- To: coq-club AT inria.fr, Jason Gross <jasongross9 AT gmail.com>, mechvel AT scico.botik.ru
- Cc: agda-list <agda AT lists.chalmers.se>, lean-user <lean-user AT googlegroups.com>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
- Date: Wed, 4 Mar 2020 17:06:08 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
- Ironport-phdr: 9a23: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
My first guess would that this has something to do with the exponential
blow-up
that I discussed in
<https://www.ralfj.de/blog/2019/05/15/typeclasses-exponential-blowup.html>.
; Ralf
On 04.03.20 00:04, Jason Gross wrote:
> I'm confused by this. Are you saying that in Agda typechecking is
> exponential
> in the number of files? Or exponential in the number of nested
> abstractions?
> Or something else? Do you have a toy example demonstrating this behavior?
> On Tue, Mar 3, 2020, 17:42
> <mechvel AT scico.botik.ru
> <mailto:mechvel AT scico.botik.ru>>
> wrote:
> On 2020-03-04 00:31, Jason Gross wrote:
> >> Which bottlenecks are you referring to? Are they intrinsically tied
> > to dependent types, or they are related to the treatment of
> > propositions and equality in systems such as Coq?
> > The main bottleneck that I'm referring to here (though not the only
> > one of my thesis) is the one that is due to the fact that arbitrary
> > conversion problems can happen during typechecking. This is used to
> > great advantage in proof by reflection (where all of the work is done
> > in checking that a proof of "true = true" has the type "some-check =
> > true"). But it also causes performance issues if you're not careful.
> > To take a toy example, consider two different definitions of
> > factorial: n! = n * (n - 1)!, and n! = (n - 1)! * n. Suppose you have
> > two different ways of computing a vector (length-indexed list) of
> > permutations, one which defines the length in terms of the first
> > factorial, and the other one which defines the length in terms of the
> > second factorial. Suppose you now try to prove that the two methods
> > give the same result on any concrete list of length of length 10.
> > Just to check that this goal is valid, Coq is now trying to compute
> > 10! as a natural number. This example is a bit contrived, but less
> > egregious versions of this issue abound, and when doing verified
> > engineering at scale, these issues can add up in hard-to-predict ways.
> > I have a real-world example where changing the input size just a
> > little bit caused `reflexivity` to take over 400 hours, rather than
> > just a couple of minutes.
> > On Tue, Mar 3, 2020, 16:00 Viktor Kunčak
> <vkuncak AT gmail.com
> <mailto:vkuncak AT gmail.com>>
> wrote:
> >> I would be also curious to hear answers to this questions!
> >> ("Lots of people do it" seems like a very compelling answer.)
> There is a problem of the type checking cost in Agda, and probably in
> Coq too.
> I do not know of whether it is fundamental or technical. And I have not
> seen an answer to this question, so far. On practice, it looks like
> this:
> Agda can type-check only a small part of the computer algebra library of
> methods (with full proofs). With implementing it further, with
> increasing the hierarchy level of parameterized modules, the type
> check cost seems to grow exponentially in the level.
> So, after implementing in Agda an average textbook on computer algebra
> (where is known a constructive proof for each statement), say, of 500
> pages, it will not be type-checked in 100 years.
> Probably, this is a difficult technical problem that will be practically
> solved during several years.
> Regards,
> Sergei
> >> There are type systems overlayed on top of initially untyped
> >> languages (e.g. the language of Alloy Analyzer) and there are
> >> gradual types and designs like TypeScript for to initially untyped
> >> programming languages. ACL2 theorem prover for pure LISP, SPASS
> >> theorem prover for first-order logic, and "TLA+ model checking made
> >> symbolic" model checker for TLA+ all include techniques to recover
> >> types from an initially untyped language.
> >> Best regards,
> >> Viktor
> >> On Tue, Mar 3, 2020 at 8:44 PM Jason Gross
> <mailto:jasongross9 AT gmail.com>>
> >> wrote:
> >>> I'm in the process of writing my thesis on proof assistant
> >>> performance bottlenecks (with a focus on Coq), and there's a large
> >>> class of performance bottlenecks that come from (mis)using the
> >>> power of dependent types. So in writing the introduction, I want
> >>> to provide some justification for the design decision of using
> >>> dependent types, rather than, say, set theory or classical logic
> >>> (as in, e.g., Isabelle/HOL). And the only reasons I can come up
> >>> with are "it's fun" and "lots of people do it"
> >>> So I'm asking these mailing lists: why do we base proof assistants
> >>> on dependent type theory? What are the trade-offs involved?
> >>> I'm interested both in explanations and arguments given on list,
> >>> as well as in references to papers that discuss these sorts of
> >>> choices.
> >>> Thanks,
> >>> Jason
> > _______________________________________________
> > Agda mailing list
> Agda AT lists.chalmers.se
> <mailto:Agda AT lists.chalmers.se>
> > https://lists.chalmers.se/mailman/listinfo/agda
Website: https://people.mpi-sws.org/~jung/
- Re: [Coq-Club] [lean-user] Why dependent type theory?, (continued)
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [lean-user] Re: [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/06/2020
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/07/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ken Kubota, 03/03/2020
