- To: Ralf Jung <jung AT mpi-sws.org>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
- Date: Wed, 25 Mar 2020 14:20:52 +0000
- Accept-language: en-US
- Arc-authentication-results: i=1; mx.microsoft.com 1; spf=pass smtp.mailfrom=anu.edu.au; dmarc=pass action=none header.from=anu.edu.au; dkim=pass header.d=anu.edu.au; arc=none
- Arc-message-signature: i=1; a=rsa-sha256; c=relaxed/relaxed; d=microsoft.com; s=arcselector9901; h=From:Date:Subject:Message-ID:Content-Type:MIME-Version:X-MS-Exchange-SenderADCheck; bh=j4NK2NHsCccVoeat0hyofGCD5AS/vbAfXnq6q4chZfg=; b=OZLdzOGmF40jzy9MAbiwCpFrBaAKoAcPkPd0nM6pxT8zQwhp1Fw5Pnp8+DhOcuWv6SBpjY8duA6XHbdJH9yGwCG2poDpPiw4UCBQcLeAkIz/oXHcVh3umZpxTTGIMCo1iSR6OSQ3Er2taVLhJpKu5wEHr0FVPR3jRQ3A+v7pynoH4LsTf7MSlgWArW+yvvVdObPrLCbxQpsIP05xEle9nZeCGE65kkCUYvhiZAbyeVuZCbhwNqP2M+0rkA+pBGD5M9/mIOis+tg1rG7TlncFd3k9Iw4lX9hmC9uKWx1nb6n/2B1jxfLHeE/GYX2KTtVaLmv2CkiM3qwc2/Wx/HhgFw==
- Arc-seal: i=1; a=rsa-sha256; s=arcselector9901; d=microsoft.com; cv=none; b=eQDGQe4uOGUY/UtVo/RmNlUZHcnOgtxATXfug6BmiocdKxU33Li1Lvq4AczRpB95BgI8IgwS2R9xqQnsMJQhH0vgSZMe6Y74VQuCfx0h1ZLoGHU2dV5FG5kfUu7oSwynFqwUyGaKf4NDKVXY85iw/s1t/f0st0Xt1lGi9XBotr/QF86ZHqKo1HFRMJogrDUOkDop+A6u3dzdYeu0JzfXffwC0Fzm1EwNWVK3jBvFWFmXcTknvYLMagwjLHVzo+D3ycQpgCVwlaD0IyknVSkPp6W+O3T3uOvBbN8qBjW0ulPRXiQkSIOP16ZHbR9oGJ+bTjDKMRDxsm92jaPGfEitxw==
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.mailfrom=Jeremy.Dawson AT anu.edu.au; spf=Pass smtp.helo=postmaster AT AUS01-ME1-obe.outbound.protection.outlook.com
- Ironport-phdr: 9a23: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
Hi Ralf,
thanks - the following output does seem peculiar
[jeremy@localhost Downloads]$ opam repo list
[NOTE] These are the repositories in use by the current switch. Use
'--all' to
see all configured repositories.
<><> Repository configuration for switch with-coq
1 default https://opam.ocaml.org
[jeremy@localhost Downloads]$ opam switch
# switch compiler description
ocaml-base-compiler.4.02.3 ocaml-base-compiler.4.02.3
-> with-coq ocaml-base-compiler.4.05.0 with-coq
[jeremy@localhost Downloads]$ opam repo list --all
# Repository # Url # Switches(rank)
coq-released http://coq.inria.fr/opam/released ocaml-base-compiler.4.02.3(1)
default https://opam.ocaml.org <default>(1) with-coq(1)
ocaml-base-compiler.4.02.3(2)
[jeremy@localhost Downloads]$ opam repo add coq-released
https://coq.inria.fr/opam/released
[ERROR] Repository coq-released is already set up and points to
http://coq.inria.fr/opam/released. To change that, use 'opam
repository
set-url'.
[jeremy@localhost Downloads]$ opam --version
2.0.1
Sorry for the extra line breaks - it's thunderbird email
Cheers,
Jeremy
On 3/26/20 12:57 AM, Ralf Jung wrote:
> Hi Jeremy,
> Well, that is pretty strange. What does "opam repo list" say?
