coq-club - Re: [Coq-Club] option to disable partially qualified Require Imports
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] option to disable partially qualified Require Imports
  • Date: Fri, 18 Sep 2020 15:45:16 +0200
Le 18/09/2020 à 15:28, Ralf Jung a écrit :
>> Another possibility would be to relax some requirements of From-Require.
>> Currently, "From A.B.C Require D.E.F" means that not only the path
>> should start with A.B.C and finish with D.E.F, but also that there
>> should be no overlap between A.B.C and D.E.F. If the second constraint
>> was removed, then Require would become non-ambiguous for people who have
>> to use messy libraries.
> I don't see how accepting even more paths for a given import can possibly
> resolve any ambiguities? "From A.B.C Require A.B.C" would then match both
> "A.B.C" and "A.B.C.*.A.B.C".
Because I am assuming the library's author is not dumb enough to have a
hierarchy A/B/C/**/A/B/C.v.
At some point, we have to accept that we cannot always win against dumb
or malicious users. They will always find a way to circumvent the system.
I don't even understand why we are wasting so much on this issue when it
is still possible to write the following in Coq:
Cd "/tmp".
Extraction passwd.
Best regards,
Guillaume
