coq-club - Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
  • To: Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
  • Date: Wed, 25 Mar 2020 15:37:53 +0100
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT juno.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23: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
Hi Jeremy,
> Sorry for the extra line breaks - it's thunderbird email
You can prevent those by using "Paste as Quotation" in the "Edit" menu.
Okay so the "coq-released" repo is not actually enabled for the with-coq
switch.
In current opam versions, "opam repo add foo" should do that, but version
2.0.1
is quite old and a lot of bugs have been fixed since then. Could you upgrade
to
the latest version (2.0.6)?
Kind regards,
Ralf
On 25.03.20 15:20, Jeremy Dawson wrote:
> Hi Ralf,
> thanks - the following output does seem peculiar
> [jeremy@localhost Downloads]$ opam repo list
> [NOTE] These are the repositories in use by the current switch. Use
> '--all' to
> see all configured repositories.
> <><> Repository configuration for switch with-coq
> 1 default https://opam.ocaml.org
> [jeremy@localhost Downloads]$ opam switch
> # switch compiler description
> ocaml-base-compiler.4.02.3 ocaml-base-compiler.4.02.3
> -> with-coq ocaml-base-compiler.4.05.0 with-coq
> [jeremy@localhost Downloads]$ opam repo list --all
> # Repository # Url # Switches(rank)
> coq-released http://coq.inria.fr/opam/released ocaml-base-compiler.4.02.3(1)
> default https://opam.ocaml.org <default>(1) with-coq(1)
> ocaml-base-compiler.4.02.3(2)
> [jeremy@localhost Downloads]$ opam repo add coq-released
> https://coq.inria.fr/opam/released
> [ERROR] Repository coq-released is already set up and points to
> http://coq.inria.fr/opam/released. To change that, use 'opam
> repository
> set-url'.
> [jeremy@localhost Downloads]$ opam --version
> 2.0.1
> Cheers,
> Jeremy
> On 3/26/20 12:57 AM, Ralf Jung wrote:
>> Hi Jeremy,
>> Well, that is pretty strange. What does "opam repo list" say?
>> Also, let me repeat what Theo said earlier:
>>> I'll add to the excellent advice of Ralf and Li-yao that another
>>> source of confusion can be the version of opam itself. Please make
>>> sure that opam --version gives you something above 2.0, otherwise it
>>> won't work to get recent Coq and Coq packages versions.
>> It's really important that you use opam 2.
>> Kind regards,
>> Ralf
>> On 25.03.20 14:17, Jeremy Dawson wrote:
>>> Hi ralf,
>>> Thanks - but I think that is what I have done, have I misunderstood this?
>>> [jeremy@localhost laptops]$ opam switch
>>> [jeremy@localhost laptops]$ opam repo add coq-released
>>> repository
>>> set-url'.
>>> [jeremy@localhost laptops]$ opam search coq-stdpp
>>> # Packages matching: match(*coq-stdpp*)
>>> # No matches found
>>> Cheers,
>>> Jeremy
>>> On 3/24/20 11:37 PM, Ralf Jung wrote:
>>>> Hi Jeremy,
>>>> You need to do the "repo add" when "with-coq" is your current switch.
>>>> Repositories are per-switch with opam.
>>>> Kind regards,
>>>> Ralf
>>>> On 24.03.20 12:47, Jeremy Dawson wrote:
>>>>> Hi Theo,
>>>>> Thanks - but if you mean doing this, it seems not to be needed
>>>>> [jeremy@localhost directory]$ opam repo add coq-released
>>>>> repository
>>>>> set-url'.
>>>>> Cheers,
>>>>> Jeremy
>>>>> On 3/24/20 8:01 PM, Théo Zimmermann wrote:
>>>>>> Hi again Jeremy,
>>>>>> This is probably because you need to add the coq-released repository
>>>>>> again to your current switch. See "Using opam to install Coq packages"
>>>>>> on https://coq.inria.fr/opam-using.html.
>>>>>> Théo
>>>>>> Le mar. 24 mars 2020 à 07:23, Jeremy Dawson
>>>>>> a écrit :
>>>>>>> Thanks all for the replies. I've now got a separate switch with
>>>>>>> coq 8.11.0 installed, but the std++ library seems to have disappeared
>>>>>>> since my first email:
>>>>>>> [jeremy@localhost directory]$ opam switch
>>>>>>> # switch compiler
>>>>>>> description
>>>>>>> [jeremy@localhost directory]$ opam install coq-stdpp
>>>>>>> [ERROR] No package named coq-stdpp found.
>>>>>>> [jeremy@localhost directory]$ opam update
>>>>>>> <><> Updating package repositories
>>>>>>> [default] no changes from https://opam.ocaml.org
>>>>>>> Why might this be, and what should I do from here?
>>>>>>> Thanks
>>>>>>> Jeremy
>>>>>>> On 3/24/20 7:17 AM, Jason -Zhong Sheng- Hu wrote:
>>>>>>>> Hi Jeremy,
>>>>>>>> I would also like to add that it's probably a good idea to use
>>>>>>>> different
>>>>>>>> switches for different versions of Coq and in that case it is less
>>>>>>>> likely to get into the version hassles. it's also more convenient to
>>>>>>>> switch between switches in emacs too.
