- To: coq-club AT inria.fr, Jeremy Dawson <Jeremy.Dawson AT anu.edu.au>
- Subject: Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
- Date: Tue, 24 Mar 2020 13:37:40 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT juno.mpi-klsb.mpg.de
- Ironport-phdr: 9a23:vMUkZxag86+huhgcxotMR7j/LSx+4OfEezUN459isYplN5qZrs69bnLW6fgltlLVR4KTs6sC17OK9fm9ACdZud6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUhrwOhBoKevrB4Xck9q41/yo+53Ufg5EmCexbal9IRmrogjdrNQajIt/Jqo+1xfFvmZDdvhLy29vOV+ckBHw69uq8pV+6SpQofUh98BBUaX+Yas1SKFTASolPW4o+sDlrAHPQgST6HQSVGUWiQdIDBPe7B7mRJfxszD1ufR71SKHIMD5V7E0WTCl76d2VB/ljToMOjAl/G3LjMF7kblWqwy9qRNh34HUYZmVNPtgcaPbYdMaXndKUsJIWyBcHo+wc44DAuwGMuhFson9vEMOogWiCgmwCu3vzTpIiWX33a08zu8tFQ7L0QglE98IrX/arsj6NL0KXO6o0qfIwzXNYfBY1zjz54fHcAwur/6XULJscsfc01UjGx/Lg1iSr4HuIjOb1v4Ks2ie9+duSfigi2opqwpspjav28EsiobUjY8SyFDE6CN5wIkuKN29UE57YMeoEIBetiGBLYd2RdkiQ25xtSs817YIt5m7fC0Qx5QmwR7Sc/2Hc46S4hLiTumdOzl4hGh9dLK4mxm9602gyunmWsmzylZKoTJJktbNtnAR1xzT99OIRuF8/kemwTqP0hjT6uBdLUAvm6vbMIQtwrkqlpoct0nIAyz4mF3ugaOLeEgp/vKk5/njb7n8pZKRNpV4hw7iPqg2mMGyA/40PhUNUmWb4+ix1Lnu8VfkTLhIivA7lLTSvorAKsQBvKG5BhdY0oY95Ba7CDeryNYYnWQBLFJCYh6HipDpO1DXLPD7Cfe/mE+jnC1ux/DeMb3tGIjCIWbbnLfge7Zy9VJcxRIuwd1R459YEKwNLfbpVkLytdHUFBA0PxCsz+biEtp914ceWWyVAq+eNaPfqV2I5v8pI+mDf4IVvS79K/k86/71g345gkURfa6z3ZsYcHy4BOhpI12FYXrwhdcMCXsFvg0nTODzlFKCVSNTaG2pUqIn5jA7DZqmAp3ZSoCshryBxia7EYdMamBIEFDfWUvvIo6DQrIHbD+YCs5niD0NE7a7D8cD2AujsR6y57N4Ne3Ssnk6uIju0ckzy+TMjhY03TVyEoKQ33zLRnwizU0SQDpj5ql7rwRf11GMmfx6nvpXPdlL5rZSTRx8MoTTmb8pQ+vuUx7MK4/aAG2tRc+rVHRsF4tgke9LWF50HpCZtj6G2iOrB7EPkLnSX84x6qOZxGfqYcFnxCSfjfRzvxwdWsJKcFaeqOt/+gzUXdSbkVifkOCvbaVZ3yrW/iGG1WXIsEwKCFcsA5WAZmgWYw7tlfq8/lnLFuT8DKwmdxBe0oiFMKQYMtA=
Hi Jeremy,
You need to do the "repo add" when "with-coq" is your current switch.
Repositories are per-switch with opam.
Kind regards,
Ralf
On 24.03.20 12:47, Jeremy Dawson wrote:
> Hi Theo,
> Thanks - but if you mean doing this, it seems not to be needed
> [jeremy@localhost directory]$ opam repo add coq-released
> https://coq.inria.fr/opam/released
> [ERROR] Repository coq-released is already set up and points to
> http://coq.inria.fr/opam/released. To change that, use 'opam
> repository
> set-url'.
> Cheers,
> Jeremy
> On 3/24/20 8:01 PM, Théo Zimmermann wrote:
>> Hi again Jeremy,
>> This is probably because you need to add the coq-released repository
>> again to your current switch. See "Using opam to install Coq packages"
>> on https://coq.inria.fr/opam-using.html.
>> Théo
>> Le mar. 24 mars 2020 à 07:23, Jeremy Dawson
>> a écrit :
>>> Thanks all for the replies. I've now got a separate switch with
>>> coq 8.11.0 installed, but the std++ library seems to have disappeared
>>> since my first email:
>>> [jeremy@localhost directory]$ opam switch
>>> # switch compiler description
>>> ocaml-base-compiler.4.02.3 ocaml-base-compiler.4.02.3
>>> -> with-coq ocaml-base-compiler.4.05.0 with-coq
>>> [jeremy@localhost directory]$ opam install coq-stdpp
>>> [ERROR] No package named coq-stdpp found.
>>> [jeremy@localhost directory]$ opam update
>>> <><> Updating package repositories
>>> [default] no changes from https://opam.ocaml.org
>>> Why might this be, and what should I do from here?
>>> Thanks
>>> Jeremy
>>> On 3/24/20 7:17 AM, Jason -Zhong Sheng- Hu wrote:
>>>> Hi Jeremy,
>>>> I would also like to add that it's probably a good idea to use different
>>>> switches for different versions of Coq and in that case it is less
>>>> likely to get into the version hassles. it's also more convenient to
>>>> switch between switches in emacs too.
