- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>, agda-list <agda AT lists.chalmers.se>, coq+miscellaneous AT discoursemail.com, lean-user <lean-user AT googlegroups.com>
- Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
- Date: Wed, 4 Mar 2020 08:43:41 +1000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=steven AT steshaw.org; spf=None smtp.mailfrom=steven AT steshaw.org; spf=None smtp.helo=postmaster AT mail-qk1-f193.google.com
- Ironport-phdr: 9a23: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
An additional advantage of Type Theory is that it maintains the abstraction barrier, whereas, in Set Theory, you can look inside to see how your mathematical objects are encoded as sets.
- Re: [Coq-Club] Why dependent type theory?, (continued)
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ken Kubota, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, jonikelee AT gmail.com, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Daniel Schepler, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Steven Shaw, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Martin Escardo, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Sylvain Boulmé, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Kevin Buzzard, 03/05/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, Bas Spitters, 03/08/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/12/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Mario Carneiro, 03/13/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Kevin Buzzard, 03/13/2020
- Message not available
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Bas Spitters, 03/17/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/18/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Stefan Monnier, 03/15/2020
