- To: Ralf Jung <jung AT mpi-sws.org>
- Cc: coq-club AT inria.fr, Jason Gross <jasongross9 AT gmail.com>, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
- Date: Wed, 04 Mar 2020 19:33:23 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mechvel AT scico.botik.ru; spf=Pass smtp.mailfrom=mechvel AT scico.botik.ru; spf=None smtp.helo=postmaster AT mail.botik.ru
- Ironport-phdr: 9a23:Bt0R5hZ/GAy77+ElJrxrT2r/LSx+4OfEezUN459isYplN5qZpsu8bnLW6fgltlLVR4KTs6sC0LWG9f24EUU7or+/81k6OKRWUBEEjchE1ycBO+WiTXPBEfjxciYhF95DXlI2t1uyMExSBdqsLwaK+i76xXcoFx7+LQt4IPjuUs6X1pzvlrP6x5qGWQxMinKffLV9ZEG0sAPenswOgM55Nb13zQHG9ChmYeNTkGZlLlKNkhLU/cyx95kl+SNMuvFn7dMTAu3BY60kQOkAX3wdOGcv6Ziu7EGbFFfd1j4nSmwT1yFwLU3d9hijAMXquSrxsax33zWbPovsUOJsAGXw3+JQUBbtzRw/GXs8+WDThNZ3ifsF8gmqphd4hYTTfICWcuBjLPqEIIEqAFFZV8MUbBRvR4Oxa4xWUrgENOdc6YP6u1oN6wGjV1Gh
On 2020-03-04 19:06, Ralf Jung wrote:
My first guess would that this has something to do with the exponential blow-up
that I discussed in
<https://www.ralfj.de/blog/2019/05/15/typeclasses-exponential-blowup.html>.
It looks like this.
Following this paper, we can define a direct product of rings, denote it _*_,
and put
G = Z * Z * Z * Z * Z * Z * Z * Z (I)
for the ring Z for Integer.
And it may occur that this will be a hard type checking example for Agda.
If so, this will be just a toy example, Jason asked for.
This needs testing.
Thanks,
Sergei
On 04.03.20 00:04, Jason Gross wrote:
I'm confused by this. Are you saying that in Agda typechecking is exponential
in the number of files? Or exponential in the number of nested abstractions?
Or something else? Do you have a toy example demonstrating this behavior?
On Tue, Mar 3, 2020, 17:42
<mechvel AT scico.botik.ru
<mailto:mechvel AT scico.botik.ru>>
wrote:
On 2020-03-04 00:31, Jason Gross wrote:
>> Which bottlenecks are you referring to? Are they intrinsically tied
> to dependent types, or they are related to the treatment of
> propositions and equality in systems such as Coq?
> The main bottleneck that I'm referring to here (though not the only
> one of my thesis) is the one that is due to the fact that arbitrary
> conversion problems can happen during typechecking. This is used to
> great advantage in proof by reflection (where all of the work is done
> in checking that a proof of "true = true" has the type "some-check =
> true"). But it also causes performance issues if you're not careful.
> To take a toy example, consider two different definitions of
> factorial: n! = n * (n - 1)!, and n! = (n - 1)! * n. Suppose you have
> two different ways of computing a vector (length-indexed list) of
> permutations, one which defines the length in terms of the first
> factorial, and the other one which defines the length in terms of the
> second factorial. Suppose you now try to prove that the two methods
> give the same result on any concrete list of length of length 10.
> Just to check that this goal is valid, Coq is now trying to compute
> 10! as a natural number. This example is a bit contrived, but less
> egregious versions of this issue abound, and when doing verified
> engineering at scale, these issues can add up in hard-to-predict ways.
> I have a real-world example where changing the input size just a
> little bit caused `reflexivity` to take over 400 hours, rather than
> just a couple of minutes.
> On Tue, Mar 3, 2020, 16:00 Viktor Kunčak
<vkuncak AT gmail.com
<mailto:vkuncak AT gmail.com>>
wrote:
>> I would be also curious to hear answers to this questions!
>> ("Lots of people do it" seems like a very compelling answer.)
There is a problem of the type checking cost in Agda, and probably in
Coq too.
I do not know of whether it is fundamental or technical. And I have not
seen an answer to this question, so far. On practice, it looks like
this:
Agda can type-check only a small part of the computer algebra library of
methods (with full proofs). With implementing it further, with
increasing the hierarchy level of parameterized modules, the type
check cost seems to grow exponentially in the level.
So, after implementing in Agda an average textbook on computer algebra
(where is known a constructive proof for each statement), say, of 500
pages, it will not be type-checked in 100 years.
Probably, this is a difficult technical problem that will be practically
solved during several years.
Regards,
Sergei
>> There are type systems overlayed on top of initially untyped
>> languages (e.g. the language of Alloy Analyzer) and there are
>> gradual types and designs like TypeScript for to initially untyped
>> programming languages. ACL2 theorem prover for pure LISP, SPASS
>> theorem prover for first-order logic, and "TLA+ model checking made
>> symbolic" model checker for TLA+ all include techniques to recover
>> types from an initially untyped language.
>> Best regards,
>> Viktor
>> On Tue, Mar 3, 2020 at 8:44 PM Jason Gross <jasongross9 AT gmail.com
<mailto:jasongross9 AT gmail.com>>
>> wrote:
>>> I'm in the process of writing my thesis on proof assistant
>>> performance bottlenecks (with a focus on Coq), and there's a large
>>> class of performance bottlenecks that come from (mis)using the
>>> power of dependent types. So in writing the introduction, I want
>>> to provide some justification for the design decision of using
>>> dependent types, rather than, say, set theory or classical logic
>>> (as in, e.g., Isabelle/HOL). And the only reasons I can come up
>>> with are "it's fun" and "lots of people do it"
>>> So I'm asking these mailing lists: why do we base proof assistants
>>> on dependent type theory? What are the trade-offs involved?
>>> I'm interested both in explanations and arguments given on list,
>>> as well as in references to papers that discuss these sorts of
>>> choices.
>>> Thanks,
>>> Jason
> _______________________________________________
> Agda mailing list
Agda AT lists.chalmers.se
<mailto:Agda AT lists.chalmers.se>
> https://lists.chalmers.se/mailman/listinfo/agda
- [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Message not available
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ken Kubota, 03/03/2020
