- To: Kevin Buzzard <kevin.m.buzzard AT gmail.com>
- Cc: Thorsten Altenkirch <Thorsten.Altenkirch AT nottingham.ac.uk>, agda-list <agda AT lists.chalmers.se>, Coq Club <coq-club AT inria.fr>, "coq+miscellaneous AT discoursemail.com" <coq+miscellaneous AT discoursemail.com>, lean-user <lean-user AT googlegroups.com>
- Subject: Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?
- Date: Tue, 17 Mar 2020 10:37:14 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=b.a.w.spitters AT gmail.com; spf=Pass smtp.mailfrom=b.a.w.spitters AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk1-f196.google.com
- Ironport-phdr: 9a23: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
For reference, we (Kevin and the hott community) had a discussion
about canonical isomorphisms here:
https://groups.google.com/d/msg/homotopytypetheory/NhIhMd7SM_4/tKvejHGiAwAJ
On Tue, Mar 17, 2020 at 1:02 AM Kevin Buzzard
wrote:
>> It seems to me that if you are working with structures, i.e. do structural
>> Mathematics you need to understand what they are and they cannot be
>> reduced to their encodings. Hence what is the equality of structures, if
>> not their structural equality? If I remember correctly, in your talk at
>> Nottingham you discussed a construction by Grothendieck where he used
>> equivalence of structures as if it were equality. This seems to be an
>> omission and you and your students were able to address this, I think by
>> choosing a canonical representation. However, the funny thing was that you
>> were using a system which doesn’t allow you to express any non-structural
>> properties but because of the way equality is done in Lean you cannot
>> exploit this.
> There is something subtle going on which I do not really understand, but it
> would not surprise me if there are plenty of people on these lists who do.
> Our problem with formalising the work of Grothendieck was that he assumed
> that objects which were "canonically" isomorphic were in fact equal.
> Canonical isomorphism is this weasel word which mathematicians often do not
> define properly, but in this particular case (we had a proof of P(A) and I
> could not deduce a proof of P(B) when B was "canonically" isomorphic to A)
> we solved the problem by noticing that in this particular case "canonically
> isomorphic" meant "satisfied the same universal property". We then changed
> our proof of P(A) to prove instead P(anything satisfying the universal
> property defining A), and then we were OK. I think it is interesting that
> at the point in my talk when I explained this, I said "and we couldn't
> believe it -- our proof barely needed changing" and you laughed and said
> something like "of course it didn't!". We are mathematicians learning how
> mathematics works :-) But we did not go "full univalence", we did not argue
> that isomorphic objects were equal, we only needed that "canonically"
> isomorphic objects were equal. In my experience of mathematics, this is the
> principle which is used. My fear of univalence is that because it goes a
> bit further, and that extra step seems to rule out some basic principles
> used in Lean's maths library and hence makes a whole bunch of mathematical
> proofs far more inconvenient to write. I am still learning about theorem
> provers but am urging my community to start formalising mathematics and
> this sort of thing is one of many issues which deserves to be better
> understood -- certainly by mathematicians!
>> I don’t know what Mathematics is actually happening in Maths departments
>> but you seem to agree that it can be done in Type Theory, e.g. in Lean.
>> Indeed, in a way Type Theory is not far away from Mathematical practice
>> (if we ignore the question of constructiveness for the moment). And it is
>> different from set theory in that it structural by nature. I just find it
>> strange if one cannot go the last step and exploit this fact. It seems
>> somehow this is a blast from the past: because we cannot have univalence
>> in set theory we don’t need it in type theory either?
> I just do not know whether we need it in "Fields Medal mathematics" or
> whatever you want to call it, because so little "Fields Medal mathematics"
> is being done in theorem provers. I have this other life when I am going
> round maths departments arguing that current mathematical practice is
> extremely unhygenic, producing example after example where I think that pen
> and paper mathematics has got completely out of control. One thing I have
> learnt from a couple of years of doing this is that most mathematicians are
> (a) completely aware of the issues and (b) don't care. A mathematical
> historian told me that in fact mathematics has often been like this,
> basically saying that it is the nature of progress in mathematics research.
>> Ok, this is a different topic (and I didn’t say anything about
>> constructive Maths in my original posting). I think the sort of Maths you
>> are doing is very much influenced by what you are using it or what it has
>> been used for in the past. It seems to me that until recently natural
>> science and hardware engineering was the main application of Mathematics
>> and hence influenced what Mathematicians considered as important. The
>> world is changing and computer science and information technology are
>> becoming an important application of Mathematics. For historical reasons
>> and also for reasons of funding a lot of the Maths for Computer Science is
>> actually done at Computer Science departments. I am just thinking that
>> you, the Mathematicians, maybe miss a trick here; and so do we, the
>> Computer Scientists because we could profit more from the wisdom of
>> Mathematicians like yourself.
