coq-club - Re: [Coq-Club] option to disable partially qualified Require Imports
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] option to disable partially qualified Require Imports
  • Date: Fri, 18 Sep 2020 07:04:31 -0700
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-io1-f45.google.com
  • Ironport-phdr: 9a23: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
Because I am assuming the library's author is not dumb enough to have a
hierarchy A/B/C/**/A/B/C.v.
"not dumb" is not a good precondition for using Coq, hopefully not something we'd like to write in the Coq manual.
If the required precondition on library structure (on all Coq libraries in the world that one may ever want to import) can be spelled out in a more objective and precise way, it may be okay.
But then it might be just simpler to just implement the feature that Gaëtan mentioned.