> Also, let me repeat what Theo said earlier:
>> I'll add to the excellent advice of Ralf and Li-yao that another
>> source of confusion can be the version of opam itself. Please make
>> sure that opam --version gives you something above 2.0, otherwise it
>> won't work to get recent Coq and Coq packages versions.
> It's really important that you use opam 2.
> Kind regards,
> Ralf
> On 25.03.20 14:17, Jeremy Dawson wrote:
>> Hi ralf,
>> Thanks - but I think that is what I have done, have I misunderstood this?
>> [jeremy@localhost laptops]$ opam switch
>> [jeremy@localhost laptops]$ opam repo add coq-released
>> repository
>> set-url'.
>> [jeremy@localhost laptops]$ opam search coq-stdpp
>> # Packages matching: match(*coq-stdpp*)
>> # No matches found
>> Cheers,
>> Jeremy
>> On 3/24/20 11:37 PM, Ralf Jung wrote:
>>> Hi Jeremy,
>>> You need to do the "repo add" when "with-coq" is your current switch.
>>> Repositories are per-switch with opam.
>>> Kind regards,
>>> Ralf
>>> On 24.03.20 12:47, Jeremy Dawson wrote:
>>>> Hi Theo,
>>>> Thanks - but if you mean doing this, it seems not to be needed
>>>> [jeremy@localhost directory]$ opam repo add coq-released
>>>> repository
>>>> set-url'.
>>>> Cheers,
>>>> Jeremy
>>>> On 3/24/20 8:01 PM, Théo Zimmermann wrote:
>>>>> Hi again Jeremy,
>>>>> This is probably because you need to add the coq-released repository
>>>>> again to your current switch. See "Using opam to install Coq packages"
>>>>> on https://coq.inria.fr/opam-using.html.
>>>>> Théo
>>>>> Le mar. 24 mars 2020 à 07:23, Jeremy Dawson
>>>>> <Jeremy.Dawson AT anu.edu.au>
>>>>> a écrit :
>>>>>> Thanks all for the replies. I've now got a separate switch with
>>>>>> coq 8.11.0 installed, but the std++ library seems to have disappeared
>>>>>> since my first email:
>>>>>> [jeremy@localhost directory]$ opam switch
>>>>>> [jeremy@localhost directory]$ opam install coq-stdpp
>>>>>> [ERROR] No package named coq-stdpp found.
>>>>>> [jeremy@localhost directory]$ opam update
>>>>>> <><> Updating package repositories
>>>>>> [default] no changes from https://opam.ocaml.org
>>>>>> Why might this be, and what should I do from here?
>>>>>> Thanks
>>>>>> Jeremy
>>>>>> On 3/24/20 7:17 AM, Jason -Zhong Sheng- Hu wrote:
>>>>>>> Hi Jeremy,
>>>>>>> I would also like to add that it's probably a good idea to use
>>>>>>> different
>>>>>>> switches for different versions of Coq and in that case it is less
>>>>>>> likely to get into the version hassles. it's also more convenient to
>>>>>>> switch between switches in emacs too.
>>>>>>> *Thanks,*
>>>>>>> *Jason Hu*
>>>>>>> *https://hustmphrrr.github.io/*
>>>>>>> *From:*
>>>>>>> coq-club-request AT inria.fr
>>>>>>> <coq-club-request AT inria.fr>
>>>>>>> on behalf
>>>>>>> of Théo Zimmermann
>>>>>>> <theo.zimmi AT gmail.com>
>>>>>>> *Sent:* March 23, 2020 12:39 PM
>>>>>>> *To:* Coq Club
>>>>>>> *Subject:* Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
>>>>>>> Le lun. 23 mars 2020 à 16:35, Li-yao Xia
>>>>>>> <lysxia AT gmail.com>
>>>>>>> a écrit :
>>>>>>>> Hi Jeremy,
>>>>>>>> Your current switch uses ocaml 4.02 but coq 8.11.0 depends on ocaml
>>>>>>>> 4.05 && < 4.10. Create a new switch with a more recent version of
>>>>>>>> ocaml,
>>>>>>>> (But not too recent, < 4.10) so you can install coq 8.11.
>>>>>>>> > However it (apparently) tried to reinstall coq 8.8.2 (why?)
