coq-club - Re: [Coq-Club] option to disable partially qualified Require Imports
  • To: coq-club AT inria.fr, Théo Zimmermann <theo AT irif.fr>
  • Subject: Re: [Coq-Club] option to disable partially qualified Require Imports
  • Date: Fri, 18 Sep 2020 13:25:58 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jung AT mpi-sws.org; spf=Pass smtp.mailfrom=jung AT mpi-sws.org; spf=None smtp.helo=postmaster AT jupiter.mpi-klsb.mpg.de
  • Ironport-phdr: 9a23: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
Hi Théo,
>> I've had quite weird problems in the past caused by stale .vo files being
>> picked
>> up by ambiguous imports, so I'd be all for a way to ensure that all
>> imports are
>> unambiguous. (In fact I am quite surprised that ambiguous imports exist at
>> all,
>> that seems quite contrary to Coq's usual design geared towards precision.
>> No
>> other language I work or worked with has ambiguous imports the way Coq
>> does --
>> Python, Java, C++, Rust all do not have this problem.)
> With Dune, this won't be an issue anymore.
Given that Dune is a build system, how can it add the missing language feature
of precisely specifying which file to import?
It might help against the "stale vo" problem, but that was just an example.
There are many more reasons for wanting imports to be unambiguous, like being
sure ones code keeps compiling and doing the right thing when more modules are
added.
Kind regards,
Ralf
Website: https://people.mpi-sws.org/~jung/
