- To: mechvel AT scico.botik.ru
- Cc: Ralf Jung <jung AT mpi-sws.org>, coq-club AT inria.fr, agda-list <agda AT lists.chalmers.se>, Coq Discourse <coq+miscellaneous AT discoursemail.com>
- Subject: Re: [Coq-Club] [Agda] Why dependent type theory?
- Date: Wed, 4 Mar 2020 17:52:59 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=ulf.norell AT gmail.com; spf=Pass smtp.mailfrom=ulf.norell AT gmail.com; spf=None smtp.helo=postmaster AT mail-lj1-f179.google.com
- Ironport-phdr: 9a23:c5v7QREhU57b5leDRwAvT51GYnF86YWxBRYc798ds5kLTJ76r82wAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWapAQfERTnNAdzOv+9WsuL15z2hKiO/MjWbg5Imje5Sah5LR6x6w/WqsgVx5F/eYgrzR6cn39GM8JR325sIRrHghLyoMG35pNn9wxfvvsg84hLVqCsLPdwdqBREDlzazN938bsrxSWCFLXviJNAFVTqQJBBk3+1D+/W57wtiXgse8kgXuVOMT3SfY/XjHwtv42Gi+tsz8OMnsCyE+SisF0i/gF8heophg6x4yNJY/Ma6s4caTactcXA2FGW5QJDnATMsaHd4IKStE5E6NAtYCk/gkBqBK/AU+nA+a9kjI=
On Wed, Mar 4, 2020 at 5:33 PM <mechvel AT scico.botik.ru> wrote:
It looks like this.
Following this paper, we can define a direct product of rings, denote it
_*_,
and put
G = Z * Z * Z * Z * Z * Z * Z * Z (I)
for the ring Z for Integer.
And it may occur that this will be a hard type checking example for
Agda.
This will certainly not be a hard type checking problem for Agda. Depending on how
you define _*_ and Z computing with G can of course blow up.
/ Ulf
> On 04.03.20 00:04, Jason Gross wrote:
>> I'm confused by this. Are you saying that in Agda typechecking is
>> exponential
>> in the number of files? Or exponential in the number of nested
>> abstractions?
>> Or something else? Do you have a toy example demonstrating this
>> behavior?
>> On Tue, Mar 3, 2020, 17:42 <mechvel AT scico.botik.ru
>> <mailto:mechvel AT scico.botik.ru>> wrote:
>> On 2020-03-04 00:31, Jason Gross wrote:
>> >> Which bottlenecks are you referring to? Are they intrinsically
>> tied
>> > to dependent types, or they are related to the treatment of
>> > propositions and equality in systems such as Coq?
>> > The main bottleneck that I'm referring to here (though not the
>> only
>> > one of my thesis) is the one that is due to the fact that
>> arbitrary
>> > conversion problems can happen during typechecking. This is
>> used to
>> > great advantage in proof by reflection (where all of the work is
>> done
>> > in checking that a proof of "true = true" has the type
>> "some-check =
>> > true"). But it also causes performance issues if you're not
>> careful.
>> > To take a toy example, consider two different definitions of
>> > factorial: n! = n * (n - 1)!, and n! = (n - 1)! * n. Suppose
>> you have
>> > two different ways of computing a vector (length-indexed list)
>> of
>> > permutations, one which defines the length in terms of the first
>> > factorial, and the other one which defines the length in terms
>> of the
>> > second factorial. Suppose you now try to prove that the two
>> methods
>> > give the same result on any concrete list of length of length
>> 10.
>> > Just to check that this goal is valid, Coq is now trying to
>> compute
>> > 10! as a natural number. This example is a bit contrived, but
>> less
>> > egregious versions of this issue abound, and when doing verified
>> > engineering at scale, these issues can add up in hard-to-predict
>> ways.
>> > I have a real-world example where changing the input size just
>> a
>> > little bit caused `reflexivity` to take over 400 hours, rather
>> than
>> > just a couple of minutes.
>> > On Tue, Mar 3, 2020, 16:00 Viktor Kunčak <vkuncak AT gmail.com
>> <mailto:vkuncak AT gmail.com>> wrote:
>> >> I would be also curious to hear answers to this questions!
>> >> ("Lots of people do it" seems like a very compelling answer.)
>> tied
>> There is a problem of the type checking cost in Agda, and probably
>> in
>> Coq too.
>> I do not know of whether it is fundamental or technical. And I
>> have not
>> seen an answer to this question, so far. On practice, it looks
>> like
>> this:
>> Agda can type-check only a small part of the computer algebra
>> library of
>> methods (with full proofs). With implementing it further, with
>> increasing the hierarchy level of parameterized modules, the type
>> check cost seems to grow exponentially in the level.
>> So, after implementing in Agda an average textbook on computer
>> algebra
>> (where is known a constructive proof for each statement), say, of
>> 500
>> pages, it will not be type-checked in 100 years.
>> Probably, this is a difficult technical problem that will be
>> practically
>> solved during several years.
>> Regards,
>> Sergei
>> >> There are type systems overlayed on top of initially untyped
>> >> languages (e.g. the language of Alloy Analyzer) and there are
>> >> gradual types and designs like TypeScript for to initially
>> untyped
>> >> programming languages. ACL2 theorem prover for pure LISP, SPASS
>> >> theorem prover for first-order logic, and "TLA+ model checking
>> made
>> >> symbolic" model checker for TLA+ all include techniques to
>> recover
>> >> types from an initially untyped language.
>> >> Best regards,
>> >> Viktor
>> >> On Tue, Mar 3, 2020 at 8:44 PM Jason Gross
>> <jasongross9 AT gmail.com
>> <mailto:jasongross9 AT gmail.com>>
>> >> wrote:
>> >>> I'm in the process of writing my thesis on proof assistant
>> >>> performance bottlenecks (with a focus on Coq), and there's a
>> large
>> >>> class of performance bottlenecks that come from (mis)using the
>> >>> power of dependent types. So in writing the introduction, I
>> want
>> >>> to provide some justification for the design decision of using
>> >>> dependent types, rather than, say, set theory or classical
>> logic
>> >>> (as in, e.g., Isabelle/HOL). And the only reasons I can come
>> up
>> >>> with are "it's fun" and "lots of people do it"
>> >>> So I'm asking these mailing lists: why do we base proof
>> assistants
>> >>> on dependent type theory? What are the trade-offs involved?
>> >>> I'm interested both in explanations and arguments given on
>> list,
>> >>> as well as in references to papers that discuss these sorts of
>> >>> choices.
>> >>> Thanks,
>> >>> Jason
>> > _______________________________________________
>> > Agda mailing list
>> > Agda AT lists.chalmers.se <mailto:Agda AT lists.chalmers.se>
>> > https://lists.chalmers.se/mailman/listinfo/agda
Agda mailing list
- [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] [lean-user] Why dependent type theory?, Colin Stebbins Gordon, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Viktor Kunčak, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Jason Gross, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Patricia Peratto, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/03/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Jason Gross, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] [Agda] Why dependent type theory?, Ulf Norell, 03/04/2020
- Message not available
- Re: [Coq-Club] [Agda] [lean-user] Re: Why dependent type theory?, mechvel, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre Courtieu, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Pierre-Marie Pédrot, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ralf Jung, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Jesper Cockx, 03/04/2020
- Re: [Coq-Club] Why dependent type theory?, Christian Doczkal, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, Ken Kubota, 03/03/2020
- Re: [Coq-Club] Why dependent type theory?, jonikelee AT gmail.com, 03/03/2020
