coq-club - Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
  • To: coq-club AT inria.fr, Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
  • Subject: Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
  • Date: Mon, 23 Mar 2020 11:34:43 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lysxia AT gmail.com; spf=Pass smtp.mailfrom=lysxia AT gmail.com; spf=None smtp.helo=postmaster AT mail-vk1-f170.google.com
  • Ironport-phdr: 9a23:5dnn7hGDvQ8ZM9KH2eTrhZ1GYnF86YWxBRYc798ds5kLTJ75psiwAkXT6L1XgUPTWs2DsrQf1LqQ7viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWapAQfERTnNAdzOv+9WsuL15z2hKiO/MjYZBwNjz6ga5tzKg+3pEPfrI1eo4Z4J6MggjfAvWBPfawC525yKFeC2Tr1+dy3+rZq9TkWtv48scddB/bUZaM9GJhZSSUvNCgF5cSj4R3SVhuO71MTV2wXllxDBA2Tv0KyZYv4riav7rk14yKdJ8CjCOlsAW3/vZcucwfhjWI8DxB88GzTjZYu3qdSoRbkuR8mhoCNP9nTO/15cafQO9gdQDgZB5cDZ2l6Goq5KrA3Ia8ENOdcoZP6ogJX/xS7DAioQujoz20R3yOk7egBy+0kVDr+8kk4BdtX6Sbbqdz0MOEZVuXnlKQ=
Hi Jeremy,
Your current switch uses ocaml 4.02 but coq 8.11.0 depends on ocaml >= 4.05 && < 4.10. Create a new switch with a more recent version of ocaml, (But not too recent, < 4.10) so you can install coq 8.11.
> However it (apparently) tried to reinstall coq 8.8.2 (why?) and failed,
> saying ERROR while compiling coq.8.8.2
The error message includes the logs below that line. There is an output-file where to find the complete logs, and also an "### output ###" section with the most recent output from the build.
> I think at the moment I have a working version of coq thanks to the
> fedora package of coq, but how can I tell which version of the library
> it is using?
You should probably not get coq via your OS distribution's package manager. Only install it with opam.
Most OS distributions move slowly, so they're always a few versions behind, and they only provide a limited selection of packages. If you want to keep up with the bleeding edge, you should only install OCaml and Coq packages through opam.
Don't hesitate to ask for further clarification.
Cheers,
Li-yao
On 3/23/20 10:31 AM, Jeremy Dawson wrote:
Hi Ralf,
Thanks - I tried opam update, and then as its output suggested doing
opam upgrade, I tried that.
It suggested running
opam switch import
"/home/jeremy/opam-coq.8.8.2/ocaml-base-compiler.4.02.3/.opam-switch/backup/state-20200323132407.export"
which seemed to hang at the point Processing 9/13: [coq: make]
it is using?
Thanks
Jeremy
On 3/23/20 7:04 PM, Ralf Jung wrote:
Hi Jeremy,
std++ 1.3 is compatible with Coq 8.8.2 (and even with Coq 8.7.2), so that
cannot
be the problem. It looks like your package definitions are quite outdated,
given that it cannot even find Coq 8.11.0. Did you try "opam update"?
Kind regards,
Ralf
On 23.03.20 03:26, Jeremy Dawson wrote:
Hi,
> This release of the std++ library adds support for Coq 8.11 and is
available in Coq's opam repository.
At present I have Coq 8.8.2 on my machine, and I don't know what version
of the standard library. How do I find that out?
How do I install a new version of the standard library (ie what do I do
to make use of the fact that it is "available in Coq's opam repository"?
Trying opam install coq-stdpp seems to start installing coq-stdpp 1.1.0
which I assume is not what I want.
In any event I assume I have to upgrade to Coq 8.11 to make use of it,
would that be right?
I've tried to do that, following instructions at
https://coq.inria.fr/opam-using.html but part way through I get
[jeremy@localhost sysadmin]$ opam pin add coq 8.11.0
[ERROR] Package coq has no known version 8.11.0 in the repositories
What do I need to do?
Thanks
Jeremy
