
> >> (or similar). Provided the build is successful, you should then be
> >> able to step through the line:
> >> > ```coq
> >> > From tttt.TTT Require Import ssss.
> >> > in your CoqIDE (or similar) without any issues.
> >> > Yours sincerely,
> >> > Donald
> >> >> Jeremy Dawson
> >> <mailto:Jeremy.Dawson AT anu.edu.au>>於2020年2月5日
> >> 15:00寫道:
> >> >> Hi,
> >> >> I'm trying to run a command which I was guessing should be
> >> >> but I get the error
> >> >> Cannot find a physical path bound to logical path matching suffix
> >> >> <> and prefix tttt.TTT.
> >> >> What does this mean?
> >> >> How do I use a file tttt/TTT/ssss.vo?
> >> >> The documentation contains
> >> >> Variant From dirpath Require qualid
> >> >> (in
> >> https://coq.inria.fr/distrib/current/refman/proof-engine/vernacular-commands.html#coq:cmdv.from-require)
> >> >> What should a dirpath look like, and where is it to be found in
> >> the
> >> >> documentation? (Some of these syntax constructs seem to be
> >> defined in
> >> https://coq.inria.fr/distrib/current/refman/language/gallina-specification-language.html
> >> >> but dirpath isn't - and none of them seem to be in the index)
> >> >> Thanks
> >> >> Jeremy
> Website: https://people.mpi-sws.org/~jung/