>>>> *Thanks,*
>>>> *Jason Hu*
>>>> *https://hustmphrrr.github.io/*
>>>> *From:*
>>>> coq-club-request AT inria.fr
>>>> <coq-club-request AT inria.fr>
>>>> on behalf
>>>> of Théo Zimmermann
>>>> <theo.zimmi AT gmail.com>
>>>> *Sent:* March 23, 2020 12:39 PM
>>>> *To:* Coq Club
>>>> <coq-club AT inria.fr>
>>>> *Subject:* Re: [Coq-Club] coq library std++ 1.3 / coq 8.11
>>>> I'll add to the excellent advice of Ralf and Li-yao that another
>>>> source of confusion can be the version of opam itself. Please make
>>>> sure that opam --version gives you something above 2.0, otherwise it
>>>> won't work to get recent Coq and Coq packages versions.
>>>> Le lun. 23 mars 2020 à 16:35, Li-yao Xia
>>>> <lysxia AT gmail.com>
>>>> a écrit :
>>>>> Hi Jeremy,
>>>>> Your current switch uses ocaml 4.02 but coq 8.11.0 depends on ocaml >=
>>>>> 4.05 && < 4.10. Create a new switch with a more recent version of ocaml,
>>>>> (But not too recent, < 4.10) so you can install coq 8.11.
>>>>> > However it (apparently) tried to reinstall coq 8.8.2 (why?) and
>>>>> failed,
>>>>> > saying ERROR while compiling coq.8.8.2
>>>>> The error message includes the logs below that line. There is an
>>>>> output-file where to find the complete logs, and also an "### output
>>>>> ###" section with the most recent output from the build.
>>>>> > I think at the moment I have a working version of coq thanks to the
>>>>> > fedora package of coq, but how can I tell which version of the
>>>>> library
>>>>> > it is using?
>>>>> You should probably not get coq via your OS distribution's package
>>>>> manager. Only install it with opam.
>>>>> Most OS distributions move slowly, so they're always a few versions
>>>>> behind, and they only provide a limited selection of packages. If you
>>>>> want to keep up with the bleeding edge, you should only install OCaml
>>>>> and Coq packages through opam.
>>>>> Don't hesitate to ask for further clarification.
>>>>> Cheers,
>>>>> Li-yao
>>>>> On 3/23/20 10:31 AM, Jeremy Dawson wrote:
>>>>>> Hi Ralf,
>>>>>> Thanks - I tried opam update, and then as its output suggested doing
>>>>>> opam upgrade, I tried that.
>>>>>> However it (apparently) tried to reinstall coq 8.8.2 (why?) and failed,
>>>>>> It suggested running
>>>>>> opam switch import
>>>>>> "/home/jeremy/opam-coq.8.8.2/ocaml-base-compiler.4.02.3/.opam-switch/backup/state-20200323132407.export"
>>>>>> which seemed to hang at the point Processing 9/13: [coq: make]
>>>>>> fedora package of coq, but how can I tell which version of the library
>>>>>> it is using?
>>>>>> Thanks
>>>>>> Jeremy
>>>>>> On 3/23/20 7:04 PM, Ralf Jung wrote:
>>>>>>> Hi Jeremy,
>>>>>>> std++ 1.3 is compatible with Coq 8.8.2 (and even with Coq 8.7.2), so
>>>>>>> that cannot
>>>>>>> be the problem. It looks like your package definitions are quite
>>>>>>> outdated,
>>>>>>> given that it cannot even find Coq 8.11.0. Did you try "opam update"?
>>>>>>> Kind regards,
>>>>>>> Ralf
>>>>>>> On 23.03.20 03:26, Jeremy Dawson wrote:
>>>>>>>> Hi,
>>>>>>>> > This release of the std++ library adds support for Coq 8.11
>>>>>>>> and is
>>>>>>>> available in Coq's opam repository.
>>>>>>>> At present I have Coq 8.8.2 on my machine, and I don't know what
>>>>>>>> version
>>>>>>>> of the standard library. How do I find that out?
>>>>>>>> How do I install a new version of the standard library (ie what do I
>>>>>>>> do
>>>>>>>> to make use of the fact that it is "available in Coq's opam
>>>>>>>> repository"?
>>>>>>>> Trying opam install coq-stdpp seems to start installing coq-stdpp
>>>>>>>> 1.1.0
>>>>>>>> which I assume is not what I want.
>>>>>>>> In any event I assume I have to upgrade to Coq 8.11 to make use of
>>>>>>>> it,
>>>>>>>> would that be right?
>>>>>>>> I've tried to do that, following instructions at
>>>>>>>> https://coq.inria.fr/opam-using.html but part way through I get
>>>>>>>> [jeremy@localhost sysadmin]$ opam pin add coq 8.11.0
>>>>>>>> [ERROR] Package coq has no known version 8.11.0 in the repositories
>>>>>>>> What do I need to do?
>>>>>>>> Thanks
>>>>>>>> Jeremy
Website: https://people.mpi-sws.org/~jung/
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, (continued)
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jeremy Dawson, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Théo Zimmermann, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Li-yao Xia, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jason -Zhong Sheng- Hu, 03/23/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jeremy Dawson, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Théo Zimmermann, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/24/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Jeremy Dawson, 03/25/2020
- Re: [Coq-Club] coq library std++ 1.3 / coq 8.11, Ralf Jung, 03/25/2020