>>>>>>>> and failed,
>>>>>>>> > saying ERROR while compiling coq.8.8.2
>>>>>>>> The error message includes the logs below that line. There is an
>>>>>>>> output-file where to find the complete logs, and also an "### output
>>>>>>>> ###" section with the most recent output from the build.
>>>>>>>> > I think at the moment I have a working version of coq thanks
>>>>>>>> to the
>>>>>>>> > fedora package of coq, but how can I tell which version of the
>>>>>>>> library
>>>>>>>> > it is using?
>>>>>>>> You should probably not get coq via your OS distribution's package
>>>>>>>> manager. Only install it with opam.
>>>>>>>> Most OS distributions move slowly, so they're always a few versions
>>>>>>>> behind, and they only provide a limited selection of packages. If you
>>>>>>>> want to keep up with the bleeding edge, you should only install OCaml
>>>>>>>> and Coq packages through opam.
>>>>>>>> Don't hesitate to ask for further clarification.
>>>>>>>> Cheers,
>>>>>>>> Li-yao
>>>>>>>> On 3/23/20 10:31 AM, Jeremy Dawson wrote:
>>>>>>>>> Hi Ralf,
>>>>>>>>> Thanks - I tried opam update, and then as its output suggested doing
>>>>>>>>> opam upgrade, I tried that.
>>>>>>>>> However it (apparently) tried to reinstall coq 8.8.2 (why?) and
>>>>>>>>> failed,
>>>>>>>>> It suggested running
>>>>>>>>> opam switch import
>>>>>>>>> "/home/jeremy/opam-coq.8.8.2/ocaml-base-compiler.4.02.3/.opam-switch/backup/state-20200323132407.export"
>>>>>>>>> which seemed to hang at the point Processing 9/13: [coq: make]
>>>>>>>>> I think at the moment I have a working version of coq thanks to the
>>>>>>>>> library
>>>>>>>>> it is using?
>>>>>>>>> Thanks
>>>>>>>>> Jeremy
>>>>>>>>> On 3/23/20 7:04 PM, Ralf Jung wrote:
>>>>>>>>>> Hi Jeremy,
>>>>>>>>>> std++ 1.3 is compatible with Coq 8.8.2 (and even with Coq 8.7.2),
>>>>>>>>>> so that cannot
>>>>>>>>>> be the problem. It looks like your package definitions are quite
>>>>>>>>>> outdated,
>>>>>>>>>> given that it cannot even find Coq 8.11.0. Did you try "opam
>>>>>>>>>> update"?
>>>>>>>>>> Kind regards,
>>>>>>>>>> Ralf
>>>>>>>>>> On 23.03.20 03:26, Jeremy Dawson wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> > This release of the std++ library adds support for Coq
>>>>>>>>>>> 8.11 and is
>>>>>>>>>>> available in Coq's opam repository.
>>>>>>>>>>> At present I have Coq 8.8.2 on my machine, and I don't know what
>>>>>>>>>>> version
>>>>>>>>>>> of the standard library. How do I find that out?
>>>>>>>>>>> How do I install a new version of the standard library (ie what
>>>>>>>>>>> do I do
>>>>>>>>>>> to make use of the fact that it is "available in Coq's opam
>>>>>>>>>>> repository"?
>>>>>>>>>>> Trying opam install coq-stdpp seems to start installing coq-stdpp
>>>>>>>>>>> 1.1.0
>>>>>>>>>>> which I assume is not what I want.
>>>>>>>>>>> In any event I assume I have to upgrade to Coq 8.11 to make use
>>>>>>>>>>> of it,
>>>>>>>>>>> would that be right?
>>>>>>>>>>> I've tried to do that, following instructions at
>>>>>>>>>>> https://coq.inria.fr/opam-using.html but part way through I get
>>>>>>>>>>> [jeremy@localhost sysadmin]$ opam pin add coq 8.11.0
>>>>>>>>>>> [ERROR] Package coq has no known version 8.11.0 in the
>>>>>>>>>>> repositories
>>>>>>>>>>> What do I need to do?
>>>>>>>>>>> Thanks
>>>>>>>>>>> Jeremy
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, (continued)
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Li-yao Xia, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Théo Zimmermann, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jason -Zhong Sheng- Hu, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jeremy Dawson, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Théo Zimmermann, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jeremy Dawson, 03/25/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/25/2020