> Mathematics is an incredibly broad discipline nowadays, as you say, and
> serious mathematics is being done in plenty of places other than
> mathematics departments. The group of people I am trying to "represent",
> not necessarily by being one of them, but at least by having what I think
> is a good understanding of their desires, are those people who do not care
> about any of these applications, and just want to prove stuff like the
> p-adic Langlands conjectures, abstract conjectures saying that some class
> of infinite-dimensional objects coming from analysis are related to actions
> of an infinite group on some spaces coming from algebra -- results which I
> personally suspect will never have any applications to anything, but which
> are just intrinsically beautiful and are hence funded because part of the
> funding system in mathematics firmly believes in blue sky research. The
> people I'm talking about are beautifully caricatured in "The Ideal
> Mathematician"
> https://personalpages.manchester.ac.uk/staff/hung.bui/ideal.pdf by David
> and Hersh (in fact I slightly struggle to see what is so funny about that
> article because I so completely understand the point of view of the
> mathematician). In fact the only difference between some of the
> mathematicians I know doing "Fields Medal mathematics" and the "ideal
> mathematician" described in that article is that the areas the "Fields
> Medal mathematicians" actually work in areas which are taken *much* more
> seriously (like the p-adic Langlands philosophy), with very big communities
> containing powerful people who are making big decisions about where the
> funding is going within pure mathematics. These people might seem very
> extreme to many of the people reading these mailing lists -- most do not
> care about computation or constructivism, they spend their lives doing
> classical reasoning about intrinisically infinite objects, and they do not
> see the point of these proof assistants at all (and they also do not care
> about bugs in computer code because the only point of the computer is to
> check a gazillion examples to convince us that our deep conjectures are
> true, and we know they're true anyway). The reason that the computer proof
> community should be bending over backwards to accommodate these people is
> that *these people are the important ones* within pure mathematics, and
> many of them have very entrenched ideas about what is and isn't
> mathematics, and what is and what isn't important. Thorsten makes some
> excellent points about all the other places where mathematics is being used
> but it's the people at the top of this particular tree who I want. It is
> these people who should be telling us what kind of type theory should be
> being used, at least for the system or systems that I believe they will
> ultimately adopt. But until they notice that the systems exist it is very
> difficult to get clear answers -- or indeed any answers.
> > As I said to me it seems that too much surface stuff is moved into the
> > core of systems like Lean.
> What Lean has going for it is that in practice it is turning out to be very
> easy to quickly formalise the kind of mathematics which these "top of the
> tree" pure mathematicians care about. However this might be because of some
> social phenomena rather than because of its underlying type theory.
> Kevin
> Thorsten
> On 08/03/2020, 14:25, "Agda on behalf of Bas Spitters"
> <agda-bounces AT lists.chalmers.se
> on behalf of
> b.a.w.spitters AT gmail.com>
> wrote:
> Dear Kevin,
> The excitement about HoTT is that it has brought together several
> communities. Some are interested in homotopy theory and higher
> category theory, some (like Vladimir) want a new foundation for modern
> mathematics.
> Some combine those two by higher toposes.
> Some are trying to improve the previous generation of proof
> assistants. E.g. this influenced the design of quotients types in
> lean.
> By Curry-Howard this also influences the design of programming
> languages, like the cubical agda programming language
> (https://pure.itu.dk/portal/files/84649948/icfp19main_p164_p.pdf)
> If we consider HoTT as an extension of type theory with the univalence
> axiom, then *of course* everything that was done before can still be
> done.
> E.g. the proof of Feit-Thompson is constructive and thus also works in
> HoTT. (I can elaborate on this if needed.)
> In fact, classical logic is valid in the simplicial set model
> (https://www.math.uwo.ca/faculty/kapulkin/notes/LEM_in_sSet.pdf).
> Moreover, that model also interprets strict propositions, so one could
> even extend lean with univalence (I believe).
> It would be interesting to know whether this simplifies the definition
> of perfectoid spaces.
> Best regards,
> Bas
> On Thu, Mar 5, 2020 at 12:25 PM Kevin Buzzard
> wrote:
> > On Wed, 4 Mar 2020 at 07:18, Martin Escardo
> <m.escardo AT cs.bham.ac.uk>
> wrote:
> >> Dependent types are good for pure mathematics (classical or
> >> constructive). They are the natural home to define group, ring,
> metric
> >> space, topological space, poset, lattice, category, etc, and study
> them.