>>>>>>>> *Thanks,*
>>>>>>>> *Jason Hu*
>>>>>>>> *https://hustmphrrr.github.io/*
>>>>>>>> *From:*
>>>>>>>> coq-club-request AT inria.fr
>>>>>>>> <coq-club-request AT inria.fr>
>>>>>>>> on behalf
>>>>>>>> of Théo Zimmermann
>>>>>>>> <theo.zimmi AT gmail.com>
>>>>>>>> *Sent:* March 23, 2020 12:39 PM
>>>>>>>> *To:* Coq Club
>>>>>>>> *Subject:* Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
>>>>>>>> Le lun. 23 mars 2020 à 16:35, Li-yao Xia
>>>>>>>> <lysxia AT gmail.com>
>>>>>>>> a écrit :
>>>>>>>>> Hi Jeremy,
>>>>>>>>> Your current switch uses ocaml 4.02 but coq 8.11.0 depends on ocaml
>>>>>>>>> 4.05 && < 4.10. Create a new switch with a more recent version of
>>>>>>>>> ocaml,
>>>>>>>>> (But not too recent, < 4.10) so you can install coq 8.11.
>>>>>>>>> > However it (apparently) tried to reinstall coq 8.8.2 (why?)
>>>>>>>>> and failed,
>>>>>>>>> > saying ERROR while compiling coq.8.8.2
>>>>>>>>> The error message includes the logs below that line. There is an
>>>>>>>>> output-file where to find the complete logs, and also an "### output
>>>>>>>>> ###" section with the most recent output from the build.
>>>>>>>>> > I think at the moment I have a working version of coq thanks
>>>>>>>>> to the
>>>>>>>>> > fedora package of coq, but how can I tell which version of
>>>>>>>>> the library
>>>>>>>>> > it is using?
>>>>>>>>> You should probably not get coq via your OS distribution's package
>>>>>>>>> manager. Only install it with opam.
>>>>>>>>> Most OS distributions move slowly, so they're always a few versions
>>>>>>>>> behind, and they only provide a limited selection of packages. If
>>>>>>>>> you
>>>>>>>>> want to keep up with the bleeding edge, you should only install
>>>>>>>>> OCaml
>>>>>>>>> and Coq packages through opam.
>>>>>>>>> Don't hesitate to ask for further clarification.
>>>>>>>>> Cheers,
>>>>>>>>> Li-yao
>>>>>>>>> On 3/23/20 10:31 AM, Jeremy Dawson wrote:
>>>>>>>>>> Hi Ralf,
>>>>>>>>>> Thanks - I tried opam update, and then as its output suggested
>>>>>>>>>> doing
>>>>>>>>>> opam upgrade, I tried that.
>>>>>>>>>> However it (apparently) tried to reinstall coq 8.8.2 (why?) and
>>>>>>>>>> failed,
>>>>>>>>>> It suggested running
>>>>>>>>>> opam switch import
>>>>>>>>>> "/home/jeremy/opam-coq.8.8.2/ocaml-base-compiler.4.02.3/.opam-switch/backup/state-20200323132407.export"
>>>>>>>>>> which seemed to hang at the point Processing 9/13: [coq: make]
>>>>>>>>>> I think at the moment I have a working version of coq thanks to the
>>>>>>>>>> fedora package of coq, but how can I tell which version of the
>>>>>>>>>> library
>>>>>>>>>> it is using?
>>>>>>>>>> Thanks
>>>>>>>>>> Jeremy
>>>>>>>>>> On 3/23/20 7:04 PM, Ralf Jung wrote:
>>>>>>>>>>> Hi Jeremy,
>>>>>>>>>>> std++ 1.3 is compatible with Coq 8.8.2 (and even with Coq 8.7.2),
>>>>>>>>>>> so that cannot
>>>>>>>>>>> be the problem. It looks like your package definitions are quite
>>>>>>>>>>> outdated,
>>>>>>>>>>> given that it cannot even find Coq 8.11.0. Did you try "opam
>>>>>>>>>>> update"?
>>>>>>>>>>> Kind regards,
>>>>>>>>>>> Ralf
>>>>>>>>>>> On 23.03.20 03:26, Jeremy Dawson wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> > This release of the std++ library adds support for Coq
>>>>>>>>>>>> 8.11 and is
>>>>>>>>>>>> available in Coq's opam repository.
>>>>>>>>>>>> At present I have Coq 8.8.2 on my machine, and I don't know what
>>>>>>>>>>>> version
>>>>>>>>>>>> of the standard library. How do I find that out?
>>>>>>>>>>>> How do I install a new version of the standard library (ie what
>>>>>>>>>>>> do I do
>>>>>>>>>>>> to make use of the fact that it is "available in Coq's opam
>>>>>>>>>>>> repository"?
>>>>>>>>>>>> Trying opam install coq-stdpp seems to start installing
>>>>>>>>>>>> coq-stdpp 1.1.0
>>>>>>>>>>>> which I assume is not what I want.
>>>>>>>>>>>> In any event I assume I have to upgrade to Coq 8.11 to make use
>>>>>>>>>>>> of it,
>>>>>>>>>>>> would that be right?
>>>>>>>>>>>> I've tried to do that, following instructions at
>>>>>>>>>>>> https://coq.inria.fr/opam-using.html but part way through I get
>>>>>>>>>>>> [jeremy@localhost sysadmin]$ opam pin add coq 8.11.0
>>>>>>>>>>>> [ERROR] Package coq has no known version 8.11.0 in the
>>>>>>>>>>>> repositories
>>>>>>>>>>>> What do I need to do?
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Jeremy
Website: https://people.mpi-sws.org/~jung/