> >> Mathematicians that use(d) dependent types include Voevodsky (in Coq)
> >> and Kevin Buzzard (in Lean), among others. Kevin and his team
> defined,
> >> in particular, perfectoid spaces in dependent type theory. Martin
> > The BCM (Buzzard, Commelin, Massot) paper defined perfectoid spaces
> in Lean
> > and looking forwards (in the sense of trying to attract "working
> mathematicians"
> > into the area of formalisation) I think it's an interesting question
> as to whether this definition
> > could be made in other systems in a way which is actually usable. My
> guess: I don't see why it couldn't
> > be done in Coq (but of course the type theories of Lean and Coq are
> similar), although
> > there is a whole bunch of noncomputable stuff embedded in the
> mathematics.
> > I *suspect* that it would be a real struggle to do it in any of the
> HOL systems
> > because a sheaf is a dependent type, but these HOL people are good at
> tricks
> > for working around these things -- personally I would start with
> seeing whether
> > one can set up a theory of sheaves of modules on a locally ringed
> space in a HOL
> > system, because that will be the first stumbling block. And as for
> the HoTT systems,
> > I have no feeling as to whether it is possible to do any serious
> mathematics other than
> > category theory and synthetic homotopy theory -- my perception is that
> > the user base are more interested in other kinds of questions.
> > In particular, connecting back to the original question, a sheaf of
> modules on a
> > locally-ringed space is a fundamental concept which shows up in a
> typical MSc
> > or early PhD level algebraic geometry course (they were in the MSc
> algebraic
> > geometry course I took), and if one wants to do this kind of
> mathematics in a
> > theorem prover (and I do, as do several other people in the Lean
> community)
> > then I *suspect* that it would be hard without dependent types. On
> the other hand
> > I would love to be proved wrong.
> > Kevin
> >> On 03/03/2020 19:43,
> jasongross9 AT gmail.com
> wrote:
> >> > I'm in the process of writing my thesis on proof assistant
> performance
> >> > bottlenecks (with a focus on Coq), and there's a large class of
> >> > performance bottlenecks that come from (mis)using the power of
> dependent
> >> > types. So in writing the introduction, I want to provide some
> >> > justification for the design decision of using dependent types,
> rather
> >> > than, say, set theory or classical logic (as in, e.g.,
> Isabelle/HOL).
> >> > And the only reasons I can come up with are "it's fun" and "lots of
> >> > people do it"
> >> > So I'm asking these mailing lists: why do we base proof assistants
> on
> >> > dependent type theory? What are the trade-offs involved?
> >> > I'm interested both in explanations and arguments given on list,
> as well
> >> > as in references to papers that discuss these sorts of choices.
> >> > Thanks,
> >> > Jason
> >> > _______________________________________________
> >> > Agda mailing list
> Agda AT lists.chalmers.se
> >> > https://lists.chalmers.se/mailman/listinfo/agda
> >> Martin Escardo
> >> http://www.cs.bham.ac.uk/~mhe
> > You received this message because you are subscribed to the Google
> Groups "lean-user" group.
> > To unsubscribe from this group and stop receiving emails from it,
> send an email to
> lean-user+unsubscribe AT googlegroups.com.
> > To view this discussion on the web visit
> https://groups.google.com/d/msgid/lean-user/CAH52Xb0X%3D06U2O7K%2BLGRXyPu%3DhaKxp2FcQr3SFK0f4jm8kv9mQ%40mail.gmail.com.
> Agda mailing list
> This message and any attachment are intended solely for the addressee
> and may contain confidential information. If you have received this
> message in error, please contact the sender and delete the email and
> attachment.
> Any views or opinions expressed by the author of this email do not
> necessarily reflect the views of the University of Nottingham. Email
> communications with the University of Nottingham may be monitored
> where permitted by law.
>> attachment.
> You received this message because you are subscribed to the Google Groups
> "lean-user" group.
> To unsubscribe from this group and stop receiving emails from it, send an
> email to
> https://groups.google.com/d/msgid/lean-user/CAH52Xb2TFq%2BV6kwq22Nw%3DGSt4wAecB%2B7M7JKvrvb4OBds%3DRZQg%40mail.gmail.com.
- Re: [Coq-Club] [Agda] Why dependent type theory?, (continued)
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Steven Shaw, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Martin Escardo, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Sylvain Boulmé, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Kevin Buzzard, 03/05/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, Bas Spitters, 03/08/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/12/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Mario Carneiro, 03/13/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Kevin Buzzard, 03/13/2020
- Message not available
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Bas Spitters, 03/17/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Thorsten Altenkirch, 03/18/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, Stefan Monnier, 03/15/2020
- Re: [Coq-Club] Why dependent type theory?, Guillaume Melquiond, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Dominique Larchey-Wendling, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jeremy Dawson, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Makarius, 03/04/2020
